Old 06-07-2009, 08:40 PM   #1
nikiter
Member#: 190942
2006 Impreza WRX
JDM STi 6 Speed
Default STi Intercooler for '06 WRX
How are STi intercoolers better than WRX's? Simply by size I assume?
If i do get one. Do i need different Y pipes and such? Does my car needs to be retuned?
Please tell me more about this mod for a Stage 1(for now) wrx.
Just more info.
Thank you
nikiter is offline   Reply With Quote
Old 06-07-2009, 08:58 PM   #2
gte123v
Member#: 114481
2006 Sti
larger volume and larger surface area. You'll need a new y pipe and mounting brackets. You shouldn't need a new tune, but you'll notice a slight lag b/c of the larger volume. To take the full advantage you should also get the sti splitter that's part of the hood scoop.
gte123v is offline   Reply With Quote
Old 06-07-2009, 09:07 PM   #3
nikiter
Member#: 190942
2006 Impreza WRX
JDM STi 6 Speed
Hmm lag is no good.
Old 06-07-2009, 09:13 PM   #4
Ysidro
Member#: 197418
07 WRX Ltd
The Mighty Evo;Fun CRZ
Just more info.
Thank you
Yes, simply by size and also the design sometime. I've seen an ebay tmic that are bigger but doesnt cool as well.
If you're going to use the sti tmic on wrx with the td04 turbo, I think the y-pipe is going to be a bit short. Get a 90 degree silicone tube thats alittle longer, and you'll be good.
Yeah, you'll probably need a retune to see a gain. Adding a bigger tmic will probably drop your psi. Just get a vf39 along with it, and you'll be good.
goodluck
Ysidro is offline   Reply With Quote
Old 06-07-2009, 09:15 PM   #5
moriswrx
Member#: 149784
2007 WRX stage ?
Plus the bellows:gasket...
moriswrx is offline   Reply With Quote
Old 06-07-2009, 09:16 PM   #6
nikiter
Member#: 190942
2006 Impreza WRX
JDM STi 6 Speed
so basicly i need sti turbo or bigger
Old 06-07-2009, 09:21 PM   #7
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
^ no you don't.
I have a JDM STi IC with a stock tdo4. No need for bigger turbo unless you want more power. USDM sti IC should be plug&play for you since you have an 06 with DBW.
rexman2002 is offline   Reply With Quote
Old 06-07-2009, 09:27 PM   #8
nikiter
Member#: 190942
2006 Impreza WRX
JDM STi 6 Speed
Originally Posted by rexman2002 View Post
^ no you don't.
so are you getting more lag?
like what is the purpose of this I/C on wrx?
Old 06-07-2009, 09:33 PM   #9
gte123v
Member#: 114481
2006 Sti
^ no you don't.
what does getting a larger IC have anything to do with the DBW? I don't think the 06 wrx had DBW, only the STIs had it.
Old 06-07-2009, 09:40 PM   #10
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
no....
Old 06-07-2009, 09:56 PM   #11
06WHTWRX
Member#: 173690
2005 Ferd
F-TeenThousand
Everything 05+ I believe has DBW. My 06 does.
You don't need to retune.
The purpose of a larger intercooler is to reduce the temperature of the compressed air entering your engine. The lower the temp, the more dense the air, and thus more power.
You will see a bigger gain from this with a larger turbo, but it still is an improvement with the td04.
You will not see a noticeable increase in lag.
I believe you will need some sort of silicon elbow to make this work with the wrx turbo, someone more knowledgeable can chime in here on fitment. Or use the search button, it's there for a reason.
06WHTWRX is offline   Reply With Quote
Old 06-07-2009, 09:59 PM   #12
bfrecon1391
Member#: 184327
06 OBP Limited
HB SPEED proTuned
Have a 07 TMIC on my 06 no brackets or hardware needed just about 20 min to put it all together and enjoy! lag.... its a td04 lag??? hahhahahaha
VF43 June 12th FTW!
bfrecon1391 is offline   Reply With Quote
Old 09-10-2009, 08:45 AM   #13
nikiter
Member#: 190942
2006 Impreza WRX
JDM STi 6 Speed
Is this true that I need a different elbow to make it work with td04? OR whatever comes with STi top mount will directly bolt on?
Old 09-10-2009, 08:57 AM   #14
Ryan314
Member#: 82989
Hybrid EJ257
You don't need new mounting brackets.
Just make sure you get one that includes the y pipe and you should be set.
Ryan314 is offline   Reply With Quote
Old 09-10-2009, 06:14 PM   #15
sd_wagon_07
Member#: 139820
2007 WRX Wagon Ltd
Clark Turner Tuned
You'll just need a longer 90 degree elbow (2" ID). You will need to trim maybe 1/8th of an inch off each end to get it to fit properly.
