Old 06-01-2009, 06:03 PM   #1
bcware
Member#: 190724
2008 2.5i Sedan
Lightning Red
Unhappy power window no worky
08 impreza 2.5i
today i ripped apart the interior and doors to run audio cable to the trunk, and installed 6.5" speakers in the doors.
started the car up and the windows worked fine, drove to the store and shut the car off. after starting the car back up the passenger side window will go down but not up with the driver switch, then the driver switch does nothing at all. so, i reach over to the passenger switch and it will not go up, but slowly goes down. now my front passenger window is stuck all the way down.
i could not find any fuse labeled for windows so i used a tester on ONLY the mini ones and none were blown. i ripped off the door and examined the wires and saw nothing out of the ordinary.
any ideas?!
bcware is offline   Reply With Quote
Old 06-01-2009, 07:25 PM   #2
Subarudave09
Member#: 209316
14 XV
Your in Luck my friend. I Have a Silver 2.5i. Had the same problem. i Ran power cable from my trunk along with new speakers in the doors. i dont see how that cud affect it. I only noticed this in the cold weater. New Years it got stuck down at -12*. my friend pulled it up. next day i took the door panel off and lubed everything and adjusted the motor around and it works greatt. the lube i used is JiggaLoo works greatt.
Subarudave09 is offline   Reply With Quote
Old 06-01-2009, 09:15 PM   #3
bcware
Member#: 190724
2008 2.5i Sedan
Lightning Red
i just tried a known working switch, no go. i also measured voltage and the other doors are getting +/- 12 volts while the font passenger is getting nothing...
Old 06-01-2009, 09:37 PM   #4
Subarudave09
Member#: 209316
14 XV
no power to the motor? u have a warranty use it
Old 06-02-2009, 12:12 PM   #5
bcware
Member#: 190724
2008 2.5i Sedan
Lightning Red
made an appointment for tomorrow morning, but still trying to fix this myself.
i did more detective work with the multimeter and isolated the problem to a single wire.
the power window switch harness is set up like this:
12.12.00.00.GG
__.__.__.__.__
the two "12" above read 12 volts on a working window and i am guess are the two sources of power for the forward and reverse direction
the two "00" represent the wires going from the switch to the power window motor
the "GG" represents the ground
currently, the window is ONLY going up, but not down.
the multimeter shows no voltage to the LEFTMOST "12" above.
i traced this red wire through the door to a harness near the front passengers foot. i can verify that on the other side of the harness no power is coming through this wire and thus the wiring in the door itself is not faulty.
SO
where does this wire harness go from the front seat of the foot well? i can't trace the wire any further up without removing the dash, though i can see it going up above the glove box when i open it.
what could cause a loss of power to this single wire? though i ripped apart my interior, i did not remove the dash. could the problem be in the engine bay?
Old 06-02-2009, 01:55 PM   #6
Subarudave09
Member#: 209316
14 XV
i have no idea. its just sumthing the dealer shud find out
Old 06-03-2009, 07:31 PM   #7
bcware
Member#: 190724
2008 2.5i Sedan
Lightning Red
dealer looked at the car today and the power window motor was shorting out. it's being replaced under warranty this week.
Old 06-06-2009, 11:14 AM   #8
bcware
Member#: 190724
2008 2.5i Sedan
Lightning Red
the motor was replaced but this did not fix the problem. the car has to go back next week. awesome!
Old 06-06-2009, 12:44 PM   #9
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
make sure the motors are plugged in
Old 06-07-2009, 03:58 AM   #10
seascooby
Member#: 133535
06 limited - mine
ww evo 8 - hers
did you tap in to your existing speaker wires or run your own? if you ran your own did you run them through the existing factory boot? if so you may check the wiring inside the boot to see if there are exposed wires. also follow the wires from the motor up to the switch to see if there is anythign exposed.
seascooby is offline   Reply With Quote
Nick...your searchy searchy...it no worky worky -=C=- Off-Topic 7 04-09-2010 03:38 PM
Got spyware...spybot no worky no more atrodger Off-Topic 20 10-17-2008 10:15 PM
Power window- no worky!! stentorian Service & Maintenance 2 08-14-2005 05:46 PM
No power windows on my '88 GL JamiePasson 'Old School' Subaru Forum 2 12-23-2004 10:25 AM
door open=no dome light, horn no workie either White 2.5rs Electrical & Lighting 0 04-19-2004 11:33 PM
