Old 06-02-2009, 07:45 PM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default DIY Fender Rolling : The corrected bat method
First, I've seen a ton of crazy methods for rolling your fender. I watched all the youtube videos of some guy messing it up with a floor jack handle, to some crazy asian going at his pink honda with a ball point hammer, to some guys wedging a bat between the wheel and fender and then driving slowly.
I've even tried making my own contraption out of a skateboard wheel...
So let's get to how to do it the right way. (by right way I mean it will cost you nothing, won't leave any marks, and will look like the results from the expensive fender roller)
You will need:
-wooden baseball bat
-heat gun
-wheel wedges (or whatever stops your car from rolling away)
Steps:
- raise your car a little bit and tear off the rubber modling. Should come right off
- make sure you can barely fit the bat between the wheel and the fender
- heat the area a little where you will be working
- put the bat underneath and put a little pressure on the handle. You should see the fender edge bend up a little bit (1mm or so)
- go all the way around the bending the edge a little bit
- keep the area you're working on hot to prevent the paint from cracking.
- once you got it started, raise the car a little bit, and do it again bending the lip in another 1mm
- you can see where this is going... keep doing this until the car is all the way in the air and you got the lip bent in as far as possible.
- if you need to bend the lip in further, turn around and use the handle. Place the handle against the bent lip and put pressure on the head of the bat to push the lip towards the fender even further. At this point, it's a good idea to have the ebrake off and the car out of gear so your wheel can rotate freely. Doign this will allow you to get a nice smooth edge on the bent lip.
-just do it slowly and you'll get great result. Take your time and do a little bit at a time. It should take you at least 30min per corner if you want to do a good job.
Here are the illustrations:
A mspaint summary
getting started
a little higher
all the way up
using the handle
finished
don't mind the scratch. that came from the skateboardwheel attempt. I slipped...
Bad Noodle is offline   Reply With Quote
Old 06-02-2009, 11:51 PM   #2
Dr. Ill
Member#: 126181
02 wagonmafia
sweeeeet!
Dr. Ill is offline   Reply With Quote
Old 06-03-2009, 11:04 AM   #3
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
I ran this system for years, until I bought the Eastwood fender roller.
But even with the roller, I bring out the bat. It can sometimes get to places the roller can't.
Awesome MS paint, too.
steve is offline   Reply With Quote
Old 06-03-2009, 11:04 PM   #4
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Your the man.
Oh I think Im going to try this soon.
rexworx is offline   Reply With Quote
Old 06-04-2009, 08:19 PM   #5
Boostinbildo
Member#: 163892
05 AW STI:SOLD
Black 93 Singled tt Supra
Awesome! Bookmarked for future referance
Boostinbildo is offline   Reply With Quote
Old 06-04-2009, 11:51 PM   #6
grippy monkey
Member#: 131067
your "stance"
sucks
all your pics are now awesome red X's
grippy monkey is offline   Reply With Quote
Old 06-04-2009, 11:56 PM   #7
dudley123
Member#: 120831
PIA Purpose Built -
SEMA-FullRace/HRE/Cosw.
works for me..
dudley123 is offline   Reply With Quote
Old 06-05-2009, 12:05 AM   #8
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
They're hosted on photobucket...make sure you're allowed to view the sight
Old 06-09-2009, 04:40 PM   #9
sportcarmn
Member#: 209999
2004 STI
Silver and Black
can i use an aluminum bat? also do i have to tear out the rubber molding?
sportcarmn is offline   Reply With Quote
Old 06-09-2009, 05:52 PM   #10
ACLerok
Member#: 27915
2004 Subaru WRX STi
that came out amazing. i used to do this on hondas for a bunch of friends. super cheap and super easy. then i bought a roller.
ACLerok is offline   Reply With Quote
Old 06-10-2009, 09:45 AM   #11
David Medina
Member#: 37721
2003 WRX sedan
pearl blue
he clearly said you take off the molding...
i would stick to a wood bat.
