Old 06-08-2009, 01:14 PM   #1
jamesssf
Member#: 205598
2006 Sti
Default GT3076R 2006 STi 370 WHP
I was looking for suggestions on what to do next or any feedback on the tune.
Perrin Complete Rotated Turbo Kit (* Relocated MAF to intake pipe)
• Perrin's Equal length header
• Perrin's Rotated uppipe
• Downpipe
• Intake and other turbo kit parts
• Perrin's FMIC
• Perrin's High flow fuel rails
• 816CC injectors
• EBCS boost solenoid
• Signature Series Recirc BOV
• Blow-thru Boost tube
AEM Wide band Gauge
Agency Power lightweight crank pulley
Agency Power Short Shifter
Agency Power Pitch Stop
Apexi Turbo Timer
Cobb AccessPORT v.2
Defi BF Turbo Boost Gauge
Defi BF Oil Pressure Gauge
Defi BF Exhaust Temp Gauge
Defi Control Unit II
Defi 3x Meter Hood
Exedy Stage 1 Clutch
Gramlights 57 Maximum
Greddy Oil Block Adapter
Greddy Oil Catch Can
JIC Titanium Turbo Back
NGK Spark Plugs
Perrin Performance Positive Steering Response System
Perrin Front Sway Bar End Links
Perrin Rear End Links
Perrin Rear Adjustable Sway Bar
SPT Motor and Trans Mount
Tein Front And Rear Strut Bar
Tein Flex Coilovers
Tein Electronic Damping Force Controller
Walbro 225LPH Fuel Pump and Kit
92 Octane Tune by Tim Bailey
jamesssf is offline   Reply With Quote
Old 06-08-2009, 01:23 PM   #2
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
367 is stellar on a low reading mustang, especially for 92 octane. Get the aquamist kit, you may be able to see 390-400 and have a real balls to the wall set-up. This car should be fast on meth!
STi Mikey is offline   Reply With Quote
Old 06-08-2009, 01:32 PM   #3
DirtyBanana
Member#: 211802
2003 Wrx
Sonic Yellow
Agreed, its a low reading dyno. Should be a really fast street car. Get that bad boy on the track and show us some good traps
DirtyBanana is offline   Reply With Quote
Old 06-08-2009, 01:39 PM   #4
my94saleen
Member#: 97791
2006 sti
wr blue
nice set up.i made 386whp and 375lb tq (stock is 201whp,200lb tq) at A.M.R. with the atp gt3076r bolt-on turbo on 93 oct.they said the car had a lot more left but still running stock block.your set up looks nice and prob a pretty conservitive tune also.nicey nice!
my94saleen is offline   Reply With Quote
Old 06-08-2009, 01:44 PM   #5
AlxSti
Member#: 94615
|'06 STi 341/356|
Delaware REALTOR®
whats the boost and taper look like?
AlxSti is offline   Reply With Quote
Old 06-08-2009, 04:30 PM   #6
jamesssf
Member#: 205598
2006 Sti
Isn't that the green line?
Old 06-08-2009, 04:55 PM   #7
AlxSti
Member#: 94615
|'06 STi 341/356|
Delaware REALTOR®
um.. im not sure. are you boosting almost 18 psi? the numbers on the right Y axis i thought were just continued from you a/f ratio black line.
Old 06-08-2009, 05:12 PM   #8
jamesssf
Member#: 205598
2006 Sti
Well I have 15, 18, 20, and 22-23 PSI maps. At the bottom of the dyno sheet you can see the boost numbers. It's the green line
Old 06-08-2009, 05:13 PM   #9
jamesssf
Member#: 205598
2006 Sti
So a low dyno? How much different would it read on another dyno?
Old 06-08-2009, 05:56 PM   #10
Tuner1
Member#: 86751
Nice numbers and nice tune. Do you have a .82 or .63?
Tuner1 is offline   Reply With Quote
Old 06-08-2009, 08:55 PM   #11
jamesssf
Member#: 205598
2006 Sti
Thanks. .63
Old 06-08-2009, 09:06 PM   #12
nation1979
Member#: 192914
06 sti
importimageracing is #1
reading your parts list i see you have some AP crap on there-why with such nice mods?and the injectors,ditch them for some DW850.i have yet to see a pair of perrins new or used flow any better than 4% within each other and the spray pattern sucks
nation1979 is offline   Reply With Quote
Old 06-09-2009, 02:01 AM   #13
STimo
Member#: 110273
450 whp 30R STI
[email protected]
^If ur looking on feedback for what to do next (as in make more power) many people have said that the .82 exhaust housing for the 30R (which is what i run) is well worth the slightly slower spool time for the better top end that it makes.. I'd get that and go for a C16 race gas tune, just got one myself and its a night and day difference.. went from ~385whp to ~500whp, and went from trapping 11.9 down to an 11.3, and i can definately improve on the race gas time as i've only been to the track 1 time so far with it..
So if ur looking for more power either do meth injection, or do a race gas tune, but regardless of which one you do i'd for sure go with the .82 housing for the turbo too..
STimo is offline   Reply With Quote
Old 06-09-2009, 05:33 PM   #14
jamesssf
Member#: 205598
2006 Sti
Thanks for all teh advice. I'll look into the aquamist and injectors later when I have the money for another tune.
Old 06-11-2009, 02:35 AM   #15
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
There's nothing wrong with AP parts. My turbo inlet and downpipe are doing just fine at the same power level.
zeropsi is offline   Reply With Quote
Old 06-11-2009, 03:20 AM   #16
GeneralTJI
Member#: 152680
Do you have E85 around? Would put you well into the 400's on pump fuel
HP curve looks very nice... pulls out nicely. Might look into the .82 as others have suggested if you plan on upping the boost.. should keep the top from falling off so you can maintain that nice curve.
GeneralTJI is offline   Reply With Quote
FS : 2006 STi stock springs *cheap* fluxcapacitor SCIC Private Classifieds 3 06-30-2010 05:49 PM
AMR Build: Performance Chemicals, LLC. 2006 Subaru STi - 800+whp - MONSTER BUILD! AMR NASIOC Project Cars 82 03-05-2010 05:58 PM
CT: 2006 STi GT3076R chlnOrSlpn? Private Vehicle 'For Sale' Classifieds 21 11-11-2008 10:24 AM
Ultimate Racing is ULTIMATE - 435 whp @ 19 psi 2006 STI GT35 Dyno Flash Proven Power Bragging 29 11-17-2006 01:21 AM
a safe 370 whp. 02h20 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 11-12-2006 02:27 AM
