Old 06-09-2009, 11:20 AM   #1
Subarurus
Member#: 190155
Subaru Stars My 02 WRX Problems HELP PLEASE!!!!!!!!
I have an 02 WRX the check engine light came on, so i ran the codes , upstream02 and misfires in cylinders 1,2,3. So i replaced the o2 and all four ignition coils, about 25 mins down the road the check engine light came back on. Codes said upstream02 and misfires in cylinders 1,2,3,4. and my car idles high and low but just enough to notice.
Not sure of whats next. Any one have problems similar to mine?
HELP
Subarurus is offline   Reply With Quote
Old 06-09-2009, 11:38 AM   #2
tcpc123
Member#: 121358
2003 wrx
rally blue
list of mods please if any?
tcpc123 is offline   Reply With Quote
Old 06-09-2009, 11:42 AM   #3
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
check for intake manifold gasket leaks...my car did almost the same thing when i had blown my intake gasket. you can use a mirror and a flashlight to see in the hard to reach spots.
amalgrover is offline   Reply With Quote
Old 06-09-2009, 11:52 AM   #4
Subarurus
Member#: 190155
Onlys Mods are SPT intake heat shield and spt catback exhaust , and a HKS SSQV BOV
Old 06-09-2009, 11:56 AM   #5
z&cobb
Member#: 12344
2002 2JC
blue
You probably needed that new front oxygen sensor if you saw a P0031 or P0032. What were the other codes, since you said you "ran the codes?"
How did the car drive before and after you replaced all those parts?
I had the P0032 at 115,000miles. Did you have codes for all four coils too, or were you just feeling generous?
If everything seems right, but the O2 CEL stays on, disconnect the negative battery terminal and push the brake pedal to reset the computer. Then do a proper restart.
z&cobb is offline   Reply With Quote
Old 06-09-2009, 12:00 PM   #6
Gigabelova
Member#: 81409
2004 Impreza WRX STi
Platinum Silver Metallic
Please list all the CEL codes numbers you got.
Gigabelova is offline   Reply With Quote
Old 06-09-2009, 12:08 PM   #7
YourMother'sLover
Member#: 76565
CLXX Stricta Parata
Neci!
Miles on car? When this started? Last work done? etc.
YourMother'sLover is offline   Reply With Quote
Old 06-09-2009, 12:57 PM   #8
Subarurus
Member#: 190155
the shop told me what the codes meant not really sure of what the actual code was. my car has 102,000 miles the problem started about a year ago with the upstream o2 sensor when i took it back to the shop for the actual repairs he ran the computer again and misfires in cylinders 123 came up along with the upstream o2 replaces the o2 and all 4 coil packs. and check engine light came back on about 25 miles down the road , so i took it back and the computer read upstream o2 and misfires in cylinders 123 and 4
Old 06-09-2009, 01:03 PM   #9
Gigabelova
Member#: 81409
Go to an autozone and have them pull your CEL codes. It is free. Your CEL light is on right?
Old 06-09-2009, 01:06 PM   #10
Subarurus
Member#: 190155
yes my cel is on
Old 06-09-2009, 01:26 PM   #11
amalgrover
Member#: 183480
2009 Forester XT
the O2 sensor has been replaced, so you know it isn't that...and its throwing misfire codes as well, which usually means something is going inside the motor and then the O2 sensor is just picking up on that. The front O2 sensor is just measuring the air/fuel mixture in the exhaust, and then is telling the car to either add or remove fuel based on what it is reading. So, if you are running a little rich or lean, then this could be causing the misfires and varying of your idle rpm. Is your vacuum pressure on your boost gauge sitting pretty steady, or is it kinda wavering as well? It just really sounds to me like you are having the symptoms of a vacuum leak...
Old 06-09-2009, 01:57 PM   #12
furryfootstool
Member#: 200526
i just recovered from a long misfire hunt. turns out the valve shims were the issues. i have an 02 with 124k miles. so its possible that you might have the same issue as well. if you check, recheck and change everything out and its still there, then you need to look inside your motor too
furryfootstool is offline   Reply With Quote
Old 06-09-2009, 02:02 PM   #13
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
I say +1 for old/cracked vacuum lines causing a leak.
perform a pressure/boost/vacuum test to find leaks. If none found, I'd say check the valve clearances... 102,000 miles on a turbo motor will lend to tight valves.
-1 for the mechanic jumping the gun to replace the coil packs without properly diagnosing the issue. Don't take the car back to them again. Period!
paintbing is offline   Reply With Quote
Old 06-09-2009, 02:02 PM   #14
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
You beat me to it.
Old 06-09-2009, 02:37 PM   #15
furryfootstool
Member#: 200526
figured you might use me as a reference.
Old 06-11-2009, 05:40 PM   #16
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
bump - Don't create multiple threads please.
05 Cluster into my 02 wrx PROBLEM SLVRBUGEYE Electrical & Lighting 3 04-29-2010 10:10 AM
smokey 02 WRX...hmmmm help please MYnewWRX Tri-State Area Forum 17 12-08-2006 12:06 PM
02 WRX Problem! Help benibarra23 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 06-22-2006 11:27 AM
Rota, 18", 02 WRX Wagon...help please? pakman916 Tire & Wheel 11 07-13-2005 01:48 PM
Buy my 02 WRX Stock parts PLEASE mxg286 Tri-State Area Forum 2 10-21-2004 03:48 PM
