Old 06-07-2009, 08:44 PM   #1
IARS2.5
Member#: 213111
Default Cluster Color change problems
I am doing the interior color change using Trunkmonkey's tutorial. Everything has been smooth up until now. I am sanded clean and my needles still work, however I seem to be burning out LEDs like nobody's business. I put the LEDs into the twist lock bases, fire up the gauges and the LED's are burning out. I have got a couple to work but it has been like pulling teeth. I ordered 20 of:
http://cgi.ebay.com/ebaymotors/10pcs...lenotsupported
out of the 20, looks like 18 have burned out. Are these just garbage bulbs or is something else wrong. Whats more, the bulbs that do work start out on, albeit dim, but they do start, and then as i adjust the brightness to be brighter, they grow dimmer. I have no clue what is going on, any and all advice will be greatly appreciated. Thanks.
Car is an 2004 2.5rs btw, my hvac and odometer both work properly with the dimmer.
IARS2.5 is offline   Reply With Quote
Old 06-18-2009, 10:26 PM   #2
gonzosquirrel
Member#: 30543
2002 WRB WRX
& 1986 VFR700F
IMO....junk led bulbs....possibly manufactured without resistors....
try these http://autolumination.com/74.htm
gonzosquirrel is offline   Reply With Quote
Old 06-18-2009, 10:36 PM   #3
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Either junk bulbs or you've managed to mix up positive and negative.
XanRules is offline   Reply With Quote
Old 06-19-2009, 02:49 AM   #4
rbimdxe
Member#: 214102
2000 WRX Evo 4
Yellow
^^ LED's obey polarity, and will only work when connected correctly. ie; positive to anode, negative to cathode.
Sounds like low-quality bulbs or incorrect resistance.
That said, I can't understand why the dim when you 'increase' the brightness. Are you sure you don't start with the dimmer switch 'bright' and they are just very dim?
Perhaps you might look into LED's with a higher MCD output, or re-calculating the resistance?
rbimdxe is offline   Reply With Quote
IL/WI: Cluster Color Change Stero1D Mid West Subaru Owners Club Forum -- MWSOC 0 10-08-2007 08:10 PM
gauge cluster color change question imprezaBlue Interior & Exterior Modification 5 02-05-2007 05:57 PM
05 STI gauge cluster color change Kuj_05STI Electrical & Lighting 2 11-13-2006 10:48 PM
Interior cluster color changed to red! tomkang2000 Interior & Exterior Modification 5 04-16-2006 02:38 AM
RED Cluster Color Change mxg286 Tri-State Area Forum 2 09-08-2004 06:12 PM
