Old 06-08-2009, 01:35 AM   #1
@NT
Member#: 207366
Default 2009 WRX clicking noise after coilovers
So I just installed my coilovers Friday night. The car looks great and I haven't had any issues rubbing. However, I went get some frozen yogurt tonight and had my first experience with a steep driveway.
I took it at an angle to avoid scraping, but I heard a weird clicking noise. I know the car was teeter-tottering at one point, could it be the diff? CV's? Could it be from one wheel spinning freely as the other wheels are under load? Has anyone had any experience with this?
From what I've found searching, people have had this problem when turning to full lock. I don't hear this noise when turning full lock, only when I was going up and down that driveway. Is this normal or should I be concerned? The clicking went away right after I got off the driveway.
@NT is offline   Reply With Quote
Old 09-16-2009, 11:13 PM   #2
WRrexu
Member#: 217061
2009 Wrx
VDC? if a tire looses traction ( lifts off ground ) it will engauge the electronic LSD and it makes a clicking noise . ive experienced this in other cars . never subis. just a thought....
WRrexu is offline   Reply With Quote
Old 09-16-2009, 11:28 PM   #3
viper74656
Member#: 84758
'04 WRB WRX
^^^ I thought VDC only applied the brakes to limit wheel slip and that the diffs are open, not electronic LSD?
viper74656 is offline   Reply With Quote
Old 09-16-2009, 11:33 PM   #4
WRrexu
Member#: 217061
2009 Wrx
oh no . it acts as LSD . limiting wheelspin is when traction control is on . when the tires spin it just throttles down ( because of drive by wire it can control it )
Old 09-16-2009, 11:39 PM   #5
tuskenraider
Member#: 65699
15 WRX
WR Blue
VDC does not act like an LSD in that LSD's control power distribution to the wheels, they don't limit it like VDC does.
tuskenraider is offline   Reply With Quote
Old 09-17-2009, 12:14 AM   #6
WRrexu
Member#: 217061
2009 Wrx
explain drifting with open differentials when all it does is limit wheelspin then .
i wanna hear this
Old 09-17-2009, 11:36 AM   #7
tuskenraider
Member#: 65699
15 WRX
WR Blue
Less wheelspin with open diffs, yes, I'm sure it limits wheelspin to one wheel, don't see the correlation. VDC is a stability contol system overall, not an ELSD.
http://www.scoobymods.com/attachment...0&d=1084717289
http://www.scoobymods.com/attachment...3&d=1084717315
Old 09-17-2009, 02:28 PM   #8
joshuaj
Member#: 216249
2011 STI Sedan
Applying braking force to a spinning wheel with an open diff transfers the power to the other wheel... I don't know enough about VDC to comment on whether this is what's happening though.. FWIW
joshuaj is offline   Reply With Quote
Old 09-17-2009, 04:19 PM   #9
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Er, i can drift my car quite easily. I don't have VDC or any LSD's worth mentioning.
sniper1rfa is offline   Reply With Quote
Old 09-17-2009, 06:55 PM   #10
tuskenraider
Member#: 65699
15 WRX
WR Blue
I autox and have forgotten to shut the VDC off many times......it doesn't transfer squat, even if that's the intention.
Old 09-17-2009, 08:53 PM   #11
MNGman
Member#: 218964
2009 WRX
Rally Blue
Back to the clicking... did you install swaybars with endlinks? Friend had same issue with endlinks binding a touch after install of coilovers and a slightly lowered ride height. adjust endlinks clicking went away.
MNGman is offline   Reply With Quote
Old 09-17-2009, 10:37 PM   #12
joshuaj
Member#: 216249
2011 STI Sedan
I track my 09 WRX quite a bit and the VDC is poo on the track. I put a piece of white tape on my cluster that says VDC to remind me to shut it off . Anyway like I said I really don't know enough about VDC to say if it should transfer power in that manner or not. Just saying that you can transfer torque to the other side of an open diff using brake control on the spinning wheel..
help clicking noise after brembo brake pad install? MRSTI28 Brakes, Steering & Suspension 11 05-19-2008 11:04 AM
Clicking noise after installing SS braided brake lines Thaddy Brakes, Steering & Suspension 6 04-18-2008 11:44 AM
AHHH! Clicking noise after installing winter rims and tires!! Soulofdarkness Newbies & FAQs 7 11-24-2005 10:40 AM
Clicking noise after gauge install tlbwrx Electrical & Lighting 3 08-27-2004 07:46 PM
Clicking noise after gearshift jr34596 Normally Aspirated Powertrain 0 01-23-2002 12:06 AM
