Welcome to the North American Subaru Impreza Owners Club Friday July 25, 2014
Old 06-09-2009, 12:57 AM   #1
blackout801
Member#: 170059
04 STi Stg 3ish?
BUNANA KING!
Default DIY: How to relocate your watersprayer for FMIC
i searched and never found a thread on how to do this so i figured id make it
supplies needed
  • OEM Check Valve - (Subaru Part #86634AG010) $8.00
  • something to cut with $5.00 at max
  • square foot of heat ducting metal shouldnt be to much maybe $8.00
  • 2 inch replacement screws for front plate $1.00
  • hammer
  • 7 feet of vacuum line $10.00 max
  • universal windshield whipper sprayers $15.00
  • drill bits
  • drill
  • hose T $1.00
  • unless your safe you'll need either zip ties or factory bumper clips $0-$15.00
1. Remove the front bumper
2. take the line that should be in your engine bay that went to your top mount watersprayer and connect the 7 foot line too it.
3. now run that line to your front i ran mine right under my headlight into my bumper beam then ran across the FMIC.
4.cut hose where you see fit then cut the extra cut in half
5. cut about 4 inches back on the line going to water sprayer and install check valve there (first toward the engine bay)
6. put T from where you first cut.
7. replace the front license plate screws
8. cut metal 7 by 7 inches
9. put metal on a right angle corner of work bench stair or anything and hammer it to bend it half so it should be in a shape then bend alittle more more.
10. press up against the screws that should be now coming threw your bumper and so the bend it toward the top of your bumper. This should leave marks on the metal so you will know where to drill holes.
11. use drill bit alittle smaller then the screws you used for the license plate and drill the holes in the metal.
12. decide where you want to put the nozzles (i did mine a inch from the center two inches apart.) use a drill the size of the nozzle screw in part where you want them to be.
13. unscrew license plate hold metal up against the back with the bend toward the top then re screw in license plate that should secure the bracket.
14. attach nozzles to bracket
15. attach each extra line to a nozzle
16. put bumper close to car attach nozzle lines to the T.
17. put bumper back on and adjust the nozzles to where you see fit.
18. fill up tank and enjoy!!!!!!!!
sorry for the lack of pics but here are some.
any issues pm me .
blackout801 is offline   Reply With Quote
Old 06-09-2009, 08:03 AM   #2
06mattsti
Member#: 174796
2006 STI
I plan to do this soon but I feel it shouldn't require this much work. I mean, should just be as simple as extending the line and mounting it but this looks like way too many steps lol. Good writeup though!
06mattsti is offline   Reply With Quote
Old 06-09-2009, 04:33 PM   #3
Admission_Regret
Member#: 131246
2004 STi Snow White
eighteen x ten + thirty
Just a picture of the finished product would help I think.. good write-up
Admission_Regret is offline   Reply With Quote
Old 06-09-2009, 04:35 PM   #4
vividwrx13
Member#: 66402
2005 STi Ver8
Or....if your state doesnt require a front mounted license plate just pop them in the holes..BAM!......... your done!
takes all of about 2 secs
vividwrx13 is offline   Reply With Quote
Old 06-09-2009, 05:28 PM   #5
gtasti
Member#: 152036
2004 Sti
easier way to do it
if you got a front plate leave alittle of that black platic that you cut out
remove the ic sparyer from the top and run the hose there with a hole that you have to make cost really not much at all
gtasti is offline   Reply With Quote
Old 06-09-2009, 06:08 PM   #6
blackout801
Member#: 170059
04 STi Stg 3ish?
BUNANA KING!
honestly this may seem like alot of steps but they take like a minute each to do and turns out clean i am posting pictures now
Old 06-09-2009, 06:28 PM   #7
hoffmanEstates
Member#: 122043
04 wagonier
psm
stinks when u have to sawzall the bumper brace to fit a fmic
hoffmanEstates is offline   Reply With Quote
Old 06-09-2009, 06:32 PM   #8
blackout801
Member#: 170059
04 STi Stg 3ish?
BUNANA KING!
haha its not that big of a deal i like it better then the brackets that come with the fmic's keeps the bumper more sturdy lol
DIY: How to change your door card color brcewane Interior & Exterior Modification 218 04-15-2014 07:59 PM
DIY: How to redo your grounds on your GC Impreza L.. Impreza Forum 1 11-05-2008 03:10 AM
DIY: how to break up with your significant other ralli-tart Vancouver Impreza Club Forum -- VIC 13 07-09-2008 10:12 PM
Tips for relocation? (AKA: How to change your life) SilverBullet2.5RS Off-Topic 14 10-11-2005 09:54 AM
How to advertise your truck for sale... eBay style. Siper2 Mid Atlantic Impreza Club -- MAIC 3 08-11-2005 09:22 AM
