Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 04-24-2002, 06:14 PM   #1
Chapel
Member#: 3496
1995 Roadmaster
Beige
Default are there any individual throttle body kits for EJ22/25s?
they would obviously be downdraught... but are they available?
Chapel is offline   Reply With Quote
Old 04-25-2002, 02:28 AM   #2
scubaracer
Member#: 4909
1992 legacy 2.2Turbo
silver sports sedan
scubaracer is offline   Reply With Quote
Old 04-25-2002, 10:50 AM   #3
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
scuba--- WHERE?
I don't see anything obvious over there.
ColinL is offline   Reply With Quote
Old 04-25-2002, 01:51 PM   #4
inpreza kid
Member#: 3334
cobb just offers a throttle body service. that means you have to send yours in to get modified. i wonder if the throttle body from the new H6 fits the MY00-01 ej25.
inpreza kid is offline   Reply With Quote
Old 04-25-2002, 02:09 PM   #5
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
I don't think you guys understand what he's asking for...
And no, I haven't seen any for the EJ25 yet. I have seen a Blitz one for a Honda B series motor though, and that thing is beautiful!
Keiho is offline   Reply With Quote
Old 04-25-2002, 02:35 PM   #6
PeterJ
Member#: 14727
2002 impreza RS
Default me too
I am also wondering about the H-6 throttle body. I'll probably go down to the dealer to take a look. It's a brand new engine design so who knows
PeterJ is offline   Reply With Quote
Old 04-25-2002, 03:29 PM   #7
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
I know *exactly* what the original poster wanted, and I know that Cobb Tuning doesn't offer one.
individual throttle bodies, or some other method of replacing the stock intake manifold, is the only way the EJ25 is ever going to make real high RPM power.
Old 04-25-2002, 04:27 PM   #8
jeffg
Member#: 2958
2001 WRX (GC8)
Yes there are kits. I found one in the UK. I seriously thought about running one, but there are some challanges with the H4 setup. Trying to get the throttle rod or line between the 2 did not look fun. But of course I dont have a machine shop and my service. If I did, it would be cake.
The company was called KVM? KMV? something like that. I got found it doing an internet search for throttle body injection.
jeffg is offline   Reply With Quote
Old 04-25-2002, 06:04 PM   #9
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
ColinL: Sorry, should've been more specific, I knew you knew what he was asking about.
Old 04-26-2002, 07:18 AM   #10
trojan9x
Member#: 3169
2001 2.5 RS: Holbert
Memorial Winner 2003
i read this article on another subaru board. it was done to an EJ22 engine though. http://pub5.ezboard.com/fthebackyard...icID=586.topic
Re: EJ22 motors Upper engine Cleaner
i found to get my car to run smooth, and i mean really smooth!
I did that throttle body mod thingy. Takes about 30 mins and is well worth it. Smoother power delivery, and smoother idle, as well as a little more get-up-and-go!
-Remove your throttle body
-Get a conical aluminium grinding drill bit/dremel bit
-Grind the lip of the throttle body where the plastic induction pipe joins on. Grind until the lip is knife edged. (ie. get rid of the flat restriction of the end of the Throttle Body)
-Then with sandpaper (beginning with rough and going to very fine) sand the inside of the throttle body and the lip until super smooth. (you can actually get a shine off mine )
Don't touch the butterfly as it is setup for smooth idle etc.
-For a little more power get a little hose connector and link up the two pipes that run the coolant water through the Throttle body, so they bypass it. (Allows the air to be a little cooler)
-Clean the Throttle Body carefully, metal shavings de get caught around the butterfly, so make sure you get it all.
-Refit Throttle Body.
While you do this reset the ECU, just for the sake of it, car will run smoother after a reset too!
you will find it runs smoother and you will have a tiny little more power.
George Liberty LX - AWD - A Wicked Doughnut
trojan9x is offline   Reply With Quote
Old 04-26-2002, 08:02 AM   #11
sohc_boy
Member#: 5859
u could try chking out twm, they do individual t/b's for hondas and i know they do a lot of weber kits so if they have manifolds for the suby they would be able to help u out. also u do know that u will probably have to go to some sort of fuel management to control individual t/b's right? also if i remember i saw some crazy intake manifolds on spo's site a long time ago made by syms for n/a subies they weren't for individual t/b's but they sure looked impressive.
sohc_boy is offline   Reply With Quote
Old 04-26-2002, 09:09 AM   #12
trojan9x
Member#: 3169
has anyone attemted or heard of anyone attempting to put a SVX throttle body on.
quoted from a website i read this about the svx throttle body
The twin throttle body flows over 900 CFM. Thatís enough for about 675HP
http://home.mgfairfax.rr.com/svx/faq/
Old 04-26-2002, 02:29 PM   #13
RageHardIntoTheBendies
Member#: 1532
1999 RS, Silverthorn
www.zucru.com
I'd say for some more N/A power it would be far easyer/Cheaper to have a new Intake manifold fabbed up. Something with shorter runners and a real intake plenum would be great.
