Old 06-11-2009, 01:52 PM   #26
Prevent
Member#: 149114
Hm, there's really no reason you should be idling poorly.... injectors and tgv's or not...
I know many people with TGV deletes and 850cc injectors it idles like stock. (Illinois residents)
Should talk to your tuner about it...
Prevent is offline   Reply With Quote
Old 06-11-2009, 03:04 PM   #27
Sb22284
Member#: 168386
Threw another P0457 again on my second tank of gas. Same mileage in as the first one ~45
and the idling is only bad when i first start the car.
Sb22284 is offline   Reply With Quote
Old 06-11-2009, 07:11 PM   #28
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
Originally Posted by c'dalerider View Post
+1 on poor fuel economy, with any bigger injectors realy.
+1 , i expected better tq #s on an STi (cam timing), but the 07 maps are difficult and the tuner there is tops so i dont know.
+1, 850 injectors are not very good on cold start up and idle poor, especially PE's! DW's are much better for those issues. My car idles to wrong for me. Im changing things up asap.
i love my gt 30r kit on a DD 06 STI. Im tuned to 21.5 psi with meth and 418/403, high reading dyno. Boost almost comes on to quick and she just stops 'pulling' at 55k rpm..sortof...ha. Great powerban.
My PE800's are fine actually.
Stops pulling that early? Why would it do that? Your peak power should come in higher than that.
TGV deletes, 800cc injectors, a 73mm intake, and cams to be exact, and the only time I ever have issues with startup or idle was when I was running Motul 300V (15W50) and the first real cold snap hit last fall. Otherwise zero issues.
zeropsi is offline   Reply With Quote
Old 06-11-2009, 08:01 PM   #29
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Originally Posted by Sb22284 View Post
Exactly what he said. I have no doubt there is room to grow. With what you have to spend on this kit to get where i am its tough to add in the price of a rebuild and clutch. I could buy a new cobalt for that price
Very Nice Jorge doing his thing as always
Your going to learn very quickly if you want to play you have to pay and that's the bottom line. I have invested in both; an AXIS Stage 3 SB and a Exedy Twin Disc.
Once you play daily at the 400WHP+ level on a DD you need to save $$$$$ because things do break and things like tires and brakes wear out very fast, almost seasonally.
Originally Posted by woodys77 View Post
if you have a big maf its probably your culprit not the tgv delete.
Not true at all I have run the P&L Big MAF setup and the P&L CAI and never idle issues. I also have my TGV's deleted and P&P.
I run modded stock FI's benched at 920CC's and idle at 900rpms.
-Dan
4ST-AIR is offline   Reply With Quote
Old 06-12-2009, 03:58 PM   #30
woodys77
Member#: 192147
2007 STI EfiLogics
422whp 421wtq fpgreen
-Dan
my aps 70mm starts fine when cold but when warm sometimes when i start it it idles ruff till i rev it up, with the stock air box installed(just to start not to drive) all is fine. but aps is not the same as p&l, maybe its just an aps thing? to the op try raising your idle a couple hundred rpm, it helped me.
woodys77 is offline   Reply With Quote
Old 06-12-2009, 10:10 PM   #31
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
First dyno runs we ran with the TGV still on. Car made about 350 and the motor on the TGV broke(due to heat?). This is a simple mod that some forget and it is a must. car put out 22HP more with it gone.
Did you remove just the butterflies, the butterflies and the rod, or did you install TGV deletes?
