Old 06-09-2009, 08:23 AM   #1
wawawrx
Member#: 200730
'08 E92 M3
'95 GC ZJ
Default 08 TPMS & different pressures for Nexen tires
I have my stock all seasons on, and i believe they are supposed to be run about 39 psi... my question is:
what psi should i be running in my Nexen N3000 tires (when they come in) and if it's below 39 psi, is there even a point in switching the TPMS over?
wawawrx is offline   Reply With Quote
Old 06-09-2009, 11:28 AM   #2
wawawrx
Member#: 200730
'08 E92 M3
'95 GC ZJ
bump for knowledge
Old 06-09-2009, 12:07 PM   #3
dougm12a
Member#: 163638
2008 WRX
There is very much mis-information on how the Subaru TPMS sensors work. Most Subaru dealers (all 3 I talked to) don't know what triggers the TPMS warning light and they pass out very inaccurate answers to questions on TPMS.
This is from Subaru's technical publication. The TPMS light only comes on if at least one tire is below about 27 pounds. The senosr can't be set to any other PSI setting and does not detect over-inflation.
"If the tire pressure drops below the minimum setting
approximately 27 psi), the sensor does not send its signal to
the control module. The module will then illuminate the
warning light.The warning light will not, however, indicate
which tire is low, so all tires need to be checked".
dougm12a is offline   Reply With Quote
Old 06-09-2009, 12:09 PM   #4
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....where did you get the 39 PSI # from? The pressure you decide to rung will depends on several factors. Either way, as long as the pressures are maintained above the recommended amounts listed on the door jamb (HINT: they are less than 39), there should be no problem. IIRC, it triggers when one or more tires drop below ~25-29 PSI so if the light does illuminate, you know you've got a problem.
EDIT: beat me to it Doug.
Kean is offline   Reply With Quote
Old 06-09-2009, 01:05 PM   #5
wawawrx
Member#: 200730
'08 E92 M3
'95 GC ZJ
i just pulled 39 out of the air... or lack there of air that is in my tires right now i have a leak in 1... but my new wheels go on wednesday so who cares
should i not bother switching the TPMS over from wheel to wheel and just check my pressures more often?
Old 06-09-2009, 01:15 PM   #6
Kean
Member#: 25187
'08 Foz Prem TGM
....it's up to you. If you don't swap the sensors over the light will remain on (unless the new wheels/tires have them and you synch them to the car).
As for monitoring pressures, this really should be done on a regular basis anyhow.
Old 06-09-2009, 01:17 PM   #7
wawawrx
Member#: 200730
'08 E92 M3
'95 GC ZJ
can a tuner turn that light off by any chance?
Old 06-09-2009, 01:27 PM   #8
Kean
Member#: 25187
'08 Foz Prem TGM
...you can do some searching but as far as I know, no one has found a way to disable the light (short of remvoing the bulb or covering it up).
Old 06-09-2009, 01:27 PM   #9
Kean
Member#: 25187
'08 Foz Prem TGM
*dbl post*
Proper tire pressure for new tires. Uzi Tire & Wheel 2 10-15-2005 07:02 PM
Proper Tire pressure for stock tires JDMTEG98 STi Forum Archive 21 07-23-2003 05:14 PM
Tire pressures for stock tires on WRX SnortWagon Brakes, Steering & Suspension 5 02-07-2002 12:15 PM
Tire pressures for snow tires? TimStevens Brakes, Steering & Suspension 10 12-22-2001 05:00 AM
Tire Pressure for snow tires??? 99 RS 2.5 New England Impreza Club Forum -- NESIC 4 10-12-2000 09:17 PM
