Old 06-09-2009, 09:41 AM   #1
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Default how does Load Index influence handling?
I am comparing two different tires of the same make/model (Bridgestone Potenza RE760Sport):
225/45R18 91W SL
215/45R18 93W XL
The OE size is the 215 whereas the 225 will fit comfortably. After reading Tirerack's info on their site, I see that the "XL" load rating means that the max load is achieved at a higher pressure of 41psi.
Does this mean the 215 will actually have stiffer sidewalls?
The OE tire is Potenza RE050A 215/45R18 93W XL and I'm pretty happy with it but looking for something longer wearing.
nhluhr is offline   Reply With Quote
Old 06-09-2009, 03:28 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
the xl load rating is a reinforced tire which will(almost always) have a stiffer carcass that a non xl rated tire
how ya like the ms3??
Old 06-09-2009, 04:26 PM   #3
fliz
Member#: 30342
Also, the XL's load capacity is rated at a higher pressure than SL (41 vs. 35).
At 35 psi comparable XL and SL rated tires will have the same load capacity.
Originally Posted by http://www.tirerack.com/tires/tiretech/tirespecskey.jsp
The above chart correctly shows that an extra load tire is not rated to carry any more load than a standard load tire when both are inflated to the same pressure (up to the standard load tire's "maximum load" pressure of 35 psi). This is because a tire's load capacity is a function of its size (which determines the size of the "air chamber"), its construction (which determines how much pressure can be held) and the actual air pressure used (which determines how many air molecules are forced inside the chamber). All tires with equivalent physical dimensions carry equivalent loads (until they reach their maximum load pressure).
fliz is offline   Reply With Quote
Old 06-09-2009, 05:22 PM   #4
rougeben83
Member#: 115154
2005 Outback XT
White on grey
it may also increase the weight of the tire by a pound or two IIRC.
rougeben83 is offline   Reply With Quote
Old 06-10-2009, 09:16 AM   #5
Tire Rack Moderator
Member#: 1215
ext. 4362
finally a good technical question and you guys answer it before I even see it ....
oh well ... good answers guys
I would add that in most cases an 'XL' tire has better steering response than an 'sl' tire if all other parameters are equal
how does up/dp influence sound ? BigWater Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 06-05-2008 11:22 AM
How does engine load scaling work VideoGameWrx Commercial ECU Reflashes 4 06-21-2007 07:42 AM
How does one load balance in XP home? linux>windows Off-Topic 1 11-11-2006 07:16 PM
how much load can a OBS hitch handle? flyingmachine General Community 8 09-17-2004 09:03 PM
dunlop sp5000 with load index of 91 the desert fox Forester Forum 0 02-23-2003 11:58 PM
