South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 06-08-2009, 04:55 AM   #1
ShaggyTR
Member#: 197159
89 SR20 30r Coupe
Aspen White 05 STi
Default white smoke from turbo?
so tonight i got off work and went to my car as usual and started it up no problem.
my friend wanted to see my new coilovers so i showed him and ran it not hard but you know for like 2 minutes and when i pulled back into the lot i noticed white smoke coming from my turbo area....
it was pretty heavy but after i shut off the car is slowed down and went away.
i drove home and when i got home only a little smoke i mean minimal was coming from the turbo area under the heat shield
so my question is why would it be doing this?
ShaggyTR is offline   Reply With Quote
Old 06-08-2009, 08:28 AM   #2
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Take the heat shield off and see. Check for any leaks. Also, you may want to remove your IC and check the inside of the piping for heavy oil.
blkscooby is offline   Reply With Quote
Old 06-08-2009, 10:33 AM   #3
skinner2013
Member#: 177792
07 wrx
black
It happened to me see if your axle booth has a split in it you could the grease from the booth getting on you exhaust and burning off
skinner2013 is offline   Reply With Quote
Old 06-08-2009, 10:41 AM   #4
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Agreed. Remove the heat sheild and look for oil or grease. The oil might be leaking from the turbo oil supply line (sometimes they weep). The grease might be from your CV boot tearing and flinging grease on the downpipe.
Old 06-08-2009, 10:56 AM   #5
SaabaruMike
Member#: 113342
2014 WRX
^^My inner CV boot ripped and flung grease onto my DP. Check that first before removing anything. Otherwise, you probably have a leak in the return line.
SaabaruMike is offline   Reply With Quote
Old 06-08-2009, 12:41 PM   #6
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
correct me if I am wrong, but white smoke = coolant not oil?
v8eaterWRX is offline   Reply With Quote
Old 06-08-2009, 12:44 PM   #7
r0bman
Member#: 87015
That was my first reaction. I'd check for coolant leaking somewhere and making its way to the turbo / DP.
r0bman is offline   Reply With Quote
Old 06-08-2009, 01:29 PM   #8
blkscooby
Member#: 44422
2009 G8 GT
Either that or Cheech and Chong are hanging out under the heat shield.
Old 06-08-2009, 01:50 PM   #9
kpluiten
Member#: 120273
06 WRBWRXWGN
I think if it's as small of a smoke trail as he says it is, blue smoke and white smoke might be easily mistaken for one another. PB blaster is an oil yet still makes a whiteish smoke when it burns off the turbo housing and downpipe.
Old 06-08-2009, 02:57 PM   #10
SaabaruMike
Member#: 113342
2014 WRX
Good call Brock, but I was thinking that maybe the smoke really wasn't white. I had a coolant line leak on my turbo and there was not a bunch of smoke. It just stunk like coolant. Looking at the inner CV boot is a good first step. When mine smoked it was not all that blue and could have been mistaked for white.
Old 06-08-2009, 04:15 PM   #11
ShaggyTR
Member#: 197159
89 SR20 30r Coupe
Aspen White 05 STi
so after looking in the daylight, i noticed that my CV boot right under the dp/turbo area has a huge rip in it.
anyone know how to fix this by that i mean has anyone ever had to do this before
Old 06-08-2009, 04:37 PM   #12
ShaggyTR
Member#: 197159
89 SR20 30r Coupe
Aspen White 05 STi
its ripped by the very front of it where it connects to that green piece. unless its supposed to pull off from that but i dont think it is cause there is grease all over that area...
Puffs of white smoke from turbo heat shield MMBOOST Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 01-17-2012 03:17 PM
Alot of WHITE SMOKE from hood/turbo simprezl25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-14-2007 03:12 PM
White smoke from legacy turbo Arctic Assassian Pre-2002 Factory Turbo Powertrain 9 05-02-2006 01:47 PM
White smoke from turbo felixman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-23-2006 02:00 AM
Intermittent White-ish smoke from turbo??? boulder wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-30-2002 11:06 AM
