North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC > NWIC Vendor Classifieds
Old 06-02-2009, 02:53 PM   #1
InfrontAuto
Vendor Sales Rating: (23)
Member#: 181756
Default Service Specials! AMAZING PRICES! Updated!
4054 Auburn Way North
Suite 4
Auburn, WA 98002
253.236.8044
Tues-Fri 9-6, Sat 10-6
Find Us on Google!
Starting off with your car all topped off and serviced properly is vital to its life. Take advantage of some of these service specials exclusively for the NWIC and get back on the road with the peace of mind that your vehicle is in top shape! We guarantee all our services to be approved for all vehicle warranties and will meet or exceed all required regular services. We off a 12/months parts, 36/month warranty on all stock/OEM repairs.
We will not be beat! We guarantee our services to be the highest quality for the best price around! If someone has the same service advertised for less we will beat it!
Don't be fooled by gimmicks or suspiciously similar advertisements! InFront is the destination for regular maintenance and performance parts sales and installation on the south end. Since 2006, our fair pricing and the highest quality of work has spoken for itself with only YOUR word of mouth to thank for our growth. Let us leave you with the peace of mind your car is being treated properly.
Tuning:
-COBB Authorized ProTuner
-COBB AccessPort, OpenSource, AEM, Motec, Vipec, Hydra
-By appointment only
-Exclusive JohnJohnTuned Sticker
-10 years tuning Subarus
Dyno Tuning
-Mainline Chassis Dynamometer
-Complete, Real, Tuning of all load points
-Ideal for ANY car
-Wideband/boost logging
-Initial tune is $450 for upto four hours. $150/hr after.
-$99/hr touch ups.
Other Tuning Services
-Driveability, Diagnostics, Custom, Unique, O/S Hacks and Patches, Launch Control, etc.
-Car doesnt run right?
-Just bought the car?
-Got a problem?
-Got a project?
-Want something different?
-Need a basemap?
-Call or message for an appointment!
Lubricants & Fluids:
We shelf Castrol, Mobil1 and Motul products. We will gladly substitute with the brand of your choice.
Engine Oil Changes
-new OEM oil filter, battery test, check lights, full under-hood inspection & all fluids inspected
-We charge $12.50 to perform your engine oil change, plus a filter and the oil of your choice.
-Bring us your fluids & filter for $19.50
-(prices are examples for 5qts)
Conventional Oil - $42.95
Mobil 1 Synthetic EP - $59
Motul X-Cess 5w30 Synthetic - $89
Motul 300V Racing oil - $100
MT Flush - $19
AT Oil/F.diff Flush - $35
-Premium Transmission Filter (where applicable) ~$30
Rear Diff flush - $19
Coolant Flush - $79
Power Steering Flush - $79
Brake Fluid Flush - $39
-with Premium DOT3 Brake Fluid
-with ATE SuperBlue Fluid (+$10)
-with Willwood HiTemp570 Racing Fluid (+$20)
-with Includes Motul RBF-600 (+$30)
Regular Maintenance:
-*advertised prices and schedules are typical for 1990 and up Subaru models. Additional (or less) parts and/or filters may be necessary.
-All scheduled maintenance services include; computer scan, tire rotation, a full under-hood & under-car inspection of suspension, fluid lines, linkages, drive line, exhaust, brake linings, bulbs, wipers, battery, charging system, and drive belts.
-This is an underhood and undercar service. If your vehicle requires the cabin air filter to be changed additional time may be required depending on your specif model.
Add a pair of PIAA Super Silicone wipers for $39!
-Prices shown are for standard fluids in a 2010 WRX MT before taxes.
15K/45K/75K/135K service $177.41
-This would be considered severe service and calls for reducing the interval of the transmission & diff fluids in half.
-Engine Oil change,
-Transmission Oil change
-Rear Differential Oil change.
30K/90K/150K Service - $177.41
-Engine Oil change,
-Rear Differential Oil change,
-Brake Fluid flush.
-Older models with green coolant get a flush +70
60K/120K Service - $337.41
-Engine Oil change,
-Transmission Oil change,
-Coolant flush,
-Brake Fluid flush,
-Change Spark Plugs with NGK Iridium IX factory plugs.
Premium OE Timing Belt Replacement - $989.97
-The timing belt is recommended to be replaced at 105K.
