Old 04-24-2002, 08:09 PM   #1
SevenStyle
Member#: 17945
2002 Impreza RS
Question RS Turbo questions
I just have some overall questions. From some of the posts on this board I get the impression that turbocharging the RS is bad news, especially if you don't know what you're doing (like me).
But what's a good way to get to know what you're doing?
Also what does a project like this cost?
SevenStyle is offline   Reply With Quote
Old 04-24-2002, 08:20 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
It's not bad news as long as you prepare yourself and educate yourself.
Start here and make sure your read the entire thead.
Things to figure out before picking parts for your turbo project
Costs vary, but if you buy a kit (FAT, Vishnu, Ludespeed) your looking at atleast $3000, plus extras.
kastle is offline   Reply With Quote
Old 04-24-2002, 10:47 PM   #3
bensonwrx
Member#: 6904
AWD R35, XE30, V37
BO, AS, MW
Yup, I was a newbie is the turbo subject...wait, I am still a newbie.
Anyway, I learned what components are needed depending on the planned setup; then I further researched on each component I needed, and found out what do they do, and why do I need them.
It ain't too hard, but time consuming to learn them well
Like kastle said, purchasing a kit will cost quite a lot of money; so be prepared to invest fair amount of cash into the project.
If you buy my partial kit, though, that will save you a lot comparing with the a kit
-Benson (Another MY98 Owner)
bensonwrx is offline   Reply With Quote
Old 04-25-2002, 03:41 AM   #4
Imprezha
Member#: 6818
2002 NSX
2010 Gen Cpe,2016 Outback
If your looking for the cheapest reliable setup, it will cost you under $3000. You could get a kit from ludespeed. I think the stage one is like $2350 and get a J&s for $500 and a egt gauge gauge for $150 if you shop around at ebay. You won't have to worry about detonation with the safeguard and just run low boost.
Imprezha is offline   Reply With Quote
Old 04-25-2002, 03:48 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
excuse me?? you ALWAYS have to worry about detonation...especially if you are relying on stock fuel injectors.
j
Old 04-25-2002, 02:02 PM   #6
Imprezha
Member#: 6818
2002 NSX
With proper setup and safety electronics
you can have a reliable setup by running low boost. Is that better? Geez!
Imprezha
Old 04-25-2002, 02:06 PM   #7
rupteur7000
Member#: 11585
02 2.5RS
i am also not a p****
ludespeed's kits now come with the parallel rail fuel mod.
rupteur7000 is offline   Reply With Quote
Old 04-25-2002, 08:58 PM   #8
STiTuner
Member#: 5778
09 135i
Jet Black
or you can hack up your own for 5 bucks
Brad
STiTuner is offline   Reply With Quote
Old 04-25-2002, 11:41 PM   #9
hayscoob
Member#: 4544
2004 STi Aspen White
Bone Stock for now
With proper setup and safety electronics you can have a reliable setup by running low boost. Is that better? Geez!
I was running just a meezly 4.4 lbs of boost and baked my engine, although, I may have spiked. The KEY to success is engine management. Any other option is just a half assed rig job to stretch the time till it does break someting. It's just not right. You will always have to worry. You will always run the risk of failure. It happens without warning too. And trust me, it's just not worth the risk. It's damn expensive to rebuild the engine. If I had purchased full on PEMS it would have cost me less in the long run. WAY less. Hind sight is 20/20. Full on PEMS is the "right" way to do it. Period. There is no other reliable long term solution.
Paul...
hayscoob is offline   Reply With Quote
Old 04-26-2002, 06:01 AM   #10
HubbieScooby
Member#: 7088
Super Slow
hey paul
my kit is in and so far i have yet to hear knocking or detination....i have the RRFPR tuned all the way to max so im running super rich....i am not taking any chances so i have my ITC going in as soon as i get it from the mail....did you tune your fuel?? why were you spiking...i can barely get it over 3lbs. right now....my EGT is kindda low...only 800-1300....so what do you think?? thanx
hugh
HubbieScooby is offline   Reply With Quote
Old 04-26-2002, 06:11 AM   #11
RawCode
Member#: 3115
2002 Impreza 2.5RS
I think your getting a new o2 sensor soon and your MPG is trash...
But hey, it is reliable right? So it is all good!
RawCode
RawCode is offline   Reply With Quote
Old 04-26-2002, 09:24 PM   #12
HubbieScooby
Member#: 7088
Super Slow
RawCode
MPG?? oh yeah thats trash all right...how bout 12-15 MPG...i filled my gas tank about 4 days ago and almost running empty....and i live on an island!! the O2 sensors won't affect the engine like cutting off fuel right?? i would think if the O2 reads waaaayy too rich that it will start leaning it out...hopefully not...thanx
hugh
Old 04-26-2002, 10:02 PM   #13
hayscoob
Member#: 4544
Bone Stock for now
Hugh,
No pinging? Great. Keep it rich till you get your timing control goodies in. I did have the RRFPR up. I can't think of any good reason why I smoked #4. This is the first cylinder to get fuel too. I don't know for sure if I was spiking or not. I am running the 4.4 lbs spring. It may be relaxing prematurely due to heat or something. Who knows. These small little bugs are the reason one should install a stand alone ECU. As far as your EGTs go, I had similar values on my meter. I never got over 1350. Never. However, I bunged #3 for the probe and not #4. Go figure.... Did you get the 4.4 lbs spring with your kit? You should be closer to 4.5 to 5 lbs with that spring. Perhaps your meter is off a few pounds or so. Is it an Auto Meter gauge? Scootr has an Auto Meter gauge and his is off too. He is running around 6 lbs and his meter reads only 3 lbs. You may indeed be running more boost than you realise. Also, you have a higher humidity factor on the Islands too. This also may play a role in why you have not pinged yet. Just a thought....
Paul...
Old 04-27-2002, 09:45 AM   #14
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Hugh, how many cats do you have in your exhaust? O2 sensors can very well determine how rich/lean you are running, especially if they aren't connected or if there broken. The purpose of the O2's is to monitor the cats and make sure they are running efficiently, and also to keep your A/F ratio stoich.
Graham
Graham is offline   Reply With Quote
Old 04-27-2002, 11:10 PM   #15
HubbieScooby
Member#: 7088
Super Slow
Graham
hey Graham
as far as i know there's only one cat and it came with my turbo kit...my air/fuel gauge isn't working correctly....my installer didn't know where to tap the wires....the first o2 sensors is better for the gauge right?? thanx
hugh
2000 rs turboed questions.. SubieGenius Normally Aspirated with bolt-on Forced Induction Powertrain 6 09-23-2008 10:46 PM
RS Turbo questions 02scoobyboi Normally Aspirated with bolt-on Forced Induction Powertrain 25 12-16-2003 04:27 AM
Questions on gear ratios for RS turbo... Digital_Boy Normally Aspirated Powertrain 6 01-10-2001 11:47 PM
Minnam 2.5 RS Turbo Question! VA_ACCORD Technical Forum Archive 9 08-05-2000 01:39 AM
2.5 RS Turbo Kits Interest/questions/feedback Thug General Forum Archive 8 05-19-2000 01:01 PM
