Old 06-04-2009, 03:03 AM   #1
awdboostftw
Member#: 178656
14 WRX hatch
& 06 Evo IX
Default AVCS compatibility?
Long story short, I just need to know if it is possible for the AVCS to funtion with:
jdm ej207 v8 block
usdm '05 2.5L STi heads
jdm harness
jdm v7 ecu
Please, any help is appreciated, thanks!
awdboostftw is offline   Reply With Quote
Old 06-04-2009, 10:17 AM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I think you need to learn a little bit more about head to block compatibility first before AVCS.
The '05 EJ257 has a wide combustion chamber. The edges of the 2.0L block will be on the INSIDE of the combustion chamber and will more than likely be a hot spot for detonation. That right there is the FLAW in your setup. You are better going with the JDM 2.0L heads over the USDM for head flow and head to block compatibility.
Look through this thread
http://forums.nasioc.com/forums/showthread.php?t=903873
FuJi K is online now   Reply With Quote
Old 06-04-2009, 04:52 PM   #3
awdboostftw
Member#: 178656
14 WRX hatch
& 06 Evo IX
I know the 2.0 heads are the best for this setup, I was considering getting a car with the setup I mentioned and changing to the 2.0 heads but wanted to know if as it sits now, the AVCS would work because I was told by another person here that it would not work but the person selling the car assured me that it was functioning but after some debating, I think I'm going to pass on the car.
Thanks for the reply and link, I'll take some time and read through the thread
Old 06-04-2009, 09:39 PM   #4
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
it would, but i would not ever under any circumstance put sti heads on a 2.0
seanathanq83 is offline   Reply With Quote
Gas Mileage question and avcs scoobystas Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-05-2010 01:37 AM
Directions how to install AVCS heads in a non AVCS car and not use AVCS sgiord86 Built Motor Discussion 1 11-19-2009 04:31 PM
OEM AVCS cam compatibility Buggn' Out Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 12-15-2008 05:30 AM
FS, CA Hydra EMS WRX AVCS compatible SubaFastR Engine/Power/Exhaust 7 04-16-2008 12:47 PM
JDM AVCS Solenoid... is the USDM STI one compatible? InfamousDX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-23-2007 06:33 PM
