Old 06-09-2009, 12:15 PM   #26
Gixxer1K
Member#: 81631
stage 11
TAZ any more details about the aem intake?
Gixxer1K is offline   Reply With Quote
Old 06-09-2009, 01:00 PM   #27
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Originally Posted by kellygnsd View Post
Jeff, you mentioned the HTA runs + Torco, did you run Torco in the non-HTA runs also?
It is as the graph titles indicate. The 19psi HTA run was pump only, and the 23psi HTA was with Torco. The other 2.0L 18G runs were pump only, not including Torco.
The 2.5L runs (all of them) were without Torco.
Jeff
sponaugle is offline   Reply With Quote
Old 06-09-2009, 01:01 PM   #28
bibs
Member#: 199879
2009 Forester
FXT
Hi Jeff
i have a td05-18g right now on my 2.5 4eat, not worth it to sell my turbo for the hta68 ?
bibs is offline   Reply With Quote
Old 06-09-2009, 01:05 PM   #29
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Ah, Unabomber does not think that my data-logging of raw intake temps is very useful without A/F. I guess I might not be informed enough about what the intake temp reading vs. what the car does with this reading vs. the actual air charge temp. means in the grand scheme of things. I just know what I logged from my thread mentioned above and as Jeff pointed out this was something that can be corrected on the dyno but maybe not on the street? I just know that on the street, without the fog cover off, the intake seems to be really hot.
More testing to come. Maybe if I ask really nicely I can get Tim and Jeff to tune with different intakes since they are easy to swap out and do some "real" data logging on the street to see if there is carry over.
I would like the AEM to work. The general fit and finish of the product rocks.
tazswing is online now   Reply With Quote
Old 06-09-2009, 01:13 PM   #30
penusai
Member#: 102808
2002 v8 EJ207
v7 6spd FP Green
Originally Posted by bibs View Post
Hi Jeff
this is something you decide... read this thread, and the other two and make your own decision.
penusai is offline   Reply With Quote
Old 06-09-2009, 01:20 PM   #31
blkscooby
Member#: 44422
2008 G8 GT
Burnouts on Central!
Originally Posted by sponaugle View Post
The hickup around 3200, and the 10% TPS feel are a result of the larger injectors. There are a few fixes, although none of them are perfect. It seems there are some maps not exposed that are effected by injector size change. Jeff Perrin has been playing around with his map for months trying to get it smooth.
Jeff
What did you use to tune, Cobb AP? I didn't notice if you mentioned it.
Did you tune the engine load/ RPM/ MAP table? This is very different than the older years and has up to 20% correction at 2600-3200 RPM, slight vacuum range.
I have been playing with this table in my 08 with RomRaider and have made the hesitation better, but it is still there. I have stock injectors and intake BTW.
blkscooby is offline   Reply With Quote
Old 06-09-2009, 02:22 PM   #32
Kastley85891
Member#: 127704
2013 Leggy
Scooby no4 - huntin for 5
Originally Posted by tazswing View Post
Yup, and why I felt it was expected.
Not on the STI. But if the injectors have enough left, I would like an E85 map please!
Like to see that result.... thats my possible route, Im on E85 now with the VF but have ran a 20G also previously on the corn, be an 'interesting ' combo I feel
Kastley85891 is offline   Reply With Quote
Old 06-09-2009, 04:39 PM   #33
EMS
Member#: 14116
Originally Posted by John@Cobb View Post
The 2.0 seems to be a bit laggy on the dyno, but it is much more responsive on the street.-J
Good point! It's actually VERY responsive on the street, better than a TD05H 18G in my opinion.
Mark.
EMS is offline   Reply With Quote
Old 06-09-2009, 04:56 PM   #34
Gixxer1K
Member#: 81631
stage 11
Does the IAT sensor need to be insulated from the engine bay heat or something? Or is it picking up conduction from the metal AEM intake?
Old 06-09-2009, 08:52 PM   #35
uc0083
Member#: 30077
2004 WrongWayParked
WRB WRX Wagon HTA68
If the 2.0L is the Blue Wagon then this my car and its running a ssac fmic.
Its very responsive on the street and very deceptive on how much power it has. The power is so linear that you dont realize how fast the car is going and even at the top end it still wants to go on.
uc0083 is offline   Reply With Quote
Old 06-10-2009, 10:54 AM   #36
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Wrapping the metal arm is certainly a possibility.
You got tuned just before me, so we met! I agree, the car feel like it has almost less torque do the nature of the power delivery. Very easy to drive thus far.
Old 06-11-2009, 12:02 AM   #37
Dobbs
Member#: 28291
2005 STi
Tuning Subarus in RMIC
Originally Posted by Surgeline Tuning View Post
jeff, i was wondering if you could comment on the sudden change in slope of the HTA's boost at around 3250rpm. From 2000-3250rpm, it looks like the boost is building at nearly the same rate as the 18g, and then at 3250 it takes on that weird plataeu shape for ~750rpm. i don't see the same thing happening on the 2.5l. do you think this might have been a boost leak or maybe something funky with WGDC / WG spring pressure?
Dobbs is offline   Reply With Quote
Old 06-11-2009, 05:59 PM   #38
uc0083
Member#: 30077
2004 WrongWayParked
WRB WRX Wagon HTA68
Interested in that myself.
