Old 06-02-2009, 01:11 PM   #1
nylions
Member#: 179551
2003 WRX
World Rally Blue
Default TURN SIGNALS? Nothing?
okay so here is the deal my wife has a 2006 impreza wagon and recently her turn signals just stopped working you hit the lever nothing on the outside and nothing on the inside in the dash? checked the fuses and they looked good? so what could be my problem? relay? please help
nylions is offline   Reply With Quote
Old 06-02-2009, 08:15 PM   #2
Spore
Member#: 100117
2009 Impreza 2.5i
Satin White Pearl
It might be the turn indicator stalk with a loose connection (or malfunction). Have you check that yet?
Spore is offline   Reply With Quote
Old 06-02-2009, 11:33 PM   #3
nylions
Member#: 179551
2003 WRX
World Rally Blue
not yet what do i have to pull to get to that?
Old 06-03-2009, 01:27 AM   #4
nylions
Member#: 179551
2003 WRX
World Rally Blue
check it and nothing????
Old 06-03-2009, 03:19 PM   #5
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
Try cycling the hazards button.
Turn it on: do hazards flash?
Turn it off: did they go off?
Now do the turn signals work?
SonicWRX is offline   Reply With Quote
Old 06-03-2009, 08:51 PM   #6
Spore
Member#: 100117
2009 Impreza 2.5i
Satin White Pearl
I can't recall in my memories and can't seem to find my technical manual for my bugeye. But you will need to remove the steering column covers and there should be a few screws that bolts the stalk in place.
Old 06-04-2009, 12:15 AM   #7
bcware
Member#: 190724
2008 2.5i Sedan
Lightning Red
no one suggested checking the flasher? the flasher is just a relay that can eventually go bad. do the hazards work?
bcware is offline   Reply With Quote
Old 06-04-2009, 06:27 AM   #8
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
It is important to see if the flashers are working like SonicWRX and Bcware suggested. If not then the flasher needs to be replaced, if power has been verified that it is getting to the flasher first.
Cougar4 is online now   Reply With Quote
Old 06-04-2009, 05:48 PM   #9
nylions
Member#: 179551
2003 WRX
World Rally Blue
the hazards do work i cycled them and nothing. weird that the hazards will make the turn signals work but they don't work from the column?
Old 06-05-2009, 04:06 AM   #10
Cougar4
Member#: 53443
Winestone
The hazard switch switches power to the turn signal module so be sure power is getting to the brn/red wire of the turn signal module. If that is ok then maybe the turn signal module is bad.
Old 06-05-2009, 09:52 AM   #11
423894
Member#: 201438
Did you recently do any sort of electrical modifications? If so you will need to plug in a code reader and reset the codes for your car. The same thing happened to me about 2 weeks ago.
423894 is offline   Reply With Quote
Old 06-05-2009, 11:35 AM   #12
Cougar4
Member#: 53443
Winestone
Resetting the codes will have nothing to do with the blinkers working. If that happened when you cleared yours it really wasn't due to that action.
Front turn signal, brake light, and running light won't turn off Floor it Electrical & Lighting 0 06-27-2009 10:34 PM
im sure its been beatin to death but my search turned up nothing pestysti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-22-2004 05:01 PM
Turning the side marker light into a turn signal romanom Interior & Exterior Modification 3 03-20-2002 08:48 AM
('93-'01) WRX turn signal bulb size?????? BkylnWReX Impreza Forum 0 06-02-2001 05:19 PM
