Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 06-08-2009, 08:02 PM   #1
uaoSTI
Member#: 175957
2005 Subaru STI
Default Need help with a datalog
I am experienceing a massive throttle body shut down at full throttle for some reason and need some help with interpreting the data. It is a .csv from my AP in my 05 STI (20g, 745 injectors, wahlboro pump). Cobb tuned on the dyno but for some reason I have not been able to smooth it out yet. I am hoping someone can look at the file and let me know what parts I may need to fix this hiccup.
How can I upload a file? Any clues?
here is a pdf but the layout is fubared
https://app.infopia.com/tainswor/ima...d/datalog4.pdf
send me a PM with your email and i will send the csv over
uaoSTI is offline   Reply With Quote
Old 06-08-2009, 08:19 PM   #2
nme187
Member#: 117763
Looking over that log, it's running good.
.7% STFT is GOOD! Jebus bad fuel alone will jump it 2%+/-.
The DAM is constant 1 aka perfect.
The DA never reads - in boost so your not knocking.
Not even going to quote the A/F's
What's going on with it? It's too hard to read in PDF format to look across the board.
nme187 is offline   Reply With Quote
Old 06-08-2009, 08:47 PM   #3
MXJS
Member#: 129793
2004 STI
LSX RX-7
Log RPM, Load, MAF voltage, throttle position, and boost, and wideband A/F. I had a the exact same problem once. My MAF extension harness was garbage and the ecu was getting a bad signal from it. I rewired it with stinger speedwire and it fixed the problem.
MXJS is offline   Reply With Quote
Old 06-08-2009, 09:34 PM   #4
uaoSTI
Member#: 175957
2005 Subaru STI
Thanks for the help so far.
What is the issue? Full throttle (99.96%) at 3800 rpm's then the TB goes to 35% at 4084 rpm's then back up to 99%. The car is stuttering in a full pull every time in 4th and 5th gear. hard to replicate in 3rd.
Looking at the logs you can see where the throttle is going from 99.96 to 50% or less during acceleration
I will try a new pull asap with the fields recommended. I am praying its a mechanical issue (ie, maybe MAF thing you pointed out).
From my original file MAF voltage looks consistent for the same times as the image above
4.52
4.56
4.58
4.58
4.52
4.22
4.1
4.2
4.36
4.46
Also Air/Fuel is 11.04 constant
Old 06-08-2009, 10:02 PM   #5
uaoSTI
Member#: 175957
2005 Subaru STI
Old 06-09-2009, 12:59 AM   #6
MXJS
Member#: 129793
2004 STI
LSX RX-7
Try swapping maf's with someone. When i had the problem the MAF voltage looked normal as it does in your log. Has it always had this problem or is it a recent development?
PS: the air/fuel will always show 11.04 under wot because it is not a wideband. It is pretty much worthless to log unless you are logging during closed loop operation.
Old 06-09-2009, 01:48 AM   #7
TurboJunkie85
Member#: 193412
1985 pumas.
white
If swapping the Maf doesnt help try re-scaling your maf I think you are able to do that on the AP race tuner
TurboJunkie85 is offline   Reply With Quote
Old 06-09-2009, 10:16 AM   #8
MXJS
Member#: 129793
2004 STI
LSX RX-7
Also forgot to mention the first thing you should do. Check for vacuum/boost leaks.
Old 06-09-2009, 10:50 AM   #9
uaoSTI
Member#: 175957
2005 Subaru STI
got a link on how to do this?
And I believe I dont have any boost leaks (recently t-bolt clamped all turbo and Y Pipe hoses). Nonetheless I will keep looking.
Thanks.
Old 06-09-2009, 10:56 AM   #10
xblackdeathx
Member#: 72357
06 fxt,11 outback
,96 land cruiser
I know how you can fix it. Drive it off a cliff?
xblackdeathx is offline   Reply With Quote
Old 06-09-2009, 11:27 AM   #11
uaoSTI
Member#: 175957
2005 Subaru STI
I just text'd you homo
Old 06-09-2009, 12:00 PM   #12
TurboJunkie85
Member#: 193412
1985 pumas.
white
Log your G/sec and your maf voltage from idle to WOT and then pull up your maf scaling values and see if it's off you might wanna get a couple of logs in before you start making adjustments
Old 06-09-2009, 12:45 PM   #13
MXJS
Member#: 129793
2004 STI
LSX RX-7
I wouldn't recommend making any changes to the MAF scaling if it was tuned correctly by cobb. If it wasn't tuned correct, i wouldn't recommend making any changes in open loop without a wideband A/F reading. An improperly scaled maf will cause a rich or lean condition, but i don't see it causing the TB to close. I could be wrong though.
uaoSTI - Do you have a fuel pressure gauge?
Old 06-09-2009, 12:50 PM   #14
uaoSTI
Member#: 175957
2005 Subaru STI
uaoSTI - Do you have a fuel pressure gauge?[/quote]
i do not actually (oil temp, boost, A/F). i am running the Wahlboro intake and deatschwerks 740 injectors)
Basically the car sputters heavily at those logs and then starts to climb again. i think the map is good so it may be electrical or mechanical. i may have to give Solid a test ride to see if they can figure it out....
Old 06-09-2009, 12:58 PM   #15
MXJS
Member#: 129793
2004 STI
LSX RX-7
Well if you wanted to diagnose it yourself this is what i'd do:
Swap maf with someone else
Pressure test IC piping and vacuum lines
Check to make sure fuel pressure isn't dropping out (bad fuel pump or FPR)
Make sure spark isn't being blown out (fouled plugs or too big of gap)
Log requested TP vs actual TP to see if its a bad TPS
If i think of anything else i'll let ya know. I'm confident its a mechanical/electrical problem if it hasn't always done it.
Old 06-15-2009, 04:27 PM   #16
uaoSTI
Member#: 175957
2005 Subaru STI
just an update:
i put in new iridium plugs (gapped to .025) and am still having the same issues. I dropped the car off at Solid in the hopes they can wrap their brains around it....
Old 06-30-2009, 03:03 PM   #17
uaoSTI
Member#: 175957
2005 Subaru STI
possibly last update:
Paul @ solid discovered 2 things:
1. WG diaphram was torn to bits
2. lower o ring in WG was brittle and fried to death
New parts on the way. hopefully bliss follows.
Columbus, OH: Need help with TMIC install.. taketurns Mid West Subaru Owners Club Forum -- MWSOC 0 06-04-2010 06:15 PM
need help with a/c compressor replacement sen7inel Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 06-04-2010 09:53 AM
Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-18-2003 01:11 PM
Help! I need help with turbo 99 HOK Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 04-16-2001 09:05 AM
Need help with o2 sensor signal please help ac_gohan Normally Aspirated Powertrain 1 01-16-2001 06:06 AM