TypeC is offline   Reply With Quote
Old 06-30-2009, 02:27 PM   #32
Sb22284
Member#: 168386
Update : Got the CEL codes cleared up. There was a loose vacuum hose going to the intake manifold. The idling issue has worked itself out and there is no more RPM bouncing
Im still working with Perrin to figure out something with the top mount. We've tried everything from brackets to spacers to bushings. Seems the Y pipe is hitting the power steering bracket. I zip tied the hell out of the AC lines to keep them in place and they are not getting all bent up anymore
Old 06-30-2009, 02:41 PM   #33
benw
Member#: 103320
1998 swapped
Forester L
you sure it wasn't the air pump? that's the only thing that runs at startup that would have an effect on your idle. TGV deletes don't do much. they will create a very small flat spot in the warmup process, but that's only for a minute or so.
benw is offline   Reply With Quote
Old 06-30-2009, 06:26 PM   #34
unclemat
Member#: 114530
2005 LGT 6MT wagon
Originally Posted by my94saleen View Post
i didnt know that. on amr's dyno stock sti's put down 201whp 200 lb tq
Yeah, we know yet. Yet bigger turbos read higher on their dyno than on other dynos. Magic!
unclemat is offline   Reply With Quote
Old 06-30-2009, 08:29 PM   #35
CatfaceType-R
Member#: 81102
For what its worth, i get 16.5 MPG sitting in Chicago traffic... lol
there is something wrong with your car..diagnose it, this is abnormal...i've even seen big turbo car's do this
before my fuel pump gasket went, I had really bad gas mileage..no idea why or how they are connected, technically speaking..but you do have a problem if your calculations are right about your avmpg
CatfaceType-R is offline   Reply With Quote
Old 06-30-2009, 10:47 PM   #36
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
I agree. I drive agressively and am always hard on the gas. I have 850's with an hta68 turbo, and still get 275 to a full tank, 325 if all highway.
STi Mikey is offline   Reply With Quote
Old 07-06-2009, 12:41 PM   #37
blk05wrx
Member#: 180559
2016 WRX STi Limited
Honestly 16.5MPG doesn't sound that bad for Chicago. I've averaged 18.5MPG for the last 4 years with a bone stock 05 WRX going back and forth to work.
On the highway it runs up to 27 or 28.
Sb22284, thanks for the quality used Cobb DP. I just had it installed and re-flashed to Stage2.
Your car sounds awesome. I'll look for you at the Thurs. meets. I've got to get a ride in that thing.
blk05wrx is offline   Reply With Quote
Old 07-06-2009, 02:38 PM   #38
zeropsi
Member#: 175453
AE86 GT-S coupe
Another Subaru @ the Algonquin meet?
I definitely need a ride in it too, haven't had the pleasure.
Old 07-06-2009, 02:46 PM   #39
mikewarlover
Member#: 197803
2009 STI--->C63
Black--->White
Good power smooth and nice flat torque curve
mikewarlover is offline   Reply With Quote
Old 07-07-2009, 02:43 PM   #40
Sb22284
Member#: 168386
sold !!!
Old 07-08-2009, 10:34 AM   #41
blk05wrx
Member#: 180559
blk05wrx - Did you think about getting an aftermarket tune? I loved my cobb stage 2 but its worth the extra few bucks to get a map custom to your car.
I'm still thinking about it. I'm enjoying the new power for now. I might wait a few months to see if there's anything else I want to add before I get a custom tune. (Sti intercooler, SPT intake, etc.)
I'm a little concerned that a custom tune may get a little more horsepower by leaning the motor out a little more. I don't want to risk it just to squeeze out another 10 HP. Right now I have exactly what the Cobb Stage 2 notes call for. TBE and everything else stock.
FS : 07 sti springs, 04 wrx springs shsjr89 SCIC Private Classifieds 8 02-16-2012 06:26 AM
FS : 02-07 STI Axleback muffler ai42 TXIC Private Classifieds 23 08-17-2010 09:53 AM
07 sti tranny scoobydoo914 Private 'Wanted' Classifieds 0 06-04-2010 06:14 PM
FS : FL 04-07 Sti Blitz throttle controller Imprezsti5 Engine/Power/Exhaust 5 06-03-2010 05:27 PM
FS/T: Roof Vane Spoiler, 07 STI headlight, 07 STi grill, 07 STI trunk and wings SD marrenr813 SCIC Private Classifieds 42 09-28-2007 10:59 AM