-Includes a New OEM timing belt & drive belts
-new OEM water pump/gasket & a new OEM thermostat,
-new timing belt idlers (4) and tensioner assembly,
-new OEM Subaru oil pump seal, and coolant flush.
-Upgrade to Genuine STi 'pink' Heavy Duty Timing Belt (+$150)
-Substitute a Gates Racing Belt at no cost
Replace Spark Plugs - $150
-New OE Type or One step colder NGK Iridium IX Plugs (inc)
-Denso Racing plugs also available
Clutch/Transmission:
Clutch Installation, All wrx 02-14, sti 04+ - $450
-BEST price around.
-remove and replace flywheel, throwout bearing, & pilot bearing
-resurfaced flywheel (+$65 flat, $75 step)
-Fluids are additional
-Snout Service Kits (TSK) are available
-Add a short shifter, bushing kit, or motor mounts to the job
Front Axle Replacement - $175
-(all impreza, legacy, forester, upto 2010, exc STi)
-100% New ISO Aftermarket Axle
-100% Lifetime Warranty
-Make it both for $300
Performance Parts Installations:
Exhaust:
Catback Install - $50
Downpipe Install - $99
Uppipe Install - $247
Intake/Fuel:
Cold air intake install - $50
Silicone turbo inlet install - $180
-save stock inlet (+$90)
Fuel pump install - $99
-replace in tank fuel filter (+$80)
Fuel injector install
-side feed - $99
-top feed $149 and up
-conversions in stock!
-rail kits in stock!
Turbocharger:
IHI install - $180
Aftermarket Bolt-on install ~$247
-all bolt-ons except OE IHI.
-additional time may be required, (based on 2.5 hours)
Suspension:
Coilover Install and initial setup - $220
Drop Spring or Strut Install - $190
Front Sway Bar Install (turbo car ej)- $80
Front Sway Bar Install (n/a car or fb)- $130
Rear Sway Bar Install - $80
(Prices are typical, some models may require additional labor and/or parts.)
Other Services are available, including Gauges, engine rebuilding and machining, head work and porting, engine swaps, transmission rebuilding and gearsets, and many other services. There isn't really anything we cant do, or get done for you and your vehicle.
Give us a call or PM today and see what we can do for you and your Subi!
We offer a military discount of 10% off all labor!
__________________
Performance Tuning, Maintenance, Parts, Accessories, Major Repairs.
253.236.8044 - 9am-6pm Tues-Sat
InfrontAuto is offline   Reply With Quote
Old 06-02-2009, 03:39 PM   #2
JamesBernard
Member Sales Rating: (21)
Member#: 180038
IB You dont even
own a subaru!
damn those are some good prices!
JamesBernard is offline   Reply With Quote
Old 06-06-2009, 12:10 AM   #3
hiimdreh
Member Sales Rating: (9)
Member#: 170823
2002 JdmYo! Bugeye
Damn. I like these prices. I will def. come to you guys when I get coilovers sometime this year.
hiimdreh is offline   Reply With Quote
Old 06-06-2009, 12:26 AM   #4
Misanthrope789
Member Sales Rating: (5)
Member#: 174595
2005 STi
Frank Dux Edition
John's teh man
Misanthrope789 is online now   Reply With Quote
Old 06-06-2009, 03:56 AM   #5
InfrontAuto
Member#: 181756
Dont forget to call for a quote on the parts too!
__________________
Old 06-12-2009, 03:44 PM   #6
oly kenji
Member Sales Rating: (12)
Member#: 211299
2005 STi
going into 2001 gc
wow..nice prices..plus military! i will hit you guys up in a few weeks for sure.
oly kenji is offline   Reply With Quote
Old 06-12-2009, 05:16 PM   #7
kaptainkevlar
Member Sales Rating: (6)
Member#: 80109
07 spec B
uh ohhhhhhhh. $50 for a steering rack bushing install eh?
we'll be talking soon :
kaptainkevlar is offline   Reply With Quote
Old 06-12-2009, 05:33 PM   #8
InfrontAuto
Member#: 181756
Yup sir. Can i get you some Whitelines?
__________________
Old 06-12-2009, 05:41 PM   #9
12sechatch
Member Sales Rating: (87)
Member#: 132458
Okie Dokie Fine
johnjohn, you got some great prices there!
12sechatch is offline   Reply With Quote
Old 06-12-2009, 05:48 PM   #10
kaptainkevlar
Member#: 80109
07 spec B
you bet you can!
