Old 06-08-2009, 09:53 PM   #1
Chuck H
Member#: 20442
Default bugeye fog light bulb replacement
One of my foglights on my 03 WRX has been out for a couple of months, so I decided to change the bulbs this evening. That turned out to be a much bigger PITA than I expected. Are there any tricks to getting the foglight housings loose that I don't know about, or does Subaru just use incredibly cheap screws to hold them in? I broke the heads off 2 of the 3 mounting screws on one side using only a 1/4 inch socket wrench and very minimal force. Of course, the first screw came out fine, so I didn't realize I was in trouble until the 2nd and 3rd one. I didn't even bother with the other side, because those screws seemed to be rusted solid, and I figured they'd break in a heartbeat, too.
Are they something that will be fairly easy to drill out and replace, or am I looking at coming up with something custom to try to hold the lens assemblies back in place?
Chuck H is online now   Reply With Quote
Old 06-08-2009, 10:03 PM   #2
WRX Loki
Member#: 208332
06 Hawkeye Wagon
Red
Had the same problem
From underneath, You can get in behind the assembly.
I PB'ed the hack out of the front and back side of the nut/bolt and took it out with needle nose vice grips. Yes it's slow going but can be done.
If you have a welder handy, welding a bolt on the back side works also.
WRX Loki is offline   Reply With Quote
2004 WRX Fog light bulb replacement? The Modaholic Electrical & Lighting 7 09-03-2010 11:08 PM
02-03 Fog light bulb replacement suggestions. HolyCrikey Electrical & Lighting 10 05-03-2005 06:12 PM
Fog light bulb replacement NickD151 Electrical & Lighting 4 01-19-2005 03:27 PM
Fog Light Bulb Replacement SSR Legacy Forum 3 03-27-2002 09:51 PM
99-01 Fog Light bulb replacement Keith99RS New England Impreza Club Forum -- NESIC 6 11-30-2001 11:19 PM
