South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 05-30-2009, 04:34 AM   #1
C-grunt
Member#: 152713
2013 Tundra 4x4 TRD
Default Electrical Guru needed, 1970 Chevelle
Hey guys, Im most likely going to be buying a bad ass built 70 Chevelle pretty soon. Im getting it for an exceptional price because he's my friend but also because its got an electrical problem. The battery is getting drained at a high rate and he hasnt been able to figure it out. Anyone out there that could help me with this?
Ill get some specs and pictures tomorrow.
C-grunt is offline   Reply With Quote
Old 05-30-2009, 09:53 AM   #2
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Wirelessly posted (LG Voyager: Mozilla/4.1 (compatible; MSIE 6.0; ) 400x240 LGE VX10000)
I'll help you out, but I live on the other side of the world from you. It should be easy enough to figure out what is draining it, there are no computers to worry about so it should just be some damn junky little circuit, you just need to identify. Just take your time and use a systematic approach to figuring out where the problem lies. There is likely a bulb stuck on somewhere or a short to ground that is not large enough to pop the fuse. It could also possibly be that the alternator isn't charging the battery?
Old 05-30-2009, 09:54 AM   #3
kpluiten
Member#: 120273
06 WRBWRXWGN
OH, and pictures of said bad ass car!
Old 05-30-2009, 12:49 PM   #4
02blkwagn19
Member#: 146496
02 WRX Wagon 2.1L
Built not bought. #0003
thats awesome C-Grunt! I'm actually looking to buy a 70-72 chevelle to restore pretty soon as well, good luck and hope you find the problem!
American Muscle FTW!!!
02blkwagn19 is offline   Reply With Quote
Old 05-30-2009, 01:13 PM   #5
02blkwagn19
Member#: 146496
02 WRX Wagon 2.1L
Oh i forgot to mention, if that car has an aftermarket tach, 8 out of 10 times the drain comes from those because they are often times wired incorrectly and sometimes people accidentally wire them drawing constant power. and you wouldn't believe the rate at which i have seen those little mistakes drain a battery.
just fyi
Old 05-30-2009, 01:55 PM   #6
*6STARS*
Member#: 205327
2006 WRX TR
1970 Camaro
You cant really wire a tach wrong.
Any way how fast does it drain? It may be the voltage regulator, it should be on the driver side mounted on the radiator support on the inside on the engine bay. it could also be the connection in the alternator on the big +POS wire going into it. Also make sure the 2 should be blue and yellow wires are pluged in to the alternator aswell, unless they converted it to a single wire alternator. I melted said wire on time and may it gave me problems like you would not believe. I may also be an underdrive pulley that does not spin fast enough to actually charge at cruising speed. Does the tach wig out and bounce around when cruising? Last but not least if you want to build a big block for the car I have a ton of stuff to make a 496CID motor. LMK if I can help any more. Sorry for the so jummbled post but I just woke up.
*6STARS* is offline   Reply With Quote
Old 05-30-2009, 01:58 PM   #7
*6STARS*
Member#: 205327
2006 WRX TR
1970 Camaro
I would also look at poor ground connections.
Old 05-30-2009, 02:11 PM   #8
ShaggyTR
Member#: 197159
89 SR20 30r Coupe
Aspen White 05 STi
i was poking around on google and alot of people seem to say it was a bad alternator.
or wired incorrectly
ShaggyTR is offline   Reply With Quote
Old 05-30-2009, 03:48 PM   #9
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
good call
szeny is offline   Reply With Quote
Old 05-30-2009, 07:48 PM   #10
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
Originally Posted by szeny View Post
good call
lulz^
v8eaterWRX is offline   Reply With Quote
Old 05-31-2009, 06:21 AM   #11
C-grunt
Member#: 152713
2013 Tundra 4x4 TRD
So I talked to my buddy today and got some more info.
Crate 350 bored 30 over
Built to take 175 shot nitrous
NOS wet system, no pill in it....thinking just a 100 though to be safe
Munsy (spelling) 4 speed with new clutch
Chevy 12 bolt rear end from 68 Camaro with 4.10 gears
Stronger axles
Rear disk brakes from a Corvette (unknown year)
Line brake
Coilovers all around
Interior needs some tlc but its mechanically pretty good. Sorry pics arent that good.
Old 05-31-2009, 12:22 PM   #12
*6STARS*
Member#: 205327
2006 WRX TR
1970 Camaro
Nice car. Muncie 4 speed, which one M20,M21 or the infamous rock crusher M22? This car seems to set up pretty well. Just to play it a little more safe find out what pistons and the ring end gap if you can. That would just let you further know what kind of N2o hit you can take . Is it a 4 link car, being tubbed and coilovers and all? This is weird I have a 68 camaro rearend with 4.11's too also with corvette C4 disk brakes and an M21 muncie 4 speed. This is where the similarities end though.
