Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 06-04-2009, 09:47 PM   #1
foxboroxt
Member#: 73104
2003 WRX wagon stg2
2011 Outback
Default help with misfires near Plattsburgh NY?
My stepfather has a stage 2 Legacy GT that is having major misfire issues (2-4 cylinders misfiring, horrible idle after car warms up). He's tried switched between a couple different stage 2 maps, new plugs, injector cleaner, cleaned his MAF, but it hasn't improved. The local dealership wants all the stock parts back on before they look at it, and I think he's nervous about driving it 50 minutes to Moon Performance to have them take a look at it.
Does anyone have any shops they would recommend close to Plattsburgh?
Would anyone in the area be willing to help diagnose his issues, maybe with a laptop and tactrix?
Thanks,
Ben
foxboroxt is offline   Reply With Quote
Old 06-04-2009, 09:56 PM   #2
G Langa
Member#: 181396
99 Razor Scooter
Have you checked the plugs to see if they are fouled? Or have you tried switching the coilpacks to different cylinders to see if the problems follow the coilpacks? That's where I'd start.
G Langa is offline   Reply With Quote
Old 06-04-2009, 11:10 PM   #3
foxboroxt
Member#: 73104
2003 WRX wagon stg2
2011 Outback
He changed the plugs a couple times, with no improvments. The original plugs looked pretty good, the car only has 45k on it. I'm pretty sure he has moved the coils around, and that didn't help either. He went from misfires on 1 and 3, to 1 and 4, and then he's been getting codes for all four cylinders recently. He claims it will start and run OK for a while, but after a moderate accleration, he'll get misfire codes, and the car will almost stall at idle.
Old 06-05-2009, 01:57 AM   #4
bobble17
Member#: 180171
2007 stage 2 wrx
black
thats weird. i was in buffalo ny last week, and my stage 2 wrx started having the same problems. i get the code for cylinder 1 misfires. im bringing it to metricsubaru tomorrow to have em check it out. hope its not something related to my mods.
bobble17 is offline   Reply With Quote
Old 06-05-2009, 04:31 PM   #5
G Langa
Member#: 181396
99 Razor Scooter
My car did the same thing. I would get random misfire codes or all 4 cylinders misfiring at the same time. Eventually I got a code for a bad o2 sensor heater circuit. I replaced the o2 sensor and haven't had a misfire code since.
Lightened flywheel by a chance also?
Old 06-06-2009, 06:01 AM   #6
thcfortified
Member#: 159469
i was having a very similar problem after a turbo install and injectors and limp map flash from my tuner. when the car is idling, tell your stepfather to disconnect the MAF. if the idle smooths out, could be the MAF. if not, something mechanical. for me, i would disconnect the MAF, and the idle would smooth out, but it would run crazy rich. i know you said he replaced it before, so check the connections around there. and check for vacuum leaks also.
thcfortified is offline   Reply With Quote
Old 06-06-2009, 08:20 AM   #7
Paisan
Tri-State Track Instructor
Member#: 197
'14 Touareg TDI '14
BRZ http://48hrs.info
I have a similar situation on my stock car. Pulled a P21 code which is subaru specific along with a few misfires. Turns out the P21 is the coolan temp sensor. Even though my CEL is off now, (haven't had to coolant temp sensor replaced yet) it's still doing it. So that is another avenue to check.
-mike
Paisan is offline   Reply With Quote
Old 06-07-2009, 12:54 AM   #8
foxboroxt
Member#: 73104
2003 WRX wagon stg2
2011 Outback
Thanks for the suggestions. At this point, he put the stock inlet on to bring it to the dealership (which doesn't give me a lot of confidence in the dealership...). The flywheel is stock, just a light crank pulley that has been fine for years. I don't know if he has tried to disconnect the MAF while he is having his rough idle (he tried cleaning the MAF, with Carb cleaner at first, oops). My brother has a WRX, so I'll tell him to try switching the O2 sensor as well. He did try switching the coils around, and the misfires did not follow the coils. I think he may have thrown a P21 at some point, there seem to be a few more avenues to try.
Thanks,
Ben
Need help with an STI in NY BL STI Tri-State Area Forum 21 06-22-2008 11:40 PM
FS Plattsburgh NY or Katonah NY turbowrx82000 Tri-State Area Private Classifieds 11 04-10-2008 10:26 AM
Help with misfires beauhawk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-09-2007 07:18 PM
Please Help with STUPID ticket in NY area DieselClown Tri-State Area Forum 29 07-05-2004 11:28 PM
mod friendly dealer near Plattsburgh NY? andygold Tri-State Area Forum 0 04-11-2003 03:31 AM
