#1 |
Member#: 5960
Vehicle:FXT 11.6@118 93 oct NSX 450 whp SC'd (93 oct) |
I might need some kind of heat shield for the bottom of my bumper so my muffler doesn't melt the plastic bumper...any suggestions?
Today I installed some stiff poly-u exhaust hangers, as my 3" turbo back jiggles around too much when I go over bumps. I was able to get two of the 4 hangers swapped, and called that good, as the exhaust barely jiggles at all now. Only problem is that the exhaust tip is now 3 mm under the rear bumper...I'm not sure how hot it gets, but I'm worried about melting the plastic bumper...it used to sit almost an inch under the bumper. Do I need to be concerned about melting the bumper? Thanks.
#2 |
Member#: 13085
all i know is that my M2 turbo back started to melt my back bumper already and it doesn't look pretty.
#3 | |
Member#: 5960
Define "already" (2 weeks, 2 months, etc)I might be going back to stock hangers until I can find a good heat-shielding solution for that underside of the bumper... |
#4 |
Member#: 3389
Vehicle:07 STImpreza Satin |
Leave it! Talk about JDM style. Great look. Or rivet a sheet of alum right there, that looks great too with soot ya know. No I'm not kidding.
Ken ![]() |
#5 |
Member#: 14611
Well You might want to take a look at Motorcycle heat shields. I never had any on my bike, but from what I could tell, all they are are like a curved piece of metal (sort of wrapped partly around the actual pipe) - with a slight air gap between the shield and the pipe (I guess the gap acts like a barrier and allows cooler air to flow under it).
You might just want to get a piece of steel tubing with a little bit larger diameter than the tip (say like 3-1/8" or so) and then cut it in half - lengthen-wise, and have someone weld it to the main tip. Make sure to have them offset it atleast 1/16 from the main tip so the air gap remains. Maybe all that sounds a little too complex, and you could maybe just buy a motorcycle heat sheild and use that instead if your really concerned about it. |
#6 | |
Member#: 2916
SCIC
Vehicle:02 duburu arr exu |
#7 | |
Member#: 2916
SCIC
nqwan p.s. i could have sworn that i just replied to this thread prior to this....*sigh* i must be going crazy |
#8 | |
Miss You Mom
Oct 1940 - Feb 2008 Super Moderator Member#: 809
NESIC
Vehicle:2000 2.5 RS, '14 For 92 5MT SVX |
. Then, they were merged . All better.Brian http://www.northursalia.com http://www.imprezamods.com http://www.scoobymods.com http://www.subaruwrxparts.com |
#9 |
Member#: 12757
South East
Vehicle:2002 Impreza WRX WR Blue Pearl |
Not sure if it's still there, but I saw a bumper protector on ebay last night. Looked pretty good and it might have been an STi product....
-Scott |
#10 |
Member#: 5960
Guys, I checked again. It's not 3 mm of space, its 1 mm, maybe 1.5 at most. Basically, the bumper and top of the exhaust are nearly kissing...
I don't want some metal shield on it. I'm thinking some kind of dark, inconspicous sheet maybe 3 x 5 inches to protect that part of the bumper. Almost like a small sheet of sandpaper, but something that resists and insulates against high temps. Even better if I can paint it red like the color of my car so its unnoticable... |
#11 |
Member#: 3389
Sorry big dog, not gonna work. YOur just gonna melt that onto the bumper. Your only choice is longer hangers.
Ken |
#12 |
Member#: 5960
I know there is an acceptable solution somewhere out there...I might just have to get creative and solve it myself like I solved my Scooby rattles (10w7 power
) this past weekend.Also, |
#13 | |
Member#: 5960
#14 |
Member#: 2992
NESIC
Vehicle:02 WRX Sedan Silver |
Does anyone in FFI care whether or not you melt your bumper with your aftermarket engine?
I think not. |
#15 | |
Member#: 5960
![]() Edit: ...and kick's your sorry ass! I just read that other post when you started this crap with d00f...Don't you have anything better to do with yourself? You get the monkey.:monkey: Last edited by annointed; 04-25-2002 at 02:58 AM. |
#16 |
Member#: 66
Vehicle:2002 Impreza WRX Britney Edition |
heya,
I had a similar problem and my bumper was toasted.. had it repainted once already and its all burnt up again!. Finally I got the exhaust lowered so now its about 2cm below the bumper and no burning yet. Id recommend fixing it right away or get a head sheild fabbed up. Your bumper will burn fast! |
#17 |
Member#: 5960
Cool, thanks for the info. I decided to to have the exhaust hanger supports rewelded for the poly-u hangers.
In the meantime, it's back to stock...who cares if my exhaust jiggles left and right every time I go over a rough spot in the road... ![]() |
#18 |
Member#: 1352
Vehicle:2005 Forester XT black |
Have you already tried using zip-ties to pinch the middle of the hangers in? This will firm it up a little. Nice temporary fix...
#19 | |
Member#: 5960
I'll try it tomorrow. |
#20 |
Member#: 12757
South East
Sorry annointed, I don't have a link to the bumper protector on ebay and I also can't find it. Good luck with whatever you end up doing!
-Scott |
| Thread Tools | |
| Display Modes | |
| New Exhaust pics/Vid Big thanx to CD Muffler &Tire! | zerospreza | Texas Impreza Club Forum -- TXIC | 6 | 04-30-2010 09:14 PM |
| Prodrive Oval... need new exhaust hangers?? | subwrx23 | Newbies & FAQs | 10 | 08-23-2009 06:57 PM |
| I think I am going to melt my chair | Rice & Gravy | Off-Topic | 7 | 09-20-2006 03:44 PM |
| Whats the point of new exhaust hangers? | 03twrx | Factory 2.0L Turbo Powertrain | 3 | 02-09-2005 12:45 PM |
| Is NASIOC going to melt down?? | Hondaslayer | General Community | 13 | 01-08-2003 05:29 PM |
