Old 06-06-2009, 10:17 AM   #1
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
Default tdo4 tuned to 241 whp and 323 wtq
07 wrx
APS tmic
GT Spec header and uppipe with IAG EWG (Tial 38mm)
HKS flat plate dp
Walbro
Tuned by EFI Logics.. Note the relatively flat spot in the boost curve on a td04. They use a Mustang Dyno btw, and I cant remember the elevation.
Dubstar112 is offline   Reply With Quote
Old 06-06-2009, 11:20 AM   #2
StupidFastWagon
Member#: 157526
2014 335i xDrive
M Sport
holy tq batman! looks good
StupidFastWagon is offline   Reply With Quote
Old 06-06-2009, 11:38 AM   #3
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Do you think you would have seen even more torque out of this by using methanol or water injection?
jigga is offline   Reply With Quote
Old 06-06-2009, 12:02 PM   #4
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
wow, thats rediculous, i was running 22psi, wonder what kinda torque i made, love to see graphs like this
seanathanq83 is offline   Reply With Quote
Old 06-06-2009, 12:17 PM   #5
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
Yimi Tuned 296AWP/322TQ
dayum good numbers on a mustang for the stocker!
Tahoe SC is offline   Reply With Quote
Old 06-06-2009, 01:36 PM   #6
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
I dont know what meth/water does to a power curve in regards to total power and location of the power. The Td04 will probably get replaced with another td04 before i put a bigger one on. Props to EFI for making a graph that makes nasioc like a stock turbo though haha
Old 06-06-2009, 01:42 PM   #7
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
damn forums you cant delete a post?
Old 06-06-2009, 01:43 PM   #8
JSarv
Member#: 163445
l33t *******
[email protected]
2.5+ baby snail+ lots of boost = Huge torque mountain that everyone loves
JSarv is offline   Reply With Quote
Old 06-06-2009, 01:52 PM   #9
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
you forgot to add ewg into that equation too . With out that boost would've dropped faster. He was really suprised at the boost curve though.
Old 06-06-2009, 02:02 PM   #10
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
just for comparison, i think that my header and uppipe combo is actually hurting me down low but mid range it helps a small bit. Here is a 07 stock turbo catted exhaust (im catless) and a tune. Although the peak torque is higher, and the overall hp line does look smoother on mine, not sure if thats due to day to day changes aswell. regardless im stoked in the feel of the car.
http://www.efilogics.com/dyno/index....&torque=1&gb=0
Old 06-06-2009, 03:38 PM   #11
EFI Logics
Vendor
Member#: 193180
Dana,
Thanks for making the hike from Buffalo!
Your car is an animal, hope you can kill it on the AutoX. Your car is a bit lazier on the low end from the UEL Header, but it's probably nothing you will notice. When your on the AutoX, the header is typically up to temp from hard driving, and boost response should be spot on. The only way around this is to get an EL Header or ported stock manifolds from Grimmspeed.. To add to the equation, you also have the big APS TMIC, which would make things slightly laggier.
Hope you enjoy it, if you have any questions, shoot us a PM.
[email protected]
EFI Logics.com / MySpace / "New" Interactive Dyno Database
Subaru / Porsche / Mitsubishi / Ford / GM
Mustang AWD500SE - 60mph wind Dyno cell
8 Sympaug Park Road : Bethel, CT 06801
Phone: 203.748.1115
EFI Logics is offline   Reply With Quote
Old 06-06-2009, 04:37 PM   #12
pacer07
Member#: 207068
06 Doesn't matter
its not a Subie!
Have you run it at the track yet?
pacer07 is offline   Reply With Quote
Old 06-06-2009, 05:00 PM   #13
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
That all depends on the tune. Just hooking meth up doesnt do much unless you tune for it (more boost/timing).
godforbid67 is offline   Reply With Quote
Old 06-06-2009, 07:11 PM   #14
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
yes, yes, I know that.. Just curious as to whether there was more in the tuning side of things with a methanol or water injection setup. I guess that would be more a question for the tuner to answer.. I'd be curious to know.
Or perhaps the turbo is just tapped out at that level and won't do any more than it has already, regardless of detonation resistance of the fuel utilized.
