Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 05-30-2009, 06:10 PM   #1
PremierWRX
Member#: 177826
06 WRX TR
Default CEL with Blinking Cruise Control Light. NEED HELP!
Ok let me give you the break down. I searched this issue already and it didn't help me. I have a 2006 WRX, car was in an accident back in march (frontend). I just barely got the car back on thursday. After driving it for a day the CEL came on and the cruise control started to blink as well. I took it back to the shop and we hooked it up to his data scanner. After running the scan it came back with no codes. He reset the ecu and i went on my way. however today after driving it the lights came again. THe car runs strong and it does not misfire or run sluggish. I really need some help.
THanks in advance,
Anthony
PremierWRX is offline   Reply With Quote
Old 05-30-2009, 06:20 PM   #2
FunSTI619
Member#: 210943
07 DOM 2.5R STI
380HP/400TQ
My Cel came on with the Cruise but it was due to aftermarket downpipe. I used a cobb stage 2 map and it got rid of it.
FunSTI619 is offline   Reply With Quote
Old 05-30-2009, 06:58 PM   #3
PremierWRX
Member#: 177826
06 WRX TR
the only mod i got is a aem cai and the exhaust from the dealer.
Old 05-30-2009, 07:03 PM   #4
justchillax808
Member#: 177287
Chapter/Region: HIIC
2006 STi
steel gray
For some reason there are some code readers that don't work on our cars. I have a 2006 STi and had the same problems, if you take your car to the dealership have them just read the code, but assuming you didn't take it there but if you did already and it still won't read IDK
justchillax808 is offline   Reply With Quote
Old 05-30-2009, 07:06 PM   #5
justchillax808
Member#: 177287
2006 STi
steel gray
Also i was able to find my own code reader at NAPA Auto Parts, I will check the brand but it was the only one I could find besides the Subi Dealership that worked
Old 05-30-2009, 07:15 PM   #6
PremierWRX
Member#: 177826
06 WRX TR
yea im going to the dealer on monday and see. What codes did it throw for you that caused cel and cruise. i wonder if it has something to do with the downpipe.
Old 05-30-2009, 07:17 PM   #7
justchillax808
Member#: 177287
2006 STi
steel gray
every code i have ever gotten has had both lights come on
Old 05-30-2009, 07:20 PM   #8
justchillax808
Member#: 177287
2006 STi
steel gray
I'm pretty sure the reason you get a cruise light is a saftey feature, because if something on your enine goes bad and causes a CEL and your in cruise control and don't notice you can do some damage so when this light comes on it disables your cruise control
Old 05-30-2009, 11:19 PM   #9
PremierWRX
Member#: 177826
06 WRX TR
what data scanner did you buy from napa. might just have to buy one
Old 05-31-2009, 10:48 AM   #10
justchillax808
Member#: 177287
2006 STi
steel gray
it is called Auto X-ray
Old 05-31-2009, 01:14 PM   #11
Weakness
Member#: 92588
2005 STi
When a CEL situation occurs, the Cruise light blinks to get your attention. The blinking is not showing a specific code (some manufacturers have blink "codes" with them but ours to not). If you know someone who has an Accessport you can get a code reading from that and go from there. - Be careful and don't push it till you get to the dealer.
Weakness is offline   Reply With Quote
Old 05-31-2009, 06:40 PM   #12
Demetry
Member#: 116220
2007 WRX Limited
were you pushing the car hard (in boost) when this happened?
Demetry is offline   Reply With Quote
Old 05-31-2009, 10:46 PM   #13
PremierWRX
Member#: 177826
06 WRX TR
no i havent been able to push it and i just got it back after two months so i have been taking it easy on it. I really haven't gotten above 4000 rpm. Just babying it. I go tomorrow so hopefully it gets worked out
Old 05-31-2009, 11:02 PM   #14
spyda23
Member#: 83758
04 sti
black
i got mine from napa too.
spyda23 is offline   Reply With Quote
Old 05-31-2009, 11:56 PM   #15
aboothby
Member#: 111994
2006 STI
WR Blue Pearl
That's happened to me about 4 times and everytime it's the tumbler valve's... lol
aboothby is offline   Reply With Quote
Old 06-03-2009, 11:34 AM   #16
08GRSTi
Member#: 179806
2008 Impreza STi
Lightning Red
Your car is most likely sensitive to the AEM intake. You posted a lean code in your other posting. Either that or it was installed incorrectly. MAF sensor properly mounted? It should give a slickt click when it is positioned exactly how it should be.
08GRSTi is offline   Reply With Quote
Old 06-08-2009, 02:53 AM   #17
Tdiggidy
Member#: 183097
2012 WRX Sedan
It might be that it has something to do with your o2 sensor. I installed an Invidia catless TBE on my 08 WRX and the same thing just happened, even though I have the mechanical CEL fix installed. Anyone have any ideas on what to do next? Make sure the CEL fix is in properly and then try and get rid of the codes? Any help would be appreciated.
Tdiggidy is offline   Reply With Quote
Old 06-08-2009, 06:54 PM   #18
justchillax808
Member#: 177287
2006 STi
steel gray
did you get this worked out??
Old 06-09-2009, 11:12 AM   #19
08GRSTi
Member#: 179806
2008 Impreza STi
Lightning Red
OP posted a crimped O2 sensor wire.
Old 06-11-2009, 12:20 AM   #20
Tdiggidy
Member#: 183097
2012 WRX Sedan
I have an OBDII at my shop so I plugged it in. Although I cant remember exactly what the code said (should have written it down), it was something to do with the o2 sensor. So I deleted the code and the CEL went away, along with the blinking cruise light on the VDC off light, so the CEL must automatically disable cruise and the VDC. I had a friend double check my install on the TBE and he said that everything was done right. I have no idea what made the CEL come on, but the TBE was on for a good 2 weeks before anything happened. So the CEL went off on monday and hasn't come back since, so I guess its all good. Thanks for the help.
CEL and blinking cruise control light calvinkw1 Warranty Issues & SOA Problems 78 02-22-2011 09:01 PM
CEL on and cruise control light flashing silversurfer307 Service & Maintenance 0 01-11-2008 09:08 PM
Blinking cruise control light? Rokudoo Electrical & Lighting 3 09-06-2006 10:13 PM
My friend's STI got a CEL and flash cruise control light. Cary Lam Vancouver Impreza Club Forum -- VIC 5 07-04-2006 02:22 PM
Can anyone help with my cruise control light blinking NlsBold Newbies & FAQs 1 12-12-2004 03:45 PM
