Welcome to the North American Subaru Impreza Owners Club Monday January 26, 2015
Old 06-04-2009, 12:24 PM   #1
lucky13_tc
Member#: 203850
09 Impreza OBS
Default 08 09 impreza mystery connectors...
I have an 09 OBS and I was messing around with some sound deadening and was ripping up the floor of the front passenger side. There was a black plate that I removed that was covering this:
First of all, what is that exactly?
But my main question, on top of the plate, before I removed it, there was this literally just hanging there:
They look like they will connect to each other but I didn't try to do that not wanting to find out the repercussions.
This doesn't seem like it goes into the box shown above though. Oh well...
WHAT ARE THESE GREEN CONNECTORS THAT I SEE HERE? HELP!
Thanks!
lucky13_tc is offline   Reply With Quote
Old 06-04-2009, 12:27 PM   #2
DreadScourge
Member#: 201184
2001 WRX
I believe that's the ECU. Can anyone confirm?
DreadScourge is offline   Reply With Quote
Old 06-04-2009, 01:32 PM   #3
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
yaeh....and dont mess with any of the wiring unless you know exactly what it is and does
Old 06-04-2009, 10:00 PM   #4
danmezz
Member#: 126339
2003 WRX Wagon
in 03 impreza wrx's that green plug is used when programming the ECU. If you plug them together (at least in 03's) the car goes into test mode and all sorts of lights and relays start flashing... I'd definitely leave it unplugged
danmezz is offline   Reply With Quote
Old 06-04-2009, 11:05 PM   #5
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The box is indeed the ECU and the green plugs are for doing diagnostic testing. They should only be tied together when doing that.
Old 06-05-2009, 12:04 PM   #6
lucky13_tc
Member#: 203850
09 Impreza OBS
Well thanks for the info! I will not plan on connecting them and nor did I plan on it. I was curious if it was for some sort of upgrade that was a plug and play or something.
Old 06-05-2009, 02:14 PM   #7
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
^^^This. Same on the 04' WRX. You connect them to use an Access Port (ECU Reflash)
skingfreak is offline   Reply With Quote
08 - 09 Impreza iPod Interface (no charge capability) sin13 Car Audio, Video & Security 28 07-08-2009 02:10 PM
DIY 08-09 Impreza iPod Mod SP.XVII Interior & Exterior Modification 23 01-23-2009 02:01 AM
Interesting new 08-09 Impreza wing Magic Marker Impreza Forum 5 12-23-2008 02:48 PM
08 - 09 Impreza warranty Recall Komd1ver Warranty Issues & SOA Problems 3 11-21-2008 05:53 PM
08/09 Impreza, no hitch? RightyTighty General Community 11 09-09-2008 03:42 PM
