Old 04-24-2002, 10:04 PM   #1
giulio
Member#: 16040
1998 Impreza RS
Supercharged
Default No a/f cycling at idle
Whats up fellas
Recently I changed my clutch slave cyl. That fixed my low pedal problem, but that same night i got idle problems.
It idles rough, once the car is warm and rpms drop to 700. sometimes almost stalling, dropping to 500 then catching up to 850 and back to 700.
TPS is working fine. 0.0%
AFL is fine. 0.8% (98MY)
Vac is fine. 18-20mmHg
All Cylinders are firing
what isN'T fine is the A/F...
it's not cycling anymore at idle. While cruising it's working fine though. And at high throttle it's fine too- nothing is out of the ordinary except at idle.
I disconnected the boost guage and PFR from the lines, pretty much putting fueling back to stock. Reset the ECU. Started it up... same thing. I checked all the vacuum lines... they're all fine.
Any ideas?
Would an ODBII scan find out what's up? There's not CEL.
thanks in advance,
giulio
giulio is offline   Reply With Quote
Old 04-24-2002, 11:01 PM   #2
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
I would say maybe a bad MAF reading at low RPM. Also, what your fuel pressure at idle? If you have a high pressure pump, like most of the Walbro's out there, long term high baseline fuel pressure could be a catalyst for something like this, just a thought.
Also, and I have mentioned this in previous posts, but what about your fuel filter going bad? They do have a life expectancy you know.
Hope you get it figured out, sitting at traffic lights with your foot pumping the throttle sucks.
Graham
Graham is offline   Reply With Quote
Old 04-24-2002, 11:27 PM   #3
Legacy GTR
Member#: 9316
1997 Legacy GT
[email protected]
Is it staying constent at one place on the A/F meter? Or is it not on at all. Check and see what voltage your at during idle. mabe it's a little low.
Mike
Legacy GTR is offline   Reply With Quote
Old 04-25-2002, 12:35 AM   #4
Aphex
Member#: 146
'16 WRX Limited
damn, another one, same thing with me, I'll check my A/F meter tomorrow when it does it to see what it's doing, but the idle characteristics is the same, fuel filter replaced shortly before it happened.
Aphex is offline   Reply With Quote
Old 04-25-2002, 01:38 AM   #5
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Are you sure it's not just cold? When the o2 is cold, it's not going to cycle.
If it's doing it after a drive, perhaps you should relocate the o2 sensor.
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 04-25-2002, 04:05 PM   #6
Aphex
Member#: 146
'16 WRX Limited
been driving around today and I get the exact same symptoms as gulio, A/F cycles at cruise, but not at idle.
what the heck does that mean?
eli
Old 04-25-2002, 09:03 PM   #7
STiTuner
Member#: 5778
09 135i
Jet Black
just tell people you cam cams with big lobes in your car and no one will ask whats up
Brad
STiTuner is offline   Reply With Quote
Old 04-26-2002, 02:28 PM   #8
giulio
Member#: 16040
1998 Impreza RS
Supercharged
Lightbulb
Thanks for the help everyone, much appreciated.
air meter readings are normal, about 0.8% at idle. usually it's .9 or 1.0... does .1% really make that much of a difference? i get a little over 50% at 6500rpm full throttle.
the walbro pump is only a year old and sounds fine. At cruise and full throttle everything is fine.
fuel filters were changed 30k miles ago.
the a/f guage isnt even lighting up the first led. it's off the chart, low.
Cold start it idles fine, 1500 rpm. when it drops to 700 it gets rough.
Well I finally gave up... brought it to the local mechanic to have it checked out (please forgive me haha).
He says there's a small leak where the SC is mounted to the intake manifold adapter. so some air is leaking out and screwing up the reading. but it's not enough to matter at cruise or boost.
I think he might be right. The rimmer instructions said to use RTV sealer and so i always have. but this time i didnt let it sit and cure overnight (totally forgot). i just bolted it on and full boosted down the road. oops! I guess it blew some sealer out of the junction. It was that very next drive when this condition started... and just got worse every day so far.
So... guess what i'll be doing saturday morning... again. I'm getting pretty good at this now. runnin out of bandaids though =/
Hopefully the mech is right and i'll be back to normal sunday morning.
Eli,
Check every single vacuum hose. i wonder if you can put a drop of water over fittings and see if it gets sucked in (leak). good luck with it!
Old 04-26-2002, 08:09 PM   #9
Aphex
Member#: 146
'16 WRX Limited
thanks I'll check into it, it did seem to start happening after I put my IC on, however I've had an air leak in my second air box before when I was N/A and it was totally different from what it happening now, I'll check it out though.
eli
Old 04-27-2002, 10:55 AM   #10
PunKidd
Member#: 8533
2002 2.5 RS-T
LudeSpeed S. III W/ FMIC
Just a thought, but getting water inside a vacume line does not sound like a great idea to me.
PunKidd is offline   Reply With Quote
Old 04-27-2002, 12:06 PM   #11
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
true, a smarter thing to use is starting fluid.
ColinL is offline   Reply With Quote
Old 04-29-2002, 09:16 AM   #12
giulio
Member#: 16040
1998 Impreza RS
Supercharged
Exclamation
What the hell was i thinking with that water comment...
I resealed the mating parts. But I can't tell if it worked or not. The rpms won't drop below 1300 now.
bypass valve is in the correct position.
a/f is cycling normally again.
throttle is 0.0%
afl is well over 1%.
CEL is on.
I'm thinking 2 things.
A) air is being sucked in before the throttle body
- Maybe something's broken with that valve that handles idling at 0 throttle ( forgot the name... pvc? pcv? )
B) timing is being raised causing really high idle.
- Ecu or J&S fried?
I don't think it's a fuel problem. I tried lowering it with the afc but the rpms didnt go down. I also tried raising it. The car just compensates and goes back to 1300.
i'm getting sick and tired of this.
the rx-8 is looking better every day.
g
Old 04-29-2002, 09:35 AM   #13
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
So you have resealed it and the car is still doing this?
Graham
Old 04-29-2002, 02:34 PM   #14
giulio
Member#: 16040
1998 Impreza RS
Supercharged
No, it's a different problem now.
Before the car idled at normal rpm, very rough, then droped to 400... bounced to 900, then leveled off at 700 again. (sometimes it wouldnt bounce back, and just stall) There was no CEL.
Now it doesnt go below 1300rpm, smooth, and i have a CEL.
Since I have a CEL i might as well have the code pulled.
Situations suck when it's your commuter car.
g
No heat at Idle?? northpolerex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 12-24-2009 07:45 PM
Help no power steering at idle. Porkchop-WRX Brakes, Steering & Suspension 9 10-09-2006 10:49 AM
Why no boost at idle? vipernj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 60 12-15-2005 01:52 PM
No heat at idle, only when moving, and long warm up period? Need4Boost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 12-01-2002 12:01 PM
Rev at idle, why no boost? Ethan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-24-2001 06:35 PM