Old 06-13-2009, 02:00 PM   #11
InfrontAuto
Member#: 181756
you bet you can!
Kwel. They are $35 for the late modle style (30mm wide)
If you have an early style rack, they are 25mm wide. and are $40. (these are special order however )
__________________
Old 06-14-2009, 08:34 PM   #12
Subi_Boy06
Member Sales Rating: (1)
Member#: 208979
2006 STI
He also has group N now!! I love my tranny mount and pitch stop mount. Thanks john!! I'm gonna stop by and talk to you this week about some fluid changes
Subi_Boy06 is offline   Reply With Quote
Old 06-14-2009, 09:43 PM   #13
StayShift
Member#: 192008
2008 REO Speedwagon
Topaz Gold
Noice prices. When the Unicorn needs servicing, I'll be checking into you guys. Thanks for sharing the love!
StayShift is offline   Reply With Quote
Old 06-15-2009, 02:39 PM   #14
InfrontAuto
Member#: 181756
Yes we carry Group N mounts now... We also will be stocking a few Whiteline items as well.
__________________
Old 06-23-2009, 09:17 PM   #15
Subi_Boy06
Member#: 208979
2006 STI
Yay!! now I have all group n mounts in my car... Tranny, pitch stop, and now motor mounts.. Thanks johnjohn
Old 06-24-2009, 01:01 PM   #16
InfrontAuto
Member#: 181756
Updated with STi available parts.
__________________
Old 06-25-2009, 01:03 PM   #17
mapleWRX
Member Sales Rating: (2)
Member#: 205966
2002 Impreza WRX
john=theman! got my spark plug problems all figured out, thanks man!
mapleWRX is offline   Reply With Quote
Old 06-25-2009, 04:50 PM   #18
05stibluez
Member#: 214801
2005 WRX STI
i like your prices for the 30/60k service, is there any benefit for me to pay more $$$ and have it done at the subaru dealership? I don't want to miss anything important for my 30k.
05stibluez is offline   Reply With Quote
Old 06-25-2009, 05:01 PM   #19
InfrontAuto
Member#: 181756
They have a shuttle?
__________________
Old 06-30-2009, 11:54 AM   #20
InfrontAuto
Member#: 181756
Kerrrbump for over 15 satisfied services performed. - Sales ratings coming soon!
__________________
Old 06-30-2009, 11:54 AM   #21
InfrontAuto
Member#: 181756
whoops Duplicate!
__________________
Old 06-30-2009, 01:41 PM   #22
Misanthrope789
Member#: 174595
2005 STi
Frank Dux Edition
aww yeaaaaa girl you work that game!
Old 07-02-2009, 06:53 PM   #23
jjc1900
Member#: 19852
2002 wrx wagon
Default another satisfied customer
John did my clutch and timing belt. Did a great job and even stayed late to finish by the time he said it would be. I would certainly recomend his shop and will be using it again myself.
Jason
jjc1900 is offline   Reply With Quote
Old 07-02-2009, 10:48 PM   #24
Rabid_Machina
Member Sales Rating: (7)
Member#: 167278
2004 WRX
interested in your timing belt replacement service package, can we schedule something for the first week of august, im not due back until then?
Rabid_Machina is offline   Reply With Quote
Old 07-03-2009, 11:47 AM   #25
InfrontAuto
Member#: 181756
Absolutely. Give me a call when you want to make the appointment! I look forward to it.
__________________
All Turbo Timers in one place! Amazing Price, Amazing Brands! RallySport Direct Gauges & Electronics 0 01-26-2010 05:45 PM
Fall Service Specials W/ New Eat It Prices!!! + Rally Armor SPECIALS! EAT Motorsports NWIC Vendor Classifieds 5 01-22-2010 03:17 PM
P&L Motorsports Service / Fabrication / Labor Pricing and Specials P&L Motorsports Inc. MWSOC Vendor Classifieds 67 10-27-2009 02:34 PM
Rally Armor Local Group Buy!! + Fall Service Specials W/ New Eat It Prices!!! EAT Motorsports NWIC Vendor Classifieds 1 10-06-2009 10:37 AM
P&L Motorsports Service / Fabrication / Labor Pricing and Specials P&L Motorsports Inc. Services 0 01-30-2009 12:19 PM