Old 06-06-2009, 07:43 PM   #15
wrxSIN
Member#: 157818
did you do your
kegels today?
video of your dyno by any chance?
wrxSIN is offline   Reply With Quote
Old 06-06-2009, 07:44 PM   #16
RexTexWagon
Member#: 150987
2013 Ford Focus ST3
Ah that familiar flop on your face at 5k of the tdo4 haha.
Mine looks like that too on the road dyno chart I used, 225/245 here with intake, grimmspeed bcs, tbe and protune.
Maybe look into a bcs, that MIGHT help some, but great numbers. Im wanting to do exactly what you did, header and ewg.
RexTexWagon is offline   Reply With Quote
Old 06-06-2009, 08:01 PM   #17
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
i have a grimmspeed bcs. I think people have pushed the td04 up to 22 psi and that is peaking the efficiency out of the turbo from what I understand. That might be where the meth comes in. Id like to see what this setup does on course, I dont think 22 psi would be very tame. As it is 323 ftlbs makes a hell of a doughnut.
Old 06-06-2009, 08:06 PM   #18
08EJ25
Member#: 174022
2008 WRX
Lightning Red
Nice, Torque curve is crazy..
08EJ25 is offline   Reply With Quote
Old 06-06-2009, 08:06 PM   #19
RexTexWagon
Member#: 150987
2013 Ford Focus ST3
Ah, didnt see it in your mod list. Well the numbers look very promising, would be a fun short track car with all that crazy lowend power.
Old 06-12-2009, 10:33 PM   #20
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
I wonder what I would have done with 20+ psi of boost? I am suspecting these to be real good numbers for the amount of boost and the dyno, but if the turbo could have put up a couple more psi in the mid would it have been worth it?
BTW, I really like the numbers that evo 3 16gs are putting down.. I think that is my next turbo
Old 06-13-2009, 12:24 AM   #21
747ifly
Member#: 144865
06 wrx lmtd.
grey
My numbers are very similar with my stock turbo. 260 awhp and 326 awtq.
747ifly is offline   Reply With Quote
Old 06-13-2009, 03:42 PM   #22
2slow2nice
Member#: 198896
2006 WRX Limited
Similar to mine as well, 250hp 350tq Topspeed Tunned.Stg2, FMIC, Walbro.
2slow2nice is offline   Reply With Quote
Old 08-03-2009, 11:16 PM   #23
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
Just want to bump, any other hot headed td04's out there? Considering a few options aswell to up my self to a hta68, e3 16g .. I just want a nice torque table.. ive heard that with headers the 68 would be the way to go.
Old 08-04-2009, 12:55 AM   #24
slowgrey08
Member#: 211738
2015 STI LE
2014 SWP Forester XT
225 awhp, 265 awtq in 103 degree texas heat. Car pulls good, hp curve is completely flat, though tq of course drops off. Only mods are dowpipe and tune. Future plans are EL header, ewg, catback, ebcs, meth and possibly e85.
slowgrey08 is offline   Reply With Quote
Old 08-04-2009, 02:13 AM   #25
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
I do wonder what kind of monster tq numbers can be had from Subaru's small turbo family. A vf11, td04, or even td05 near 18lbs is where I'm targeting. 12lbs is already a bear on a vf11/WAIC and slips the clutch badly on E50. 1-3 aren't too shabby but the clutch slips in 4-5. I like the direction it's headed and just keep the boost turned down for now.
HamFist is offline   Reply With Quote
Which ACTUALLY gains WHP and WTQ on the VF39: PnP Exhaust Manifold, TGV Deletes, EWG? Red Rexx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 22 12-17-2008 09:39 PM
I-Speed USA 631.2 whp / 613.2 wtq Crawford/I-Speed Proven Power Bragging 510 10-17-2006 05:23 PM
Aftermarket Intake for 300+ whp and a custom tune? TROLL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 04-04-2006 05:22 PM
which clutch for 400+whp and 400+wtq sr55stiguy Transmission (AT/MT) & Driveline 2 11-13-2005 05:07 PM
270 whp with ECUTEK and TBE, now how do I get to 300 whp? ewright Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 27 08-21-2005 09:32 PM