Old 06-16-2009, 11:07 AM   #39
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Well, it is done. Revised 92oct. tune and an E85 map as well. All will be posted with dyno graphs if I know Tim and Jeff and also this is not my thread!!
I want to "publicly" thank Tim for the tune last night. I got out of there after 9pm and Tim still had to close. We had fun seeing what this turbo can do on stock internals with 80 degree shop temps. The intercooler stayed just that throughout the tune so that is good news.
My new T-shirt will read: IloveE85.
Cheers!
Old 06-16-2009, 12:20 PM   #40
SaabTuner
Member#: 67608
I'm thinking exactly that; it looks like the HTA gets up to the spring pressure (or at least near) very quickly, and then the computer appears to use a less-aggressive boost climb. I bet if you either tuned that a little more aggressively, or used a better boost solenoid, it would spool much quicker.
-Adrian
SaabTuner is offline   Reply With Quote
Old 06-16-2009, 12:35 PM   #41
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
Cheers!
go ahead and throw up the e85 tunes andrew. Jeff and i will repost later with supporting data.
Tim
Old 06-16-2009, 03:40 PM   #42
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Ok, think I got the graphs correct now.
Ok, here we go: Mod list: DW850, WB255pump, Perrin two-cat DP, Borla CB, AEM CAI, FP HTA68 turbo, colder plugs, Motul 10W-40, around 80 degree shop temp, foglight cover removed, no heat shield on the AEM. 2008 STI, stock internals hence the boost not over 22psi.
First is the tune with and without the catback. Nothing else was changed mechanically speaking between these two tunes. This is the Borla system.
This is 92 Octane full boost (S#) vs. E85 full boost (S#):
This is 92 Octane full boost (S#) vs. E85 low boost (S). Very cool since you can essentially make the same power with E85 with much less boost:
Here we have both maps for the E85 tune presented (S# and S):
Old 06-16-2009, 03:42 PM   #43
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Here we have lower boost setting for both fuel types (S:92 and S:E85):
The car remains highly drivable with the E85 tune. I can just putts around town in S# E85 and the car is, well, civil. This platform also delivers that power is a very predictable and drivable way when you get on it as well. Fun little chirps from the tires Anzen615s, too. I cannot comment on driving the 92 octane map yet since we rolled from one fuel type to the other without removing the car from the dyno. I will let Tim and/or Jeff comment on the technical side of things (what was found with +/- timing and boost tuning tuning, etc).
Old 06-16-2009, 03:52 PM   #44
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I am assuming that the HTA turbo has a 2.4" inlet? Is it possible to get a 3" inlet with this turbo? I have been kicking around the 20g idea for a while now and haven't made teh plung yet. The HTA beign as cheap as it is makes me think twice. I was going to go with either the TD05-7cm^2 EWG or the TD06-8cm^2 both coming with a 3"inlet. Now I am so confused....
medamullet is offline   Reply With Quote
Old 06-16-2009, 04:01 PM   #45
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Unless otherwise posted, all equipment on the 08sti is OEM (intake, TMIC, internals, headers, UP, pulleys, etc).
Old 06-16-2009, 04:05 PM   #46
Loubaru
Member#: 155489
07 STi
I can't see the graphs...?
Loubaru is offline   Reply With Quote
Old 06-16-2009, 04:08 PM   #47
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
RELAX, I AM CONVERTING PDF FILES AS WE SPEAK. THIS POST WILL BE FULL IN A LITTLE WHILE.
see above. converting pdfs...and trying to work at the same time
Old 06-16-2009, 04:53 PM   #48
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Graphs are all up. Also, anyone local just hit me up with a PM and we can try and meet up for a ride if you want to feel the car first hand.
Old 06-16-2009, 05:04 PM   #49
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
ya, I realize that but it doesn't answer my question and help me make my choice any easier.
Old 06-16-2009, 05:08 PM   #50
penusai
Member#: 102808
2002 v8 EJ207
v7 6spd FP Green
what you're asking, he can't answer.
FP doesn't offer this in a 3". so your answer is no.
all you can do now is compare and compare, keep on comparing, and choose whatever you can get the "better" price on etc.
Non-Subaru Cobb Tuning/Surgeline Tuning EVO X Cobb Tuning Member's Car Gallery 12 03-08-2009 06:17 PM
06/11/08 AK RACEWAY PARK PRE-REGISTRATION FOR SS X-3 (Free class and test & tune incl missiceblast Alaskan Impreza Club Forum -- AKIC 20 06-23-2008 10:26 PM
Tim Bailey of SurgeLine Tuning in Santa Clarita YimiSport Tuning Cobb Tuning SCIC Vendor Classifieds 140 01-30-2008 02:36 PM
Solo Nationals Warmup and Test-n-Tune - Sept. 7 at SGMP (Ga.) wrx2.0 555 Motorsports 11 09-04-2007 06:02 AM
Video is up! DB meet and Test & Tune Vid xenonk Mid Atlantic Impreza Club -- MAIC 4 03-31-2004 08:59 AM
Message Board Statistics All times are GMT -4. The time now is 08:18 PM.
