Old 06-02-2009, 09:23 PM   #1
jikhead
Member#: 32535
2009 Nissan 370Z
Monterey Blue
Default Caution when using stock hoses on GMS Radiator
I recently installed a GMS radiator two months, which is a great piece of hardware. I used my stock hoses. Due to the size of the radiator, the upper hose has very little space to sit/reside and the middle of the hose is near the fan blade. It is apparently to close, as I found out today when coolant blew out everywhere. I had found the fan blades had slowly cut a slit into the hose. Not sure what othe hoses will be positioned better; waiting a response from GMS.
jikhead is offline   Reply With Quote
Old 06-02-2009, 09:46 PM   #2
quazimoto
Member#: 70395
I have the same radiator on my 02.I have the Samco hoses and they fit without any trimming or clearance problems.
quazimoto is offline   Reply With Quote
Old 06-02-2009, 09:51 PM   #3
MIKE DD
Member#: 106818
2003 Truck
This is a known issue w/most aftermarket radiators, they all have thicker cores. This is discussed in most install threads. All i did was cut about a half inch off of the stock hose. And as far as i know it's only the top hose that was the problem. I've had no problems w/mine for a few months now.
MIKE DD is offline   Reply With Quote
Old 06-02-2009, 10:03 PM   #4
bugeyerex02
Member#: 195967
2002 VF39'd WRX
WR Blue
i just blew 2 upper hoses in 3 days with the stock radiator. didnt know i had to trim them. do the samco's require trimming?
bugeyerex02 is offline   Reply With Quote
Old 06-02-2009, 10:06 PM   #5
MIKE DD
Member#: 106818
2003 Truck
Stock radiator? or stock hoses on aftermarket radiator?
Old 06-02-2009, 10:10 PM   #6
2.5ReallySexy
Member#: 167943
You need to cut half an inch off where it goes onto the block
2.5ReallySexy is offline   Reply With Quote
Can you use stock hoses for the APS turbo Inlet? kakarotoni Newbies & FAQs 8 06-20-2008 06:51 AM
anyone use stock lugnuts on rotas?? wrxsubaruwrx Tire & Wheel 28 12-01-2007 07:55 PM
Tire size when using JDM trans on GC8? Silver '02 REX Tire & Wheel 2 10-19-2007 11:26 AM
Part number for stock hoses on turbo... mightbewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-17-2003 06:25 PM
('93-'01) Does anyone notice that when using synthetic oil on a RS Jimmy Impreza Forum 16 05-15-2001 08:56 PM
