Old 06-04-2009, 07:58 AM   #1
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Default What is the newest center driveshaft that will fit 93-01 mt imprezas?
I'm having a vibration/resonating sound when letting off the gas pedal at speeds above 45mph or so. It almost seems like something is out of balance but it doesn't shake the car. The noise is coming from the center driveshaft area, I confirmed it by putting the car on a lift and getting my friend to press and release the gas pedal. The heat shield clearance is good and nothing is rubbing. It almost sounds like the noise is coming directly from the driveshaft. Has anyone had this same problem? If I need to replace it would any mt impreza/wrx driveshaft up to 06-07 fit my older drivetrain? Thanks for any help.
2slofouru is offline   Reply With Quote
Old 06-04-2009, 08:21 AM   #2
gtu89rx7
Member#: 108029
2000 2.5RS
Rally car
i think as long as it is m/t and impreza/wrx it should fit
gtu89rx7 is offline   Reply With Quote
what's the most powerful battery that will fit the oem 93-01 battery tray? 2slofouru Electrical & Lighting 1 01-23-2010 09:41 PM
What is the difference in driveshafts in 04 and 05 transmissions? Crazy650 Transmission (AT/MT) & Driveline 0 10-07-2007 01:49 PM
WTB: Any lowering springs that will fit a 01 GC8 Idahoreza Private 'Wanted' Classifieds 1 04-17-2007 10:17 PM
Whats the biggest size gauges that will fit in the OEM dash pod? mjd85la Electrical & Lighting 1 01-31-2006 08:34 PM
Whats the largest sway bar that will fit a 99 Legacy GT? MY99 2.5GT Legacy Forum 11 05-07-2001 08:51 PM
