Old 04-28-2009, 02:20 AM   #1
speed_addict
Member#: 168206
Default Broke a caliper bolt... what next?
Hey all,
Looking for some insight... while having to replace the wheel studs on the driver side of my 04 STi, a caliper bolt was snapped in action as it is obvious the prev owner never put anti-seize on the bolt after installing new rotors. The thread wouldn't clean so the top hole had to be retapped with a slightly larger bolt taking the place of the old one.
Still having a warranty and experiences "clunk" issues, I took the car to the dealer. After them declining to fix the (now) obviously blown suspension, they blamed the caliper for the problem saying it was "moving" and that brembos cannot be retapped. I undersand that brembos are indeed aluminum but what the hell else is one suppose to do when a bolt breaks off? Buy a new set of calipers? Really?
The bolt gets super tight and I can't feel any real movement when braking. Also, I would think that with the bottom bolt going back in solid, play in the caliper would be impossible. Anyone have a take on this? Just wondering if new calipers should really be put on my "to buy next" list.
-Ashlee
speed_addict is offline   Reply With Quote
Old 04-28-2009, 07:54 AM   #2
copterdr
Member#: 23366
2004 WRX STI
Don't use anti seize on the bolts. I did and the temp differential from steel bolt and alum brake caused the bolt to back out then seize. I ended up buying a new Bremo. I think I could of got by by Helicoiling the brake instead but I needed to get the car back up an running.
copterdr is offline   Reply With Quote
Old 04-28-2009, 08:14 AM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
You didn't have the bolt torqued down enough. We always use anti-seize on those bolts and have never had an issue with them backing out.
OP, easiest way to fix this is to get a helicoil and put it in the caliper. If you can use a stock bolt, that is best, but since you have already drilled out the hole you may not be able to. We have helicoils in all of our Brembos as the aluminum always strips out after a while and have never had a problem with them.
Tony
Old 04-28-2009, 07:04 PM   #4
WeldingHank
Member#: 98645
2002 WRX Wagon
Tony
Heli-coil for the win.
I watched a program once about heli-coils. They were developed for the airplane industry and are designed to last longer and be stronger than the material they are replacing.
WeldingHank is offline   Reply With Quote
Old 04-28-2009, 09:21 PM   #5
prometheum
Member#: 92003
04 bicycle!
depends on what type of antiseize you use; if its graphite based and you're using it on aluminum it should be called proseize
prometheum is offline   Reply With Quote
Old 04-28-2009, 09:41 PM   #6
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
ding
ding
and
ding
Old 06-08-2009, 04:58 PM   #7
speed_addict
Member#: 168206
Thanks guys! (just got back from vacation lol) I'm gonna look into this further so I can get the beast fixed.
Broke a caliper bolt PWR_Slave Brakes, Steering & Suspension 10 04-04-2010 01:48 PM
i broke my bottom (half) whats next ?? scooby did !! Mid West Subaru Owners Club Forum -- MWSOC 20 05-31-2008 09:57 PM
Question - Broke 14mm Caliper Bolt bjy20716 Brakes, Steering & Suspension 3 03-31-2007 09:29 AM
front caliper bolt broke... suggestions? LatentWagen Brakes, Steering & Suspension 4 10-04-2005 01:52 PM
Snapped caliper bolt, what are my options? TooSlow Brakes, Steering & Suspension 6 06-14-2005 02:23 PM
