Old 06-05-2009, 02:10 PM   #1
imprezive
Member#: 746
Default Laptop won't boot! (even in safe mode)
Sony Vaio - VGN-NR360E - Windows Vista
I'm no longer under warranty and Sony wants $49.95 just to talk to me.
It froze completely. ctrl+alt + del did nothing. I powered it off. I rebooted. It then said:
Windows failed to start. A recent hardware or sorftware change might be the cause. To fix the problem
1. Insert your Windows installation disc and restart.
2. Choose your language settings and click "Next".
3. Click "Repair your computer".
Other options:
If power was interrupted during startup, choose Start Windows Normally.
Safe Mode
Safe Mode with Networkinng
Safe Mode with Command Prompt
Last Known Good Configuration (advanced)
I've tried all the options. After I choose one, it attempts to boot and redirects me to this:
If you do not have this disc, contact your system administrator or computer manufacturer for assistance.
Flie: \Windows\system32\config\system
Status: 0xc00000e9
Info: Windows fail to load because the system registry file is missing, or corrupt.
It gives you the option to hit Enter or Esc. Either one brings you back the safe mode prompt screen.
Oh, and I don't have the original disc, of course.
Update: I managed to get to a new screen. Any reccomendations?
Choose advanced options for: Microsoft Windows Vista
Safe Mode
" With Networking
" With Command Prompt
Enable boot logging ---
Enable Low res video (640x480
Debugging mode
Disable automoatic restart on system failure
Disable Driver Signerature Enforcement
There are descriptions for all these options, but I'm sure you gurus know them.
Debuggins sounds good to me.
Help, my member number is low.
imprezive is offline   Reply With Quote
Old 06-05-2009, 02:12 PM   #2
MikeCee
Member#: 136687
15 iginla, dup...
Take out your hard drive and try to boot that way.
MikeCee is offline   Reply With Quote
Old 06-05-2009, 02:12 PM   #3
imprezive
Member#: 746
Looking on Sony website, googling, and searching Nasioc as we speak.
Old 06-05-2009, 02:12 PM   #4
infamousone
Member#: 59625
01 Integra Type R
#01-0362
Ibsuperaids
infamousone is offline   Reply With Quote
Old 06-05-2009, 02:13 PM   #5
cnw
Member#: 98395
PM r0bman for
parts discounts.
i was going to help until you took it upon yourself to point that out. cave your face in with a hammer.
cnw is offline   Reply With Quote
Old 06-05-2009, 02:14 PM   #6
Ripper
Member#: 7774
BOOM!
Ripper is offline   Reply With Quote
Old 06-05-2009, 02:14 PM   #7
saturn2wrx
Member#: 36810
Hi, I'm a Mac.
saturn2wrx is offline   Reply With Quote
Old 06-05-2009, 02:14 PM   #8
imprezive
Member#: 746
I could delete it now, but you've already quoted it.
Old 06-05-2009, 02:16 PM   #9
r0bman
Member#: 87015
Originally Posted by Ripper_AWD View Post
BOOM!
Actually, it's more of a dull thud, accompanied by cracking and dripping sounds.
r0bman is offline   Reply With Quote
Old 06-05-2009, 02:16 PM   #10
Ripper
Member#: 7774
Old 06-05-2009, 02:20 PM   #11
MacintoshMan
Member#: 160863
2009 Speed3****box
I have a few windows Machines in my house, and to solve that problem you have to take the harddrive out, plug it into another computer. Delete System32 (Under WINDOWS folder) and your set. It resets all the settings so it can start up properly. Your wireless networks might not be saved but atleast you'll be running.
MacintoshMan is offline   Reply With Quote
Old 06-05-2009, 02:23 PM   #12
WHTWRX
Member#: 18571
You normally don't change hardware on a laptop. How recently did you put Windows on it?
WHTWRX is offline   Reply With Quote
Old 06-05-2009, 02:26 PM   #13
imprezive
Member#: 746
Safe Mode
" With Networking
Debugging mode
Old 06-05-2009, 02:28 PM   #14
imprezive
Member#: 746
This could be done, with my skill level, quite an undertaking.
Haven't changed windows since I bought it like 2 years ago.
Haven't been surfing any porn or getting any viruses as far as I know. Been running good.
Old 06-05-2009, 02:38 PM   #15
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
So wait, hang on.
Are you posting from the laptop?
i_c_the_light is offline   Reply With Quote
Old 06-05-2009, 02:38 PM   #16
MacintoshMan
Member#: 160863
2009 Speed3****box
This could be done, with my skill level, quite and undertaking.
I was joking please don't do what I said, Id feel to bad when your machine would never start up ever again hahah.
Thats really not a bad fix, as long as the computer is starting up. Take out the hard drive, recover your data onto a seperate computer or flash drive. (To connect the drive to another computer you need a SATA external drive adapter, they sell them for like 10 bucks but there so usefull. Its like a socket set for a mechanic.
After you have retrieved all your files from documents and settings, reinstall windows. Then run driver magician 3.42 or newer doesnt reall matter but thats the one i use. And itll get you back up with latest drivers fixing your supposed hardwarre problem.
Goodluck!
Old 06-05-2009, 03:05 PM   #17
teiva-boy
Member#: 22825
Stick in the repair disc, or reinstall windows from scratch
teiva-boy is offline   Reply With Quote
Old 06-05-2009, 03:21 PM   #18
imprezive
Member#: 746
I don't have the repair disk....
I'm not posting from my laptop.
"Debugging" did nothing.
I have the entire hard drive backed up. I'm not worried about "wiping everything clean" just need to get it to open.
Old 06-05-2009, 03:34 PM   #19
cnw
Member#: 98395
PM r0bman for
parts discounts.
if "last known good config" doesn't work, boot from windows disk and reinstall.
Old 06-05-2009, 03:37 PM   #20
imprezive
Member#: 746
Will any window's disk work? Or does it have to be specific?
Old 06-05-2009, 03:42 PM   #21
boxered
Member#: 61884
Don't you have a recovery partition?
It'll say, "press F11 (or whatever) to start recovery when you boot
boxered is offline   Reply With Quote
Old 06-05-2009, 03:44 PM   #22
imprezive
Member#: 746
Haven't seen one. I'll tying pressing F11
Old 06-05-2009, 03:45 PM   #23
MacintoshMan
Member#: 160863
2009 Speed3****box
Ya, unless its a hacked truncated copy. Do you have a windows xp install cd? Just recover your files and reinstall windows, sometimes thats the easiest thing to do.
Old 06-05-2009, 03:46 PM   #24
boxered
Member#: 61884
Try F2 if that doesn't work
Old 06-05-2009, 10:53 PM   #25
imprezive
Member#: 746
Nada, nothing, zilch. Tried my friends Vista OS disc, didn't do anything. It is from a Gateway laptop. I don't know if that makes a difference, but it didn't do anything.
XP help: Laptop won't boot Reciprocity Off-Topic 14 02-16-2010 11:14 AM
Laptop won't boot up. Help. JEEENKINNNS Off-Topic 12 11-24-2009 10:28 AM
PC won't boot after RAM install iyzmi Off-Topic 25 08-07-2009 02:30 AM
How can I make my laptop dual boot? GooseMan Off-Topic 20 08-25-2008 12:48 PM
Asus P4P800 Deluxe board won't boot off cd rom 12voltguru Off-Topic 38 12-07-2003 11:51 AM