Old 05-31-2009, 01:04 PM   #13
02blkwagn19
Member#: 146496
02 WRX Wagon 2.1L
Like I stated before, yes one REALLY CAN wire a tach wrong, you seem to know your stuff, so you should know the kinds of hacks that own old cars like this that think they know everything about cars and screw up the easiest tasks, even wiring a tach.
But either way this looks like a great setup and a beauiful car, you are certainly going to have fun with this car!!
Old 05-31-2009, 01:54 PM   #14
kpluiten
Member#: 120273
06 WRBWRXWGN
I would imagine you could wire a tach incorrectly for sure. What if you connected it to a constant +12 volt and not an ignition switched +12? I'd bet that would drain the battery at some rate. I've seen it done on other cars...
Old 05-31-2009, 02:06 PM   #15
ShaggyTR
Member#: 197159
89 SR20 30r Coupe
Aspen White 05 STi
good call
thanks chief
Old 05-31-2009, 02:27 PM   #16
*6STARS*
Member#: 205327
2006 WRX TR
1970 Camaro
True you are correct. I just think that is crazy how someone could screw that up, but you are ciorrect. I said that in this case cause the guy who he is getting it from seems like he knows his stuff.
Old 05-31-2009, 04:26 PM   #17
kpluiten
Member#: 120273
06 WRBWRXWGN
Buy the car already. It's badass.
Old 05-31-2009, 04:36 PM   #18
C-grunt
Member#: 152713
2013 Tundra 4x4 TRD
Well he is pretty good mechanically but admits he's no electrician. He thinks the problem is somewhere in the rear of the car but isnt sure.
Old 05-31-2009, 06:04 PM   #19
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
let me know if you need my help.
I've been doing auto electrical for almost 15 years, I've done numerous engine swaps, including into sandrails, carburated and FI. Just got done wiring factory repo console gauges in a 69 camaro.
Im up near the glendale arena so I'm too far away.
bobturismo is offline   Reply With Quote
Old 05-31-2009, 07:07 PM   #20
want2004stipronto
Member#: 207273
2003 Ford
Mustang gt supercharged
thats a badsas chevelle and those muncie trannys are very strong ur gunna have with that car gl with the electrical problem
want2004stipronto is offline   Reply With Quote
Old 06-02-2009, 06:03 AM   #21
C-grunt
Member#: 152713
2013 Tundra 4x4 TRD
Hey guys update. So the loan was approved. Price is 14k for the car plus lots of extras (tires and misc parts).
We talked about what exactly happens with the electric. The car will start fine but after about 5 miles the volts will drop and the car shuts down. You can jump it and your good to go for a little while more. So he changed out the alternator for a new one and re wired it to the battery but it still happens. Again he is no electrician and wires it all by diagram.
So Im probably gonna have to flat bed it to my house until we can figure out whats wrong.
Oh and the tranny is, I believe, a Muncie M22.
Old 06-02-2009, 08:04 AM   #22
*6STARS*
Member#: 205327
2006 WRX TR
1970 Camaro
My guess is it is grounding out to the chassis somewhere form a wire that had rubbed through to casing. You will know if it an M22 if you can hear major gear whine, because the m22 is a straight cut gear. Does it have a Battery shut off switch in the back lower valance somewhere?
Old 06-02-2009, 11:25 AM   #23
SaabaruMike
Member#: 113342
2014 WRX
M21's are somewhat loud too, so if you've never heard a Muncie before you might not know what to listen for. Unfortunately you will have to pull the tranny to truly identify what it is. Here is some info:
http://www.5speeds.com/muncie2.htm
SaabaruMike is offline   Reply With Quote
Old 06-07-2009, 06:34 AM   #24
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
So clean all the grounds.... Then put a meter on it and see what the drop is at the battery.
Does it run a HEi or MSD distrbutor? I'm betting it will turn out to be a bad alt. Does it have a internal or external voltage regulator? Get the GM one wire altenator, Easy to install, bolt it on, run one wire to the battery and your done. But start with a fully charged battery and do a draw test 1st. The draw test will tell you if it happening all the time or just while its running.
There would have to be a hella of a drop somewhere to eat up the current and battery when that car is running.
06STi is offline   Reply With Quote
Old 06-07-2009, 06:34 AM   #25
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
posted twice..
subi electrical guru needed desperately xxlostxx Tri-State Area Forum 16 06-11-2008 06:38 PM
Need an electric Guru In NNJ! Chandy69 Tri-State Area Forum 17 05-07-2006 10:44 PM
1970 Chevelle 70SS454LS6 Member's Car Gallery 14 03-25-2006 11:45 PM
B'ham Tech Geek openings: Lan Guru, and Comm Guru needed ShagnRS South East Region Forum 4 07-07-2004 10:02 AM
1970 Chevelle ...26 original miles... SkirtBoy Off-Topic 28 06-04-2004 02:26 PM
