Old 06-05-2009, 09:23 AM   #1
tylerrusso
Member#: 197035
04 Sti Wagon
06 sti black
Default little trouble with 6 speed swap into 04 wrx
i would like to say that i have read a lot of the sti swaps into wrx's but cant seem to find info on this because everyone seems to use the sti flywheel and clutch. this is the problem that i may have...
so i bought a complete 04 sti trans. with diff, controller, axles, drive shaft, fork, slave cylinder to put into my 04 wrx. i just recently bought a light weight flywheel and 3+ clutch from spec for a wrx. i know that the wrx uses a pull type slave cylinder while the sti uses a push type. but i have heard of people using there wrx clutch with a 6 speed will that work?
looking to stay cheep.
tylerrusso is offline   Reply With Quote
Old 06-05-2009, 09:27 AM   #2
ej20ajk
Member#: 113223
08 WRX NB R180
yes, 5spd clutch/flywheel combo works with the 6spd.
ej20ajk is offline   Reply With Quote
Old 06-05-2009, 09:56 AM   #3
tylerrusso
Member#: 197035
04 Sti Wagon
06 sti black
thanks a lot.
Old 06-05-2009, 10:20 AM   #4
MasterKwan
Member#: 98961
2003 WRX
04 WRX and 04 STI use the same kind of clutch. You won't be able to use the factory DCCD Controller.
Old 06-05-2009, 07:59 PM   #5
tylerrusso
Member#: 197035
04 Sti Wagon
06 sti black
thanks about the dccd controller guess that i will have to go after-market.
Old 06-05-2009, 08:35 PM   #6
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Not entirely true. The 2002-2005 5speed clutch and flywheel combos will work with all STI transmissions. They are known as the pull style because the clutch fork pulls the throwout bearing away to disengage the pressure plate.
The 2006-2007 5 speed (I don't know about the 2008-2009) will not work with the STi transmissions because they are push style. The clutch fork pushes the throwout bearing to disengage the pressure plate.
And the OEMK DCCD controller can be made to work, but the amount of swaping and wiring and general work makes it next to impossible. An aftermarket controller is your best bet.
Old 06-05-2009, 09:09 PM   #7
penusai
Member#: 102808
1995 Built EJ207 6sp
30r ***break in***
you didn't search, just admit it.
penusai is offline   Reply With Quote
Old 06-05-2009, 09:18 PM   #8
MasterKwan
Member#: 98961
2003 WRX
It's more than wiring. If you start with an 04-05. You'll need ABS system specific to those years (04 and 05 ABS is very different from each other). If you go 06+ you need ABS for that year AND a complete steering wheel setup to supply the yaw sensor.
I have factory DCCD in my swap but, I swapped EVERYTHING. Even the fuel tank and rear harness (for the Diff temp sensor).
6 speed swap into 08 WRX help. aboogabooga Transmission (AT/MT) & Driveline 21 02-15-2013 09:17 AM
6 speed swap into 09 WRX Darkmatter1986 Transmission (AT/MT) & Driveline 20 02-06-2013 04:51 PM
6 speed swap to 04 wrx wagon tylerrusso Transmission (AT/MT) & Driveline 17 07-09-2009 06:48 PM
04 6 speed swap into 02 Wrx with Sti swap drftwell Transmission (AT/MT) & Driveline 28 09-10-2008 10:22 PM
I'm doing a 6 speed swap into my wrx and I need some advice! snowcrzy Transmission (AT/MT) & Driveline 1 10-16-2006 02:54 PM
