Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 05-31-2009, 11:42 AM   #1
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
Default Dome & Map Light problem after 02 wrx radio into 99 Legacy
Hello,
I attempted to install an 02 WRX radio into a 99 Legacy. The Legacy had a Sony xplode installed before the car was purchased used.
The previous install wasnt the prettyest, but it worked.
I took a record of what stock wires went to which of the Sony's harness.
Clipped it out, Put female bullet style connectors on all the wires, put male connectors on the wrx harnes.
Matched up the swithced and constant powers (Black/Red/yellow form Harnes, to Black/Yellow/red-blue on the car).
I wasnt getting any power, so i thought i might have the diagram of the harness mixed up in my head.
After a few swtiches of the wires, the radio turned on, but on ly with the headlights.
Another connection I made illuminated the done light. After that, no more dome light or map light.
All the other electronics seem to work OK.
I checked the fuses, all look OK. What else could I have messed up?
At the end of the day, we tried to put the xplode back in with the wires matched where they were. No power to the sony now.
CN: Did some bad wiring now map and dome lights dont work, and the previous radio doesnt work either
moogoob is offline   Reply With Quote
Old 05-31-2009, 11:48 AM   #2
Un0RiGiNaL
Member#: 189748
sony esplode!
Un0RiGiNaL is offline   Reply With Quote
Old 05-31-2009, 11:58 AM   #3
moogoob
Member#: 7101
00RS I want to fill
Yep... I esplodificated it.
I'm guessing the radio is fine, jut not sure what i did to the car.
Old 05-31-2009, 12:06 PM   #4
Un0RiGiNaL
Member#: 189748
double check your fuses--
You know you have 2 fuse boxes? im 90% sure its a fuse problem.
in my car on the left of my steering wheel theres a coin box and if you remove that theres a fusebox. I had the same issue until i figured out about that fuse box then there were 2 fuses there messed up
Old 05-31-2009, 12:10 PM   #5
moogoob
Member#: 7101
00RS I want to fill
the 99 has one under the dash. My RS has it in the coinbox like you mentioned.
Double checked the the one under the dash, and the one in the engine bay.
You're right that it sounds like a fuse problem, but i couldn't find a bad fuse. I guess a triple check wouldnt hurt.
Is there another fuse box i'm missing?
Old 09-01-2013, 11:08 AM   #6
welder
Member#: 367039
So about the jammed cds. I checked the fuse inside was fuse # 9 thats ok but what is the fuse in the engine compartment. Dont see one the could be for the cd player
welder is offline   Reply With Quote
WTB: Headliner, rear shelf, dome & map lights, rearview switch 555ideways Private 'Wanted' Classifieds 4 02-26-2006 02:25 PM
02 WRX Radio in 99 RS 99RSTurbo Car Audio, Video & Security 12 11-15-2005 11:37 PM
WRX EJ20 into 99 legacy Godmal Subaru Conversions 5 05-23-2005 12:41 AM
02 WRX radio into 04 STi webefine Car Audio, Video & Security 4 06-13-2003 09:28 AM
WRX Radio into BC Legacy Turbo Jarvis Legacy Forum 16 08-26-2002 09:50 PM
