Old 06-09-2009, 12:38 AM   #1
Project Barnie
Member#: 123697
2006 Miata
Galaxy Gray
Default Lightwerkz Digital HID Vs OEM STi HID
I ordered a HID kit from lightwerkz (got here really fast! thanks Caesar!) when i thought my ballast was bad after forgetting to connect the ground wire on the driver side. Turns out the fuse was blown and the fuses i found in my dads car were blown only after i ordered the lights.
Now my question is, is there any difference in light output between digital HID's than stock HID's?
Project Barnie is offline   Reply With Quote
Old 06-09-2009, 01:29 AM   #2
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
The OEM stuff will probably be slightly brighter. The difference there is mainly from the bulbs. The biggest difference between the two is going to be reliability. The OEM stuff will most likely outlast the cheapo kits two or three fold. Aftermarket stuff just isn't built to the standards of OEM components. There is little quality control and they aren't tested to meet safety and reliability standards. The lightwerkz stuff is usually on the upper end of the crappiness spectrum but still not as good as OEM.
FourOnTheFloor65 is offline   Reply With Quote
Old 06-09-2009, 10:15 AM   #3
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
My kit meets the CE European standard.
CRAZYHAWK is offline   Reply With Quote
Old 06-09-2009, 10:52 PM   #4
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
That says nothing about its quality. It simply says that it conforms to the laws of the European Union to be sold within those countries. Without that sticker it couldn't be sold in the EU. For instance it is illegal to use Cadmium in EU countries in electronic devices. If the ballasts had cadmium in them they would not be able to pass CE standards. The products that receive it are usually self certified by the manufacturer. I bought a $2 flashlight that had a CE sticker on it. It broke the second time I used it. "CE" means pretty much nothing other than your kids won't grow a third arm after touching it.
Old 06-10-2009, 12:26 AM   #5
trueno16v
Member#: 175170
2005 WRX Wagon
owl + bungee cord= my a$$
So "CE" is to Europe what "UL" is to the US...?
trueno16v is offline   Reply With Quote
Old 06-10-2009, 02:31 AM   #6
pc4400
Member#: 139835
2007 Impreza WRX TR
grey metalic
No, there's lots of stuff with CE logos here in the US. But I can tell you that UL listings are stick, more than ETL listed lighting
pc4400 is offline   Reply With Quote
Old 06-10-2009, 08:51 AM   #7
CRAZYHAWK
Member#: 198067
WHITE Premium
This is the kit that I am using. I didn't buy it from either of;
http://cgi.ebay.com/HID-H11-8000k-ma...ayphotohosting
http://southjersey.craigslist.org/pts/1177816521.html
I had AutoSound Plus in Wayne NJ supply and install the kit.
Old 06-10-2009, 09:11 AM   #8
steverx05
Member#: 128269
www.hidkitsaregay.com
Dood, stop plugging your kit, NO ONE CARES. I can't believe a mod hasn't whipped you yet for linking to products to buy. I think someone is just trying to inflate their post count
steverx05 is offline   Reply With Quote
Old 06-10-2009, 12:36 PM   #9
Project Barnie
Member#: 123697
2006 Miata
Galaxy Gray
Thanks! I guess I'll just use the lightwerkz as a back up.
Oem WRX header Vs. Oem STI header... Difference? stevey323 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-05-2008 09:46 AM
Oem WRX header Vs. Oem STI header... Difference? stevey323 Normally Aspirated Powertrain 6 10-03-2008 02:08 AM
JDM HID vs. JDM non HID RIP EP3 Electrical & Lighting 0 03-22-2007 11:37 AM
Engine Options - Axis vs OEM STi vs Rebuild cwepruk Built Motor Discussion 31 12-20-2006 12:53 AM
04 vs 05 STi HID Setup Kaze Electrical & Lighting 1 03-08-2006 08:05 PM
