Old 06-06-2009, 01:31 PM   #1
iancka83
Member#: 164643
Default P0123 and P0223 on 08 wrx HELP CANT DRIVE!!
I was driving home last night when I threw a code and the car lost almost all acceleration. I check the codes and it was coming up with codes p0123,223 108, 2433 and a few others. after resetting the ecu and unhooking the battery and restarting it, its holding onto the p0123 and p0223 codes. I have a little bit of smoke coming out smeling strong of gas. I know the 123 and 224 codes have to do with throttle/pedal position sensor a and be high. any help on how to fix this would be great. i am now out of my warranty by 1500 miles. I have stage 2 downpipe with perrin map.
iancka83 is offline   Reply With Quote
Old 12-22-2012, 04:32 PM   #2
TeTim
Member#: 340007
2011 WRX
Reviving this thread as I'm encountering the same symptoms on my '11 WRX. The car is stock though I do have an AP setup with the 'Installed Stock' map so I can pull codes easily.
This seemed to be triggered by going over a speed bump coming out of a parking garage at normal parking lot speed. After resetting the ECU the car runs fine while parked, doesn't throw codes and will rev just fine. Pretty much as soon as I start moving the codes get thrown and the car then barely limps along. CEL and traction light are solid with a blinking cruise light. I always get P0123 and P0223 when this happens though occasionally P0108 and P2443 have been thrown as well.
I'm guessing that there's a loose connection or bad ground somewhere. I'm not an expert at where everything is in the engine bay but I've going through and poked at a bunch of the connectors that I can see and none of them seem to be loose.
I have an appointment to take the car into the dealership on Wednesday but if I could get the car running before then that'd be much better Any thoughts or fixes that I could try to get this resolved?
Thanks!
TeTim is offline   Reply With Quote
Old 12-28-2012, 12:51 AM   #3
DeM3n
Member#: 184692
2004 STI
Any updates?
DeM3n is offline   Reply With Quote
Old 12-28-2012, 10:58 AM   #4
TeTim
Member#: 340007
2011 WRX
Finally got the car into the dealership after the Christmas holiday. Turns out there was a broken\shorted wire from the main wiring harness inside the wiring loom. They repaired that wire and all is right again.
They found that with the car running the idle would surge when flexing the main wiring harness which of course lead them to find the bad wire.
Old 12-28-2012, 05:26 PM   #5
DeM3n
Member#: 184692
2004 STI
Hmm, my car is having similar issues and I'm thinking it has to do with wiring as well. Thanks for the update.
Old 07-18-2013, 02:06 PM   #6
shampy2k
Member#: 202848
05 Sti
silver with silver wheels
i am having the same issues on my 05 sit. Just did a bunch of mods to the car. Manley forged pistons rods and bearings, fp hta green, new clutch and a few other things. Was driving ok when i got it back and then started throwing the p0223 code. I also smell gas and the car just limps along. cel stays on with the cruise control flashing. What did the dealership chargew you to replace that bad wire in your car? im betting thats my problem as well.
shampy2k is offline   Reply With Quote
Old 07-20-2013, 12:38 AM   #7
shampy2k
Member#: 202848
05 Sti
Sti. Damn auto correct
Old 09-25-2015, 12:49 PM   #8
mjimmym
Member#: 430886
Subaru Stars 2008 impreza STI P0223 & P2135
I Need Help
Did A Valve Job On The Car For A P0103 Code. Problem Fixed.
After A 2 Weeks,
Driving Down The Highway The Car Throws A Cel And A Christmas Tree For A Dash Board.
I Checked The Codes Its Giving Me These Two With Smell Of Gas And Ideling Rough With The Gas Pedal Not Doing Anythiung If U Press It All The Way Or Nothing.
I Reset It Drove Fine For About 80 Miles And Then Did The Same Exact Thing.
Reset It Again Same Thing Over
Any Ideas Before I Go Get Screwed At The Dealership
Thank You...
mjimmym is offline   Reply With Quote
Super Hella Tone's installation on 08 WRX HELP! papafrito Electrical & Lighting 9 03-04-2010 10:18 PM
Need Help w/ Whiteline Roll Center Kit Install on 08 WRX Troa Brakes, Steering & Suspension 10 10-27-2009 07:55 PM
Sparco Seat Install Help On 08 Wrx TAWRX Interior & Exterior Modification 0 06-03-2009 09:54 PM
help removing rear bumper on 08 wrx volcom0749 Interior & Exterior Modification 0 02-17-2009 03:26 PM
Installed HID Kit on 08 WRX and have one problem - Help! aoisubaru Electrical & Lighting 14 09-24-2008 08:26 AM
