Old 06-01-2009, 05:37 PM   #1
camelian
Member#: 165973
Default Parking Brake and Battery light appear simultaneously while driving
Greetings,
As I was driving yesterday, I noticed the battery and parking brake light come on. After trying different variables, I noticed that it only comes on when the RPMs are below 1500. When I shift in gear and drive above 1500 rpms it will go away, but as soon as I disengage the clutch and the RPMs fall below 1500, they'll come on again. Everything else was acting fine
Today I drove to Auto Zone to get a battery check and this time the ABS light came on erratically. In addition, the speedo and tach would cut out intermittently. The positive battery terminal had an excessive amount of corrision (I'm pretty sure it wasn't that bad before, but I haven't checked recently). The battery output displayed 2v and the guy said it was definitely bad. However he wasn't sure if it was just a bad battery or if it was something wrong with the alternator, causing the battery to overcharge and overheat/leak.
Any ideas on which is the problem? I don't want to replace the battery, only to have it die again due to a bad alternator. Is there a good place to get the alternator checked?
Thanks in advance for any help!
camelian is offline   Reply With Quote
Old 06-01-2009, 08:21 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Autozone should be able to check the alternator as well. The problems you are describing are consistent with a failing alternator.
Old 06-02-2009, 12:13 AM   #3
camelian
Member#: 165973
The Autozone tech said he couldn't check the alternator because the battery was bad and I need a good battery for him to test the alternator.
Old 06-02-2009, 05:41 AM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
No doubt the alternator is bad, and is most likely why the battery is low. If the battery is over 4 years old you may be better off replacing both items. Putting in a new battery when you change the alternator is a good practice.
Old 06-02-2009, 01:49 PM   #5
camelian
Member#: 165973
any idea how much a new alternator will run and a good place to have the service done? i just spent another 1500 on other maintenance recently =/
Old 06-05-2009, 11:28 AM   #6
Cougar4
Member#: 53443
Winestone
A new one may run a few hundred dollars. You could also check out any local salvage yards to see if they have any.
Parking Brake and Battery light come on as I drive WangDAT Electrical & Lighting 8 09-10-2011 05:44 PM
Brake and battery light lil WRXer 760 Normally Aspirated Powertrain 3 01-17-2007 11:41 PM
Brake and battery light issues 996c2 Car Audio, Video & Security 7 01-07-2007 12:20 AM
Brake and Battery light being wierd psychochild Electrical & Lighting 8 10-03-2006 07:00 PM
brake and battery light on with AC? sc00by25rs Service & Maintenance 4 06-02-2005 12:09 PM
