Old 06-03-2009, 04:59 PM   #1
gold rush
Member#: 90110
2004 wrx wagon
Default Help with slim fan
I am replacing my driver-side rad fan on my 04 WRX with a Hayden Slimline fan to accommodate room for a reverse intake intercooler pipe. I am wondering if I can tap into the wires from the existing rad fan plug to keep things simple? The new fan is only one speed and only has positive and negative wires, while the OE fan is two speed and has 4 wires.
Has anyone done this before, and if so which wires do I cut into?
gold rush is offline   Reply With Quote
Old 06-16-2009, 12:53 AM   #2
gold rush
Member#: 90110
2004 wrx wagon
OK so here's what I did: I cut the original plug off the OEM fan and tapped into the blue and green wires with the positive and the black wire with the negative.
The slim fan is now working as normal but with only one speed.
FS: New Mishimoto Aluminum Radiator, Two 12" Slim Fans, Cap, Fan Switch, 02~07WRX/STI wrx_limited Engine/Power/Exhaust 12 04-03-2009 07:44 AM
HELP with aftermarket fan wiring Rod702 Electrical & Lighting 8 03-22-2009 02:48 AM
Need some help with cooling fan + a/c fan operation and wire color codes.. caterpill Electrical & Lighting 1 01-25-2009 12:38 AM
Hayden fan controller or stock wiring for slim fans Twiztidunreal Electrical & Lighting 5 12-19-2008 12:42 PM
I Need Help With Radiator Fans ict-wrx Electrical & Lighting 5 09-06-2008 08:39 AM
