Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 05-29-2009, 09:27 PM   #1
rsw0124
Member#: 173013
..08 AwwGrr FTW!
[email protected]+ft ^sea level
Default Reliablity Of 2.0l heads on a built 2.5l block?
Just as the title says.... I beleive I blew a blew a ring land or the head gasket in my 2.0l. So I'm just gonna buy a Brand new 2.5l block that was built by CBRD.
Just wondering about the reliablity of the two as one?????? I know its been done plenty of times with great results. Just looking for some first hand experiences. It's being put together next week. The hta68 is on the car but has still not been tuned, I'm waiting to get the motor back together.
PS..... Very well aware that I need to watch my trans with a very close eye.
rsw0124 is offline   Reply With Quote
Old 05-29-2009, 09:30 PM   #2
darksc00by
Member#: 102140
I personally like the setup with a stock headgasket. I ran a 16g, and had GREAT results (stock tmic, 565cc injectors)
I made 260/290 @14lbs.
I highly recommend it.
darksc00by is online now   Reply With Quote
Old 05-30-2009, 01:21 PM   #3
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
Check in the built motor discussion - you'll have better luck.
FWIW, my built EJ257 block with EJ207 heads has been running strong with 12K daily driven miles over the past year - all tuned to 22.5psi on pump, and higher (8.8:1) compression. Stock headgaskets are the best choice. Just put it together right and tune it right, and you won't have to worry.
zeropsi is offline   Reply With Quote
Old 05-30-2009, 02:37 PM   #4
rsw0124
Member#: 173013
..08 AwwGrr FTW!
Thanks! that's good to know.
Can a mod. move my thread to the built motor forum for me please!
Old 05-30-2009, 05:47 PM   #5
fearmywrx
Member#: 176103
2004 WRX
Blouch 18g 324whp
just repost, not like much was really mentioned
fearmywrx is offline   Reply With Quote
Assembly: 2.0L Heads on 2.5L block Kingpin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 110 09-26-2014 06:58 AM
2003 WRX 2.5L/2.0L heads hybrid build w/ GT52 on dyno today Mr.Anderson Proven Power Bragging 11 05-11-2010 06:24 PM
93 2.2 sohc heads on a 02 2.5 sohc, will they fit? Oldbluelegacy Normally Aspirated Powertrain 17 05-05-2010 01:22 AM
need a base for 2.5L block/2.0L heads w/VF30 and TMIC db_amn UTEC 9 08-11-2009 05:18 AM
2003 wrx w/ ej257 swap sti cams stock 2.0L heads on a TD06H 20g w/ 8cm exhaust housin 03SuBbYWrX Proven Power Bragging 35 12-01-2007 05:15 PM
