Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 06-05-2009, 07:04 PM   #1
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Default Turbo Rebuild Kit
I got a turbo rebuild kit that I ended up not needing. I decided to take couple of pics, maybe this will help ofthers that are wondering if it's safe to buy a kit, or which to buy.
The one I have is labeled Kamak and I bought it through Kando Dynamic.
It's for a TD05, TD06 16G and 18G.
Here's an overview:
Following, I am comparing dimensions and shapes with parts from a known Mitsubishi Turbo.
Red Kamak, Black Mitsu, this is the compressor cover gasket.
Old 06-05-2009, 07:06 PM   #2
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Cartridge gasket. Brown Kamak.
Old 06-05-2009, 07:23 PM   #3
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Cartridge trust plate. Flat Kamak, shiny Mitsu.
They claim to have an extra heavy duty trust bearing. If you look at a drawing that shows how everything goes together, you'll see that the trust bearing is bigger with Kamak, a different style altoghether.
The washer that goes with this plate.. Kamak is the shiny. Although the flange is wider, Im measuring the "stem" thickness and diameter.
Center bearing assembly. Shiny is Kamak.
Old 06-05-2009, 07:24 PM   #4
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Old 06-05-2009, 09:19 PM   #5
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Front turbine oil rings
Old 06-05-2009, 09:26 PM   #6
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Sleeve bearings
Old 06-05-2009, 09:29 PM   #7
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Overall, these components look like they could do the job with no problems. There are two nuts as well, one direct, one reverse tread.
Old 06-05-2009, 09:43 PM   #8
quazimoto
Member#: 70395
Also what makes the thrust bearing "heavy duty" is the oil groove on the back.The Mitsubishi one doesn't have that groove.Nice pics though!I have used that same company as well (Kando Dynamics) for parts.They seem to always have pretty quality stuff.
quazimoto is offline   Reply With Quote
Old 06-05-2009, 10:58 PM   #9
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Thanks
Old 09-11-2010, 03:03 AM   #10
AWDNV
Member#: 233813
2006 Forester XT
Platinum Silver
Nice review man!
AWDNV is offline   Reply With Quote
Old 09-16-2010, 10:40 PM   #11
seth1981
Member#: 183115
2005 WRX Stg 2
San Remo Red
Awesome I was trying to find a kit. Do you happen to know where to get the turbines? preferrably oversized?
seth1981 is offline   Reply With Quote
Old 09-17-2010, 07:47 AM   #12
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Same place, Kando_dynamic. If you're moving to a TD-06, you'll need a turbine housing as well, which they sell too. You may even have the option of a TD06 7 sq cm or TD06 8 sq cm.
They have some parts that they advertise as Original, and they ship in OEM boxes. You're looking for an OEM Mitsubishi Heavy Industries item, if possible.
I think that the TD-06 may not last as long as a TD-05 though, because the turbine shaft diameter increases from TD-04 to TD-05, but not from TD-05 to TD-06. So the bigger turbine gives more torque on the same diameter shaft, putting more wear on the sleeve bearings.
If you're putting a TD-06 on a 2.0 I'd be curious to see some logs, if you want to post them.
Old 09-17-2010, 08:10 AM   #13
REX8
Member#: 24038
Want to sell it?
Edit, holy old thread batman!
Old 09-17-2010, 09:21 AM   #14
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
It's old, and I sold my kit meanwhile.
However, here's one of the 'cheap kits" they sell
http://cgi.ebay.com/Turbo-Rebuild-Ki...item3ef765f90b
Here's the "full OEM kit"
http://cgi.ebay.com/Turbo-Rebuild-Ki...item41525118b1
I'm almost sure that we have the superback, not the flat back. I say almost, because I forgot the explanation of the superback meanwhile.
I think it was the back of the compressor impeller though.
Old 01-02-2011, 12:43 PM   #15
punker39
Member#: 221065
2004 wrx
blue
any one have experience with these kits lately? thinking about doing this myself.
punker39 is offline   Reply With Quote
Old 05-14-2011, 07:13 PM   #16
Vasabond
Member#: 269548
2008 FXT 6spd
Very nice.
Exactly what I am looking for.
http://www.subaruforester.org/vbulle...ramento-89423/
http://www.subaruforester.org/vbulle...charger-93998/
also I found this video
How is your rebuild turbo?
Did you put it on?
How is everything?
Thanks
Vasabond is offline   Reply With Quote
Old 05-14-2011, 08:21 PM   #17
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
I sold my kit and bought a beand new FP built CHRA, then used Kando Dynamic housings on it.
It ran nice for a year, generating 300WHP. Then I upgraded to a Twinscroll engine and now I will convert the EVO III to twinscroll.
After 1 year, there's no additional play in the bearings, it's a good unit.
As far as the rest, if you rebuild yourself, end it by sending the unit to be bellanced by a reputable builder. And use the ppropriate oil feed banjos.
Old 05-16-2011, 07:48 PM   #18
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
^+1 on that the balancing. That and cleanliness of the rebuild are the most important factors. Kamak kits are fine and the parts are OEM made under license.
soobaviator is offline   Reply With Quote
Old 05-17-2011, 10:02 AM   #19
vien
Member#: 221538
2003 wrx/ylw wheels
darkness.................
i might have to do this as well
vien is offline   Reply With Quote
TD04 turbo rebuild kit? zavala Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 01-13-2008 10:24 PM
Turbo rebuild kits Pi7467mp Normally Aspirated with bolt-on Forced Induction Powertrain 10 10-19-2004 04:18 PM
turbo rebuild kit Imprezanator Private 'Wanted' Classifieds 1 03-06-2004 03:22 PM
Turbo rebuild kits? Hondaslayer Normally Aspirated with bolt-on Forced Induction Powertrain 2 01-25-2003 11:43 PM
Turbo rebuild kit? IMPEZER22 Normally Aspirated with bolt-on Forced Induction Powertrain 2 06-06-2002 02:28 AM
