Old 06-06-2009, 09:59 PM   #1
Ryan314
Member#: 82989
Hybrid EJ257
Default Need some advice...
So the other day I replaced the driver's side 9007 female connector in my 02 WRX. I'm running the JDM non-HID projectors. I noticed tonight that my low beam on my driver's side is slightly less bright compared to the passenger side. My high beams look fine, both side just as bright. Is this a connection issue on my part or bulbs? The bulbs are only about 7 months old.
Ryan314 is offline   Reply With Quote
Old 06-07-2009, 04:22 PM   #2
Ryan314
Member#: 82989
Hybrid EJ257
Swapped the fuses and the bulbs and still the same problem ....
Old 06-07-2009, 06:35 PM   #3
danmezz
Member#: 126339
2003 WRX Wagon
if you swap bulbs to the other side and the "dimness" follows, then you know it's the bulb. If the same side is still dim after switching sides then it's probably a bad ground or other connection somewhere...
danmezz is offline   Reply With Quote
Old 06-08-2009, 08:59 PM   #4
Ryan314
Member#: 82989
Hybrid EJ257
Well I'm an idiot. Found out I wired it wrong!!!
Saw some wheels today and need some advice.... Tecate Tire & Wheel 2 02-26-2010 11:44 AM
building a car in stages and i have some questions/or need some advice jmanrex Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 03-11-2006 12:20 PM
I think my clutch needs replaced and I need some advice! dexterous Transmission (AT/MT) & Driveline 11 01-20-2006 10:10 PM
Just bought some seats, need some advice... legacyej22 Legacy Forum 5 12-04-2002 12:47 AM
('93-'01) Need some advice please. JNaubur Impreza Forum 3 04-19-2001 07:45 PM
