Vancouver Impreza Club
Go Back   NASIOC > NASIOC Chapters > Vancouver Impreza Club Forum -- VIC > VIC Vendor Classifieds
Closed Thread
Old 06-02-2009, 01:20 PM   #1
dalesalignment&brake
Vendor Sales Rating: (47)
Member#: 173316
'13 BRZ
Default DBA rotors and Hawk brake pads in stock
DBA rotors and Hawk friction material in stock.
DBA’s Kangaroo Paw(4000 and 5000 range) delivers significantly improved braking performance under all conditions to make you safer than ever before.
The innovative Kangaroo Paw design runs cooler, is stronger, and outperforms traditional straight vane disc brake rotors.
So what makes it work so well? To answer this, let’s look at a car’s braking system. This system is critical in terms of vehicle safety and performance. Being able to stop reliably, time after time, under heavy braking conditions can mean life or death.
Every time the brakes are used massive pressure is built up through the braking system. The force your foot applies at the brake pedal is multiplied many times at the disc rotors, creating friction and extreme heat.
The extreme heat can cause disc rotors to warp, distort and in some cases fail. Traditionally, heat is removed as air flows through the rotor passing between straight ‘cooling vanes’. However, the straight vane design does not provide the ideal conditions for heat to be dissipated and tends to allow an unwanted ballooning effect.
Kangaroo Paw disc rotors will quickly remove the heat, cool the discs, and return to optimal operating temperatures ready for the next braking application – without this ballooning.
The Kangaroo Paw features 144 precisely positioned diamond and tear-drop pillars. The pillars create greater strength, reliability, and a more efficient cooling system. Greater surface area means more rapid heat dissipation.
Cool air flows in from the centre of the disc, while hot air is forced to the outside of the disc - regardless of rotational direction. The pillars provide greater strength across the disc rotor and reduce the tendency for disc distortion.
More efficient cooling improves brake pad and disc rotor life, and helps reduce brake fade.
That’s why the Kangaroo Paw system is so effective.
'05-09 STI DBA 5000 2-piece rotors(frt)-in stock
'05-09 STI DBA 4000(frt/rr for '05-07 and frt for '08-09)-in stock
'04 STI Standard slotted rotors(frt/rr)- in stock
'02-03 WRX standard slotted rotors(frt/rr)- in stock
HP Plus / Autocross
Hawk Performance’s HP Plus brake pad compound is ideal for Autocross and Track Day drivers looking for a high performance race compound that can take the heat of the track and get you home safely without having to change the pads.
HP Plus utilizes a unique Ferro-Carbon, high-tech friction material that was developed and manufactured for sport driving in autocross, Solo II and “track day” applications. The Ferro-Carbon formulation offers lower wear rates and higher torque values than other competitive materials.
Extremely high coefficient of friction makes HP Plus the perfect upgrade over stock for high performance streetcars used in autocross competition or that experience repetitive, heavy braking.
Key Features:
Extremely High Friction Output
Fade Resistant
Worthy for Autocross & Club Racing Events
Warning! Due to the dramatic friction levels produced by this product to achieve "race-level" braking, rotor wear, noise, dust, and pad life may be affected.
HPS - High Performance Street
Superior Stopping Power
HPS - High Performance Street disc brake pads are world renowned for increasing stopping power on your street legal vehicle. Increasing the performance of your vehicles braking system is easy when you choose Hawk Performance’s HPS braking compound. This unique Ferro-Carbon formula was developed for street performance using the safety and quality of Aerospace and Motorsports severe-duty friction technology.
The High Performance Street compound offers a higher coefficient of friction over stock brake pads and can provide you 20-40% more stopping power and higher resistance to brake fade than most standard replacement pads. Less fade means you’ll have a highly durable brake pad with less brake dust..
HPS Ferro-Compound Features:
Increased stopping power
High friction/torque hot or cold
Gentle on rotors
Extended pad life
Low dust
Virtually noise-free
All Hawk Performance High
Hawk HPS and HP+ for '02+ WRX and '04+ STI-in stock
Techna Fit steelbraided brake hoses in stock- WRX and STI fitment
Please PM me for pricing and availability.
__________________
[CENTER][CENTER][SIGPIC][/SIGPIC][/CENTER][B][I][COLOR="Red"]"We do pricing a little differently. Every price you see includes the shipping cost to our office(Surrey, BC), duties and exchange rate . This creates a built in cost savings, no hidden fees, and less hassles. The best part is we still have a price match guarantee!"[/COLOR][/I] [/B]
[COLOR=black]Service Center: 604 530 9160 [/COLOR] [COLOR=black]Email- [/COLOR]
[/CENTER]
dalesalignment&brake is offline
Old 06-03-2009, 09:50 PM   #2
Derek.C
Member Sales Rating: (4)
Member#: 172663
05 Blk 2.5RS
Blk 00 Civic
hey
do u guy have Hawk Performance Ceramic Pads
for 05 WRX?
Front
HAW-HB432Z.661
Rear
HAW-HB452Z.545
& how much will it be?
Derek.C is offline
Closed Thread
Stock front calipers Power Slot rear rotors and Hawk HPS pads for 2002 WRX MTL_SLVR_WRX Suspension/Brakes/Handling 1 06-22-2010 11:17 AM
DBA rotors and Hawk brake sale dalesalignment&brake VIC Vendor Classifieds 1 10-29-2009 09:59 PM
DBA 4000 front rotors and hawk hps pads smoking? subiesoho Brakes, Steering & Suspension 26 10-06-2009 04:06 AM
WTB: DBA Rotors and HAWK brakepads Henrik - Denmark Private 'Wanted' Classifieds 0 05-03-2007 02:40 PM
Racing Brake Rotors and Hawk HPS pads Psydotek SCIC Private Classifieds 9 04-29-2006 11:37 AM