David Medina is offline   Reply With Quote
Old 06-11-2009, 02:54 AM   #12
itaride
Member#: 207641
2005 WRX WAYGUN
ASPEN WHITE
I was reading this thread (which is awesomely done btw) and plan on doing this in the next couple of days. But something has occurred to me. Wouldnt that nice folded lip now be a trap for muck that could lead to rust? Any thoughts?
itaride is offline   Reply With Quote
Old 06-11-2009, 06:43 AM   #13
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
not any more than the current rubber molding is a trap for moisture
Old 06-11-2009, 05:55 PM   #14
Gooshin
Member#: 213441
the molding helps with preventing rocks hitting the metal which leads to paint chipping which leads to rust...
i too am curious if you can just slowly roll the fender with the molding still attached still its pretty pliable, plus makes car resale better if you can pull off a clean job.
also, "heat gun", would a decent hairdryer work too?
Gooshin is offline   Reply With Quote
Old 06-11-2009, 09:57 PM   #15
dougfeature
Member#: 196971
the paint cracks and bare metal is exposed...sand it and seal it
dougfeature is offline   Reply With Quote
Old 06-23-2009, 10:50 PM   #16
18gabtom35
Member#: 210254
2003 wrx
wr blue
thanks for the great write up, I used it last weekend and it worked great.
18gabtom35 is offline   Reply With Quote
Old 06-26-2009, 01:35 PM   #17
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
I removed my rubber molding and would suggest anybody rolling their fenders to do the same. The rubber molding (at least on my 04 STi) has metal fingers that help grip the fender. I suspect if you tried to roll the fender edge with the molding on, the metal "grippers" would tear the heck out of your paint.
bcblues is offline   Reply With Quote
Old 07-02-2009, 07:30 PM   #18
Five-seveN
Member#: 203275
2006 WRX SBR 20G
More boost to come!
Awesome write up. I just finished and took the car for a test drive and no more rubbing! I couldn't find my heat gun so i just pulled an old hair dryer and had my dad hold it for me. Now i can really test this rubber!
5.7
Five-seveN is offline   Reply With Quote
Old 07-15-2009, 09:29 PM   #19
wawawrx
Member#: 200730
'08 E92 M3
'95 GC ZJ
how's this method vs. the good ol' taped mallet method??
wawawrx is offline   Reply With Quote
Old 07-15-2009, 11:45 PM   #20
IIdiceII
Member#: 90438
has anyone pulled a fender using the bat method?
IIdiceII is offline   Reply With Quote
Old 07-18-2009, 09:01 AM   #21
Blackaxela
Member#: 145673
2002 Impreza WRX
i rolled mine last year like that.
Blackaxela is offline   Reply With Quote
Old 07-19-2009, 08:04 AM   #22
leighton1245
Member#: 210593
2002 WRX PSM
Epic tuned 300whp
I rolled mine to fit 18x9.5 grids with a mallet didnt think about something like this but will try this if i have to do it again on a diff car.
Here is what my bugeye looks like with 18x9.5 with rolled fenders.
leighton1245 is offline   Reply With Quote
Old 07-19-2009, 09:38 AM   #23
CynicX
Member#: 48199
06 WRX
Excellent post Bad Noodle. I have a set of 18x9.5 Torque's with 245's coming in and I still didnt have a plan of attack for making them fit. I'll be doing this sometime this week....
CynicX is offline   Reply With Quote
Old 07-30-2009, 10:18 PM   #24
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
Nice writeup. I think i'm gonna do this to save a few bucks.
snowflowmfg is offline   Reply With Quote
Old 10-22-2009, 09:51 AM   #25
ScoobyRS-t
Member#: 85324
2005 WRX
Freakin sweet, Hey did you just use a blow dryer to heat it up? If so for how long did you heat up the area? My 245's rub a bit when i have people in the back so i need to fix this haha.
ScoobyRS-t is offline   Reply With Quote
DIY Rear Diffuser : The Writeup Sausage Interior & Exterior Modification 193 03-17-2016 08:37 PM
fender rolling in the valley? PCSkiBum_21 Rocky Mountains Impreza Club Forum -- RMIC 25 03-03-2009 04:40 AM
need fender rolled in the hampton roads on my sti moorebl Mid Atlantic Impreza Club -- MAIC 5 02-09-2009 06:41 PM
Looking to have fenders rolled in the West Chester area Willie Dynamite Mid Atlantic Impreza Club -- MAIC 5 04-06-2007 03:50 PM
Fender Rolling in the area? moss Tri-State Area Forum 4 05-13-2006 11:13 PM