Similar to this.
http://www.sdsefi.com/air12.html
RageHardIntoTheBendies is offline   Reply With Quote
Old 04-26-2002, 04:09 PM   #14
sohc_boy
Member#: 5859
pretty sure that's what i saw on spo's website awhile back, it was made by syms. is there a us site for syms? i have looked in the past for more info on syms on the net but didn't find to much.
Old 04-26-2002, 08:55 PM   #15
STiTuner
Member#: 5778
09 135i
Jet Black
do you want individual as in.. F1 style?
Brad
STiTuner is offline   Reply With Quote
Old 04-26-2002, 11:34 PM   #16
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
individual as in, it's a four cylinder so there should be four throttle bodies!
Old 04-26-2002, 11:38 PM   #17
STiTuner
Member#: 5778
09 135i
Jet Black
my friend did that to his 260z.. it didn't help AT ALL!!!
he had the throttle plates come straight off the head. with those velocity stacks, that were probably too small to help. My guess would be that it would actually hinder a cars performance does to the loss of intake velocity.
Brad
Old 04-27-2002, 10:26 AM   #18
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
assuming that is true, here's a few possibilities for what happened:
a) weber DCOE carburetors are extremely tuneable which is a good thing, but when you don't know what the hell you're doing it is also a very BAD thing. so maybe your friend had no clue how to set his up right. most people don't!
b) velocity stacks operate over a narrow RPM range. if your friend had velocity stacks tuned for 6000-8000 rpm and he still had the stock 2.6L cams, pistons, etc. then guess why this isn't a good match. then again, even if he had a complete matched setup see A) above.
Old 04-28-2002, 12:21 AM   #19
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Sooooo, they hinder performance, but F1 (the showcase for the most advanced internal combustion engine technology) uses them because....???
Pat Olsen
'97 Legacy 2.5GT sedan
Old 05-12-2002, 05:54 PM   #20
tonytiger
Member#: 3844
1993 Legacy 1.8
There is this one thread open which has got ITI. IT's here . It has also couple of pictures.
However, what I'd like to know is where the TBs get their air from? Will the air be sucked under the hood - hot air?
Another thing about the ITI is the short lenght which directs the resonance pulses operating RPM range very high up. This way a fairly low revved engine will suffer from it.
In F1 these both factors are gone, because of the engine location design.
How can you make ITI? What parts do you need? It doesn't look so bad
I probably figure out some more questions, but above is a few for now...
Thank you.
tony
tonytiger is offline   Reply With Quote
Old 05-12-2002, 08:42 PM   #21
Section 8
Member#: 821
You can take air from under the hood, or preferrably fabricate air boxes around each bank and supply them both with cold air from a scoop somewhere.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 05-13-2002, 08:10 AM   #22
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Ram air has been discussed before but I feel the only way to build an effective ram air intake is to take the stock hood scoop off and design one specifically for catching air. (Section8 I wasn't trying to say you were suggesting ram air).
I still don't believe you would see massive gains from a direct throttle body fed pannel style filter box that is open to a custom birdcatcher style scoop. However it seems like the engine would run smoother and flow better specifically at high speed high rpm driving. There again though if the throttle body chops that air up and the intake manifold chokes your probably not going to be much better off.
MY99 2.5GT is offline   Reply With Quote
Are there any Piano Black interior kits out there? StiChiara Interior & Exterior Modification 20 03-21-2006 04:55 PM
Are there any good CVS plug ins for Visual Studio 2003? catass Off-Topic 14 11-01-2005 01:28 PM
Walther P22 are there any others u would recomend for around... GregBolby Off-Topic 26 09-30-2005 10:06 PM
who's got individual throttle bodies? darioc Normally Aspirated Powertrain 21 05-24-2004 08:05 AM
Are there any good body kits for the wrx besides the c-west kit. faceplate Interior & Exterior Modification 1 06-08-2002 01:34 AM
