Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 06-02-2009, 05:08 PM   #1
realwomble
Member#: 49305
2002 Stg.2 WRX Wagon
Short story: installed VDO oil temp/pressure senders a long time back.
Used this http://www.egauges.com/vdo_indA.asp?PN=R7965 NPT adapter bushing, left rubber ring on, which degraded leading to a leak... big mess after 4 years.
Anyway, pulled out the temp sender yesterday, cleaned it up and re-installed without the rubber ring, with appropriate thread sealant (permatex high temperature thread selant).
Problem (idiot alert) didn't use a washer.
Torqued down to 18 lbft (spec for stock oil pressure switch), could see a few slivers of aluminium shaved off the block by the (brass?) bushing.
Thankfully the torque spec is low, so no real damage done.
Questions, before I pull out the pressure sender for the same treatment...
a - any harm in leaving this one as is without a washer?
b - should I use a washer (assume yes)
c - what material should the washer be made of? Are brass/aluminium at risk for galvanic corrosion?
Thanks.
realwomble is offline   Reply With Quote
Old 06-03-2009, 04:18 PM   #2
realwomble
Member#: 49305
Bump!
question on oil pressure sensor installation... irishhockeypimp Newbies & FAQs 5 07-31-2007 02:35 AM
EGT Sensor installation question Wiznaz Electrical & Lighting 3 12-06-2006 12:38 PM
quick alk install question-what direction should the big washer be installed? garie Brakes, Steering & Suspension 5 07-07-2005 04:48 AM
O2 sensor / down pipe install question.. firedust Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-10-2003 08:32 AM
MIL Eliminator install question - where's the rear O2 sensor? WHTWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-13-2002 04:15 AM
