Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 06-02-2009, 09:38 PM   #1
pogomonkey
Member#: 19132
2002 DPS tuned
black
Default morette hid problem
i just got a set of morettes for my 02 with hid. i hooked everything up and i get the hids on both sides, but only the low beam comes on the driver side and when i flip to high beams i can a sound coming from the engine bay. any ideas??
pogomonkey is offline   Reply With Quote
Old 06-02-2009, 09:50 PM   #2
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
The sound you're hearing is the high-beam relay, and assuming the kit works, check and double check your wiring, and if and only then, when you are sure your wiring is 100% accurate, post up a schematic of your HID setup, which will help us help you.
Also a good way to trouble shoot is take parts from the non-working side and swap them on the working side. Start with testing the non-working balast on the working bulb and wiring, if that works, then you know the wiring or the bulb on the other side is non-functional. Then swap the bulbs and see. And keep going down the line..
skingfreak is offline   Reply With Quote
morette hid problem pogomonkey Electrical & Lighting 5 06-26-2009 09:47 AM
Wanted pic of HID vs Morette HID?? Drews_WRX Electrical & Lighting 4 11-03-2004 02:45 AM
JDM Morette HID problems AWDball Electrical & Lighting 0 10-07-2004 02:14 PM
WTB: Morette HID KID/grill to fit Morettes 1stgearsyncro Private 'Wanted' Classifieds 1 12-08-2003 10:40 PM
GC8 Morettes HID install problem! Need Help sti2_5rs Interior & Exterior Modification 7 11-02-2001 05:49 PM
