Old 04-24-2002, 12:20 AM   #1
PRODRIVEN
Member#: 111
1999 Impreza 2.5 RS
EJtwentyfied -> '04 STi
Question Running extemely rich
My car (MY99 RS) is running extremely rich. It idles at about 500rpm then rises to 1000rpm and back down to almost zero until it revs back to about 1000k until it eventually dies if I sit at a red light to long. Black smoke also comes out the exhaust when it idles. You can even smell the gas fumes when driving behind me. I tried resetting the ecu but that didn't change anything. The only other changes recently have been a new fuel filter and pcv valve last week, but the problem only started a couple days ago. Anyone have any ideas what the problrm may be? Bad O2 sensor, MAF, burnt spark plugs (except thay are only about 2 months old)?
PRODRIVEN is offline   Reply With Quote
Old 04-24-2002, 12:51 AM   #2
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Default 500 RPM???
Are you sure you're idling at 500 RPM? That seems a little low. If you look at the first line after the zero mark, it is the "medium" sized line, it is the 500 RPM line.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 04-24-2002, 01:08 AM   #3
wistful
Member#: 745
2004 STi
Java Black Pearl
kinda sounds like an o2 sensor. I think its getting weird readings and adjustingly accordingly. *Scratching head*.. dunno what else it might be. what MY do you have?
Don
wistful is offline   Reply With Quote
Old 04-24-2002, 02:23 AM   #4
Penphoe
Member#: 269
Don
He's got a MY99 - posted right up top!
O2 Sensor? Yah, you could be right. But wouldn't an O2 sensor going bad throw a CE light?
LaterZ!
Darren!!
Old 04-24-2002, 04:04 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
LaterZ!
Darren!!
yes...sounds like the typical goofy 99 MAF...unplug it and see if the car will idle normally. if it does you found your problem.
jeremy
Old 04-24-2002, 11:34 AM   #6
PRODRIVEN
Member#: 111
1999 Impreza 2.5 RS
I was thinking o2 sensor, but that would throw a CE light which hasn't happened yet. I'll try and unplug the maf. Thanks guys.
Duncan
Old 04-24-2002, 12:09 PM   #7
imposter
Member#: 10642
95 Impreza EJ22T
An O2 sensor going bad may not always throw a CEL right away, or even at all. I would start by cleaning the MAF w/ some electronic parts cleaner available at most auto parts stores, and then go to the O2 sensor. If you could get your hands on an OBD2 scanner that would really help.
-Jim
imposter is offline   Reply With Quote
Old 04-24-2002, 12:33 PM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
9 times out of 10 a bad 02 will throw a code of some sort(usually a fuel trim code)
Jeremy
Old 05-03-2002, 03:53 PM   #9
RageHardIntoTheBendies
Member#: 1532
1999 RS, Silverthorn
www.zucru.com
Hey I have the same problem Was it the maf or the O2?
RageHardIntoTheBendies is offline   Reply With Quote
Old 05-07-2002, 03:38 PM   #10
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
What happens when you turn on the AC? When I killed my MAF (ok, there was some life lift in it but not much) I had the exact same problem, rich running, rough idling, etc. When I turned on the AC the engine revs raised to ~800 and were stable. Now, mind you I've only blown one MAF throughout the entire 76k mi on the car (although I did blow up the shortblock too and I've been running a Weapon R CAI (with custom ram tubing dropped into the fender).
Old 05-07-2002, 07:12 PM   #11
STi-Nane
Member#: 18568
2006 7.5L Turbo
TypeR Rotary with Headers
I had a similar problem with my MY01 and it turned out to be a short circuit in the Air/Fuel part of my ECU. It would idle really rough, almost to the point of stalling and sometimes the power would completely cut out during acceleration. I got terrible mileage too because the engine was running VERY rich at some times. Dealership fixed the ECU and it hasnt come back.
STi-Nane is offline   Reply With Quote
Old 05-07-2002, 07:19 PM   #12
karl_hungus
Member#: 7507
2002 WRX Wagon
This sounds almost exactly like the way my car was acting a few days ago. It turned out to be a bad front O2 sensor but I have a MY02...
I also got a CEL with 2 codes but they didn't show up right away:
Code #1 - running lean (which makes no sense since I'm usually running SUPER rich). I cleaned my exhaust tips about 10 days ago and already there is some carbon build up
Code #2 - faulty front O2
karl_hungus is offline   Reply With Quote
Dyno'ed Car Today/HELP-Running Way Rich Bigmike Bay Area Impreza Club Forum -- BAIC 11 08-04-2002 06:32 PM
Dyno'ed Car Today/HELP-Running Way Rich Bigmike Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-02-2002 11:48 PM
Can running too rich for too long throw a CEL? Bighurt1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-26-2002 05:57 PM
My car is running really rich tcs007 Normally Aspirated Powertrain 24 01-08-2002 09:22 AM
My98 runs ultra rich up top even with intake...but i fixed it GregBolby General Forum Archive 4 03-26-2001 05:06 AM
