Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 06-08-2009, 11:55 PM   #1
evanevan
Member Sales Rating: (13)
Member#: 95253
2004 WRX
Java Black
Default Ground Control Coilovers AGX with Koni Inserts (Socal)
SOLD!
Up for sale is a set of Coilovers. KYB AGX shocks in the front and shock bodies with Koni Yellow Inserts in the rear. Eibach Ground Control Coilover spring kit mounted on top with GC230.64.55 F and GC200.64.58 R. (315lb/in Front and 330lb/in Rear). Comes with Tophats in the Rear and you can reuse your tophats in the front. Also they handle great!
$350 picked up
Located in San Diego,CA.
evanevan is offline   Reply With Quote
Old 06-09-2009, 06:11 AM   #2
240kat
Member Sales Rating: (1)
Member#: 90366
1997 Cherokee
Red
what were these on?
240kat is offline   Reply With Quote
Old 06-10-2009, 02:06 PM   #3
Un0RiGiNaL
Member Sales Rating: (26)
Member#: 189748
how many miles were they used for?
Un0RiGiNaL is offline   Reply With Quote
Old 06-10-2009, 11:43 PM   #4
evanevan
Member#: 95253
2004 WRX
Java Black
They were used on a 2004 WRX. I put about 10k on them.
Old 06-10-2009, 11:45 PM   #5
bugeyebilly34
Member Sales Rating: (3)
Member#: 205858
2004 STI
JBP GT35R
have any pics of how low they go on your car?
bugeyebilly34 is offline   Reply With Quote
Old 06-11-2009, 09:13 AM   #6
Feign
Member Sales Rating: (39)
Member#: 68604
06 STi
Why is the strut on the far right all dented and effed up?
Feign is offline   Reply With Quote
Old 06-12-2009, 09:49 PM   #7
evanevan
Member#: 95253
2004 WRX
Java Black
It is not dented!!!!
The older rear KYB shock bodies have damping adjustments right there at the bottom. These damping adjuster wheels extude into the shock bodies. In order to fit the Koni Yellow inserts into the shock bodies I had to grind out the adjuster wheel that extruded into the shock body. It is still 100% strong with the wheel gone and did not compromise the strength of the overall shock assembly.
Again Nothing is "dented or effed up"....
Old 06-13-2009, 12:57 AM   #8
Rossabo
Member#: 117225
You can't adjust the height can you? Also do you have pics that show the drop?
Rossabo is offline   Reply With Quote
Old 06-13-2009, 02:36 PM   #9
evanevan
Member#: 95253
2004 WRX
Java Black
You can adjust the ride height, that's why the bottom perch is adjustable like any other coilover...
I had the set-up at just under the stock height but had the adjustment to lower it at least an 1-1.5".
However, I didn't want to compromise the suspension geometry by lowering it and introduce bumpsteer and dropping the roll centers. This can be fixed just with more suspension parts that I didn't want to buy.
Old 06-13-2009, 06:35 PM   #10
zmonster
Member#: 201142
2002 wrx sedan
Curious as to why you would put the yellow's in the back and not front given the superior dampening performance of them over the agx's.
zmonster is offline   Reply With Quote
Old 06-15-2009, 07:23 PM   #11
evanevan
Member#: 95253
2004 WRX
Java Black
the rears were blown and I'm cheap. These will compliment the slightly stiffer spring rates in the rear to get more oversteer.
Old 06-25-2009, 07:39 PM   #12
Subynoob763
Member#: 182441
03 WRX wagon
Paypal sent!
Subynoob763 is offline   Reply With Quote
Old 06-29-2009, 06:24 PM   #13
evanevan
Member#: 95253
2004 WRX
Java Black
sold!!!
Rear Camber Plates + Koni Inserts + Ground Control Coilover Kit compatible? rlavalle Brakes, Steering & Suspension 6 10-31-2005 07:22 PM
Ground Control coilovers and possible Konis strohk Private 'For Sale' Classifieds 11 10-14-2005 10:45 PM
FS: Ground Control Coilovers and Possible Konis strohk Mid West Subaru Owners Club Forum -- MWSOC 0 09-27-2005 06:29 PM
Talk me out of Koni inserts + Ground Control coilovers 100 Brakes, Steering & Suspension 15 03-17-2004 04:50 PM
Anybody have KONI inserts w/ Ground Control coilover kit? rommel Brakes, Steering & Suspension 6 03-02-2004 08:11 AM