Use this for reference: http://stylinmotors.com/images/usdmsticopy.JPG
I would recommend getting it from http://siliconeintakes.com/. They also have t-bolt clamps if you need better clamps as well.
You will also need a new splitter and bellows to take full advantage of the bigger intercooler.
sd_wagon_07 is offline   Reply With Quote
Old 09-10-2009, 06:18 PM   #16
tekfoc
Member#: 21392
2016 C63S AMG MB
Iridium /MB C300 4MATIC
wrong thread sorry
tekfoc is offline   Reply With Quote
Old 09-10-2009, 06:18 PM   #17
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
If you are not going to tune for it, I'd say it's a useless upgrade. And by tuning, I do not mean an off-the-shelf Stage 1 map that wasn't designed for an upgraded TMIC.
Honestly, there are better things to spend your money on right now than a TMIC, like a downpipe and then flash to Stage2. The difference will be far more dramatic.
Audiosavvy is offline   Reply With Quote
Old 09-12-2009, 01:15 AM   #18
05wrx09
Member#: 204111
2005 WRX
Unless you're already Stage 2+ like me
I got a super deal on a local STi TMIC so I went with it. I was hesitant because I kept on hearing the STi TMIC has like a 3psi pressure drop. But it'll probably be fine for my TD04 and soon VF43. Now, if I could just get a longer TB/IC coupler I would be in business.
My Y-Pipe looks like this though:
With the red part in stock silver of course. Weird.... I keep seeing all these hack Y pipe setups.... I'm thinking that setup with work just fine with my WRX minus the coupler I need.
05wrx09 is offline   Reply With Quote
Old 09-14-2009, 09:54 AM   #19
nikiter
Member#: 190942
2006 Impreza WRX
JDM STi 6 Speed
already stage 2 tuned.....as soon as i put the top mount i will be going back for a road tune
Old 09-14-2009, 10:01 AM   #20
nikiter
Member#: 190942
2006 Impreza WRX
JDM STi 6 Speed
thanks for the link....very nice
is this the elbow that I need?
http://www.siliconeintakes.com/produ...ebc4d1b2d501f1
Old 09-14-2009, 04:59 PM   #21
BENSREX
Member#: 39718
2007 WRX
The STi TMIC will not be sufficient when you start getting upwards of 280whp/300wtq. It's just too small and gets too hot on a day that is 70 degrees+. If you don't plan on making more power than that, I say go for it. If you do plan on more power... just get a bigger TMIC from day one and save yourself some $$.
And yes, the above link is the elbow you need. I used scissors to cut it to the necessary size. Easy install/fix.
BENSREX is offline   Reply With Quote
Old 09-14-2009, 05:01 PM   #22
nikiter
Member#: 190942
2006 Impreza WRX
JDM STi 6 Speed
Thanks....The number you mentioned is where i wanna be maybe even a bit less.....gotta save the tranny lol
Old 09-15-2009, 08:24 AM   #23
nikiter
Member#: 190942
2006 Impreza WRX
JDM STi 6 Speed
So i ordered that 2"- 90 degree angle and some clamps from them.
Old 09-15-2009, 10:39 AM   #24
burtonrider3889
Member#: 163519
2016 GT4
Do I need the elbow on a 05 Wrx if I'm attaching it to a EVO III 16G or will the STI elbow fit? I would just need the bigger intercooler to manifold pipe right? Not the elbow though?
burtonrider3889 is offline   Reply With Quote
Old 09-15-2009, 11:30 AM   #25
ChrisM623
Member#: 114573
Slow Miata
I added an STI I/C to my previous 06 WRX. I didn't notice any more or less lag.
You WILL need a new 90 degree elbow thing. The OEM STI one doesn't reach far enough. I forgot where I picked up a new one but it was through some digging on the forum and I found it.
Good luck!
ChrisM623 is offline   Reply With Quote
WTB STi Intercooler for my WRX Anthony Prez VIC Private Classifieds 1 01-31-2009 06:49 PM
Feeler: WTT STi interior for '06+ WRX Interior Thommyboy12183 Interior & Exterior Modification 6 03-28-2007 11:37 PM
WTT- '06 Aspen White STI trunk for '06 WRX trunk with small wing Cam2 Tri-State Area Private Classifieds 4 03-29-2006 01:17 AM
STi interior for '06 WRX Leather? sgtpeper Rocky Mountains Impreza Club Forum -- RMIC 1 10-11-2005 12:49 AM
STI intercooler for my WRX WolfInSheepsCLothing General Community 1 09-11-2004 10:37 PM
