Notices
Old 04-24-2002, 01:49 PM   #1
STiTuner
Member#: 5778
09 135i
Jet Black
Default Q for those running Stock WRX turbos on RS's
[anti flamatory suit] ALREADY SEARCHED [/anti flamatory suit]
Just out of curiousity I was wondering what boost levels every one is running with Stock WRX turbos. Has anyone tryed to push the turbo with 8-9 psi?
I just want to see iif anyone has tryed to max it out. and what you got from it in terms Boost levels including spikes and surges.
Brad
STiTuner is offline   Reply With Quote
Old 04-24-2002, 07:37 PM   #2
inpreza kid
Member#: 3334
the stock internal wastegate in the wrx turbo bleeds around 8psi. i'm not sure how to get around this to run lower boost. i'm sure this turbo has no problem pushing 13psi.
inpreza kid is offline   Reply With Quote
Old 04-24-2002, 10:47 PM   #3
Rovah
Member#: 1375
2003 WRX Rally Car
Can't tell you what boost I'll have, but I've disabled the internal wastegate and am using a Tial external unit on my project. We hope to have it running by the end of the coming weekend.
Cheers! John
Rovah is offline   Reply With Quote
Old 04-25-2002, 03:09 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
FWIW cranking up the boost on an already undersized turbo is just going to make it trow more heat increasing your risk of detonation...i would push it harder then the factory wastegate...it'll already be strugglin.
jeremy
Old 04-25-2002, 08:17 AM   #5
Rovah
Member#: 1375
2003 WRX Rally Car
FWIW, I'm not planning on running a high amount of boost on the WRX turbo. Although WRX owners are cranking up there boost a bit without any major problems.
Cheers! John
Old 04-25-2002, 09:28 AM   #6
STiTuner
Member#: 5778
09 135i
Jet Black
but basically this turbo COULD hold about 9 psi for a short bit if If necessary too?just debating on where to put my scramble boost
also you said your wastegate was bleeding at 8 psi? to you have your bypass and its just putting that much pressure on the plate or are you using the spring from the wastegate?
Brad
Old 04-25-2002, 02:48 PM   #7
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
What the deal with the REX's producing 14 psi then if the wastegate is stepping in at 8 psi?
Graham
Graham is offline   Reply With Quote
Old 04-25-2002, 02:54 PM   #8
inpreza kid
Member#: 3334
STiTuner i don't have the turbo installed yet. still working out the up and down pipes.
the stock wrx wastegate is set to go off around 8psi. the wrx has some sort of boost controller to raise the boost level to 14psi in some gears. i think i'm probably going to run a external wastegate. too much work to get the stock internal one to work right.
Old 04-25-2002, 02:54 PM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Graham
there is a restrictor in the hose between the wastegate and boost control solenoid which allows the boost to hit 14psi.
jeremy
what do you think an MBC or EBC does??
Old 04-25-2002, 03:27 PM   #10
inpreza kid
Member#: 3334
have you guys considered getting a wrx turbo and sending it to forced performance to modify it? i'm thinking about it but not sure.
Old 04-25-2002, 10:09 PM   #11
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Don't know Jeremy, never dealt with a MBC or EBC before.
Guess I should have known that, since its so apparent that internal wastegate doesn't do all the work.
Graham
Old 04-25-2002, 10:55 PM   #12
Rovah
Member#: 1375
2003 WRX Rally Car
FWIW(although there has been another WRX turbo in RS thread), I'm using up and down pipes from www.uniquemotorsports.com. I'm disabling the stock internal wastegate and using a Tial 35mm external wastegate. Waiting for the wastegate flanges to be welded on-should have the parts by Saturday, and then I'll be back under the car.
Chad's pipes do away with swapping the stock crossmember, although with an auto tranny(like I have), the up pipe has to be lengthened horizontally about half an inch so that the down pipe doesn't hit on the tranny bellhousing.
Also, the exhaust housing of the turbo had to be rotated, requiring the use of a large pair of snap ring pliers-I had to have my mechanic do it. There are some pics on my website at www.lastditchracing.net. Not great pics, but I hope to have better ones soon.
Once I get it running, I'll post a report of boost level and driveability. I don't know if anyone actually has a WRX running in their RS yet.
Sorry if I wandered a bit off topic-didn't mean to!
Cheers! John
Old 04-25-2002, 11:28 PM   #13
FastRS
Member#: 13265
04 Sti
if you are just talking about the turbo and not the motor i dropped 16lbs the other day at the track with 104 octaine the other day. as far as 91 octaine goes i have run 13 on the street.
FastRS is offline   Reply With Quote
Old 04-26-2002, 08:43 PM   #14
STiTuner
Member#: 5778
09 135i
Jet Black
AND what have you done to you motor?
are you using a 2.5l motor?
Brad
Questions for those running fixed race seats in their WRX. mav1c Motorsports 20 06-28-2005 11:22 AM
question for those running one hiflo cat johsti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-22-2005 02:37 PM
for those running stock tires Caddy Daddy Forester Forum 13 11-13-2004 03:29 PM
Question for those running the Stoptech Stage 2 Kit STIRS Brakes, Steering & Suspension 0 11-02-2004 06:11 PM
For those running SSR Type Cs on GC8s - Help! JaiMak Brakes, Steering & Suspension 5 03-18-2002 02:24 PM
