Old 05-29-2009, 07:29 PM   #1
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Default shift fork gets loose when car is in stop and go traffic?
I just noticed this happening in the past couple of months. When I'm driving around the city, normal stop and go traffic (not rush hour, ride your clutch for 2 feet then stop, repeat for the next 4 blocks ) The clutch pedal would develop sort of a clunk near the bottom of its travel. I can half hear/half feel it whenever I shift into any gear from neutral, but especially in first and second if that helps any. When I opened my hood up and checked the slave cylinder/clutch fork, I found I could easily wiggle the clutch fork from side to side when that starts to happens.
When the car has been sitting overnight or I'm driving on the highway, I don't have this problem.
I've also noticed I would have to rev the engine about 500rpms higher than I would just to start from a complete stop. It used to be that I could easily get the car rolling with around 1100rpms, now I found I would have to blip the gas a little more to around 1500-1750rpms to get it rolling smoothly.
What could be causing this? normal clutch wear? slave cylinder? air in the hydraulic clutch?
I'm running an ACT street clutch (push style) and 14lb flywheel for the past 15k miles and 2 1/2 years. The last year mated to a turbo engine (ej205).
rougeben83 is offline   Reply With Quote
Old 05-31-2009, 09:39 PM   #2
rougeben83
Member#: 115154
2005 Outback XT
White on grey
update: should there be any play in the slave cylinder piston? I wiggled the shift fork again today, and the the rod coming from the slave cylinder moves along with it...
Old 06-02-2009, 10:44 AM   #3
rougeben83
Member#: 115154
2005 Outback XT
White on grey
anyone?
Old 06-02-2009, 12:21 PM   #4
Member#: 67
1999 Outlasting
the competition.
almost sound like the spring tension in the PP is starting to die.
T
Idle jumps to 2000 in stop and go traffic... Synx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 10-19-2009 03:25 PM
Idle jumping high in stop n go traffic ReDHaTyGuY Newbies & FAQs 11 06-05-2009 09:45 AM
How do you drive in stop and go traffic? Ken Off-Topic 49 09-26-2007 01:56 PM
stop and go traffic for miles on end -- arrival of smelly clutch Xymox Newbies & FAQs 20 08-25-2005 03:56 PM
Do we get a loaner when car is in service? KenshinPlates General Community 14 01-26-2002 05:07 PM
