Old 05-29-2009, 06:34 PM   #1
stixtasy12
Member#: 97128
08 Legacy Spec B
QSM
Default trans and rear diff fluids questions (Amsoil)
I have searched and I am still unsure about a few things. I picked up 5 quarts of the Amsoil severe gear 75w-90, am I able to use this in my trans and rear diff without a problem? I also picked up a quart of the Amsoil synthetic manual synchromesh trans fluid, would that do any good for the trans?
stixtasy12 is offline   Reply With Quote
Old 05-30-2009, 12:56 AM   #2
speedadc
Member#: 158096
2009 WRX
SSM
Go ahead and put it in. I have been running that in my car for a while now, and there is a slightly better feel IMO.
Just a little thing, when pouring in the trans fluid, go slow, it will bubble back up, and if you put too much in the funnel it will go all over the place(lucky for me this did not happen). Oh and if you get a long enough funnel and one that fits into the dip stick hole you do not need to remove your IC.
Go ahead and put it in, nothing wrong with it. At least for me on the last 40K plus miles.
speedadc is offline   Reply With Quote
Old 05-30-2009, 01:37 AM   #3
suub07
Member#: 163702
2007 impreza 2.5
UGM
I use Redline 75w-90 NS in the trans, and Redline 75w-90 in the rear diff. It is a much better feel over stock fluid, and the whole shifting to first while moving problem that is fairly common in our 5MT's is not an issue at all.
I know that the 5MT's are fairly picky about which fluids can be used safely, and which cannot (for example Motul 300 and redline are great, while valvoline is terrible in our trans even though they are all a 75w90 viscosity).
Unibombers manifesto has good advice about what to use and what not to. I have heard mixed things about amsoil, but haven't ever used it myself
suub07 is offline   Reply With Quote
Old 05-30-2009, 01:40 AM   #4
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
NS being non-synthetic?
I was unaware that it was a good idea to use NS in our transmissions, I figured Synthetic was just da bomb diggity all around.
XanRules is offline   Reply With Quote
Old 05-30-2009, 01:52 AM   #5
suub07
Member#: 163702
2007 impreza 2.5
UGM
The NS is a synthetic oil. Im not sure what the NS stands for. I just check out Redlines site to confirm before posting.
I was debating using the 75w90 NS, or the Lightweight Shockproof that a lot of people on here run, but the back of the bottle on the shockproof said that it could mean death for syncros... so it was NS FTW.
Old 05-30-2009, 09:04 AM   #6
viper74656
Member#: 84758
'04 WRB WRX
NS = No Slip, meaning it doesn't have friction additives, which means it is good for the synchros. You don't want the NS stuff in the rear diff b/c no synchros back there.
viper74656 is offline   Reply With Quote
Old 05-30-2009, 11:11 AM   #7
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP - SOLD
Yes you can run that in your trans and read diff without a problem.
The manual synchromesh fluid though is not needed for anything.
RonJitsu is offline   Reply With Quote
Getting ready for trans and rear diff fluid change, need recommendations BGPKR Transmission (AT/MT) & Driveline 8 03-11-2008 02:29 AM
Power steering fluid, manual tranny fluid, and rear diff fluid ex_boyometric Vancouver Impreza Club Forum -- VIC 17 03-09-2008 05:54 AM
trans and rear diff fluid pinoiraider Service & Maintenance 1 07-28-2007 02:21 AM
weird sound after trans and rear diff fluid change IIdiceII Service & Maintenance 1 07-16-2006 05:38 PM
Best trans and rear diff fluid? stevepius Transmission (AT/MT) & Driveline 12 08-09-2005 08:59 AM
