Old 06-09-2009, 11:32 AM   #1
Thug
Choke Artist
Member#: 603
Default Can anyone confirm that this turbo will fit my '05 LGT?
It's supposedly off of an 08 WRX, which from what I've read is a bolt-in.
http://i650.photobucket.com/albums/u...g?t=1244561199
Thanks!
Thug is offline   Reply With Quote
Old 06-09-2009, 12:17 PM   #2
RPA Performance
Member#: 210762
2005 Legacy GT
GRP
The turbo will fit your Legacy, keep in mind you will need better fueling and a tune to go along with it
RPA Performance is offline   Reply With Quote
Old 06-09-2009, 12:18 PM   #3
Thug
Choke Artist
Member#: 603
Thanks! That's what I figured. I'll probably have DSG do an OpenSource tune on it if I end up getting this turbo.
Old 06-09-2009, 12:31 PM   #4
RPA Performance
Member#: 210762
2005 Legacy GT
GRP
Yep,
Some 650cc or bigger injectors will do the trick and maybe a better fuel pump.
Old 06-09-2009, 01:16 PM   #5
rougeben83
Member#: 115154
2005 Outback XT
White on grey
I don't know why you'd want to go to a smaller turbo. That's just a td04l that's been used since the 2002 wrx's. The 09 wrx's got the sti-sized turbo...
I mean, just look at the size of the wastegate compared to the rest of the housing...
rougeben83 is offline   Reply With Quote
Old 06-09-2009, 01:19 PM   #6
Thug
Choke Artist
Member#: 603
Everything I've read says the '08 WRX turbo is larger, not smaller.
Old 06-09-2009, 01:36 PM   #7
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Look at what's inscribed directly on the turbo itself. It's a td04l. If you want to buy fine, but don't be surprised when you pull your stock vf40 and find its the same if not bigger size than what you're going to be replacing it with.
The 08 WRX's were 230hp. The 09 with the bigger turbo are 265hp. You're car is 250hp stock. Put two and two together...
Old 06-09-2009, 04:06 PM   #8
pdx Nick 05 LGT
Member#: 179490
2005 Volvo S40 T5
Flint Gray
this ^^. I wouldn't suggest spending time and money on buying this turbo when you most likely will see no power gains what so ever. There are other direct bolt on vf series turbos that will be in or around that same price range if you are not looking for a ton of more power.
pdx Nick 05 LGT is offline   Reply With Quote
Old 06-10-2009, 09:35 AM   #9
Thug
Choke Artist
Member#: 603
Ballz!
Old 06-10-2009, 05:53 PM   #10
JDMChizad
Member#: 159058
05 LGTx2/Baja T/OB
SWP/GRP/SWP/SPG
If you swap to older VF series turbos, you also need the WRX/STi intercooler. You can also have your VF40 rebuilt with better internals (hybrid)... Not bad for the price if you are looking for a mild upgrade.
JDMChizad is offline   Reply With Quote
Old 06-10-2009, 09:31 PM   #11
Thug
Choke Artist
Member#: 603
I believe I would also need the intake manifold.
Old 06-10-2009, 10:19 PM   #12
JDMChizad
Member#: 159058
05 LGTx2/Baja T/OB
SWP/GRP/SWP/SPG
Oh yeah that, too...
Old 06-10-2009, 10:20 PM   #13
JDMChizad
Member#: 159058
05 LGTx2/Baja T/OB
SWP/GRP/SWP/SPG
Unless you go with an FMIC
Old 06-11-2009, 11:43 AM   #14
RPA Performance
Member#: 210762
2005 Legacy GT
GRP
Good call, I quickly glanced over it and figured it was a VF52 but this turbo is small
anyone know if this lip will fit a wagon? STiwaggen? Interior & Exterior Modification 5 12-14-2005 11:26 AM
Can anyone confirm that racingbrake makes an H6 rotor? AndyU Brakes, Steering & Suspension 1 07-25-2005 05:11 PM
can anyone confirm or deny that margarine is one molecule away from plastic? bobturismo Off-Topic 17 01-04-2004 04:44 AM
Can anyone confirm WRX struts fit '02 TS Wagon? MrJaemz Brakes, Steering & Suspension 1 05-02-2002 10:45 PM
Can anyone tell me if a 2001 cass\cd will fit my 93 impreza? briummkay Car Audio, Video & Security 2 12-13-2001 12:37 AM
