South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 06-03-2009, 05:44 PM   #1
Turbovan
Member#: 168654
2005 WRX
some form of black
Default Brake system bleed?
I just did ss brake lines all around, and now i can't get all the air out of my brake lines. Where should/can I take my car to have the entire brake system bled? I'm on the phone with power subaru now, but would prefer a cheaper option. '05 wrx
Turbovan is offline   Reply With Quote
Old 06-03-2009, 05:57 PM   #2
DroppedClutch
Member#: 52313
2005 STiOmgWtfBbq20G
2007 MS3 Black
What part of phx are you located?
DroppedClutch is offline   Reply With Quote
Old 06-03-2009, 05:58 PM   #3
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Wirelessly posted (LG Voyager: Mozilla/4.1 (compatible; MSIE 6.0; ) 400x240 LGE VX10000)
You can't do it yourself? Go to the autoparts store and buy some speed bleeders. The find out the correct bleed order from the service manual and replicate. The speedbleeder screws make it easy by not allowing air to go back into the system. It becomes a one person job. Did you let the reservoir run dry?
Old 06-04-2009, 03:24 AM   #4
gormonk
Member#: 98960
1978 brat (fo realz)
red
speed bleeders ftw. or buy a speed bleeder pump
gormonk is offline   Reply With Quote
Old 06-04-2009, 04:32 AM   #5
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
they have those little one man bleeders at autozone, just a plastic bottle with a hose.
Just keep pumping fluid into it untill the bottle fills, then pour it into the reservoir. Kepp cycling it until there's no air bubbles.
bobturismo is offline   Reply With Quote
Old 06-04-2009, 01:08 PM   #6
Evil Imports
Member#: 14732
+ 13 B8
I would be happy to help you if you wanna drive to chandler
Evil Imports is offline   Reply With Quote
Old 06-04-2009, 03:33 PM   #7
shemoves
Member#: 80663
2005 STi
I need to do my brake fluid also. Lets meet up.
shemoves is offline   Reply With Quote
Old 06-05-2009, 12:39 PM   #8
theSNOOTRS
Member#: 151508
2004 WRX
Platinum Silver
sort of off topic, but did you have any troubles disconnecting the hard brake lines from the stock rubber flexible brake line?
I just did pads and tried to do SS brake lines on my '04 rex but the connection at this point was really freakin stuck on there. stripped the bolt on the hard line side down to practically nothing. Don't know how that sucka is going to come off
theSNOOTRS is offline   Reply With Quote
Old 06-05-2009, 01:42 PM   #9
kpluiten
Member#: 120273
06 WRBWRXWGN
Mine was on there like crazy too. I started to strip it and then realized I was using the wrong tool for the job. go get some high quality flair nut wrenches and try those.
I say high quality cause I bought some Checker Parts cheapo ones and they expanded and fully stripped the nut. My solution to getting a striiped unit off? Vice grips. Lock those suckers on there and turn. Job done.
Old 06-08-2009, 01:11 PM   #10
theSNOOTRS
Member#: 151508
2004 WRX
Platinum Silver
Yeah, I tried using C-clamps for the stripped bolt. I got it so tight on there that the clamp was flexing backwards. Still nothing. I'm thinking I need some sort of machine shop to remove that mutha *****a.
Side note: any ideas how much it cost to have the hard brake lines replaced throughout the car?
Wanted GC8 2.5 rs Brake system and SVX brake System stevos758 Private 'Wanted' Classifieds 1 07-26-2006 02:03 PM
brake system bleed kits deimos Brakes, Steering & Suspension 16 05-31-2003 02:36 AM
Bleeding WRX braking system veloLexus Bay Area Impreza Club Forum -- BAIC 11 09-06-2002 08:48 PM
Fuel system bleed valve released... GavinP Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-03-2002 07:10 AM
Bleeding full brake system through ABS? Imprezer Brakes, Steering & Suspension 6 12-13-2000 12:29 AM
